Hi, I am installing JetPack for L4T version 2.1 on my host (Kubuntu 14.04 LTS, Intel i7, Nvidia GPU with CUDA and drivers installed). After running the installer of the “JetPack for L4T” and selecting a full installation with the host and TK1 software (also the installer is able to download all the software), I get an unknown error code 29. the log of the installation is this:
04-07 16:22:40.0 E: fopen failed, errno = 2
04-07 16:22:57.8 N: Install com.nvidia.l4t.driver4os_tk1 21.4.0; Install com.nvidia.l4t.filesystem_tk1 21.4.0; Install com.nvidia.l4t.flash_tk1 21.4.0;
04-07 16:30:41.5 E: Operation was aborted by an application callback
04-07 16:31:27.8 E: Operation was aborted by an application callback
04-07 16:31:28.8 E: Installing Driver for OS 21.4.0 failed.
Return Code: 29
4.2.0-35-generic #40~14.04.1-Ubuntu SMP Fri Mar 18 16:37:35 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
Ubuntu 14.04.4 LTS
I have tried deleting the installer folder and trying again. I have deleted the JetPack-L4T-2.1-linux-x64.run and downloaded it again. I have plenty of hard drive space. The path has no spaces. I have tried installing JetPack-L4T-2.0 and get the same rrror.
Is there anywhere I can just download the images without using the installer and flash them myself?
I’m unsure of JetPack as I use Fedora, but I’m wondering if that message is for driver install on the host? If so, what video card do you use on the host?
The JetPack is just a bundle of software, the individual installer is simpler in many ways (finding and downloading all the packages you want is a pain without JetPack, but can be done). The URL for driver package and sample rootfs are the minimum requirements. For a Jetson TK1, the most recent is R21.4: https://developer.nvidia.com/linux-tegra-r214
Basically you unpack the driver, go into the Linux_for_tegra/rootfs, unpack the sample rootfs, and then cd back to Linux_for_tegra, followed by running sudo ./apply_binaries.sh. At this point you are ready to flash if your Jetson is in recovery mode with USB micro connector connected. The most common flash command is:
sudo ./flash.sh -S 14580MiB jetson-tk1 mmcblk0p1
Flash creates a loopback copy of the file system, along with a sparse (compressed) version, so before you run the actual flash expect that about 30GB of disk is a good amount to have spare prior to flash starting.
