At d_rawDisp[y * width + x] = minDis; Error code: 716,Error message: misaligned address.
When I replace it with d_rawDisp[y * width + x] = 0;,error disappear.
But I try to print minDis;,error also exist.
I don’t know how to fix it.
If it’s an array out-of-bounds issue, I would expect d_rawDisp[y * width + x] = 0 to throw an error, but it probably isn’t.
__global__ void wtamatchKernel()
int x = blockIdx.x * blockDim.x + threadIdx.x;
int y = blockIdx.y * blockDim.y + threadIdx.y;
int height = d_rawImageParameter.m_recImgHeight;
int width = d_rawImageParameter.m_recImgWidth;
if (x < width && y < height)
float minCost = d_fltMax[0];
float minDis = 0;
for (int d = 1; d < d_disparityParameter.m_dispMax; d++) {
float* costData = &d_costVol[d * height * width + y * width + x];
if (*costData * 1000000.0f < 0.01f)
continue;
if (*costData < minCost) {
if (*costData <= 0.0001f) {
minCost = -10.0f;
minDis = 1;
} else {
minCost = *costData;
minDis = d;
As I said, only then the computation is done (otherwise the optimizer removes it). And probably the error is with d_costVol. It is an array so you have to explicitly allocate memory for it.
I found the misaligned address caused by d_fltMax, I fix it.
But the problem minDis also exits.
int disIdx = y * width + x;
/*if (disIdx == 100)
float a = minDis;
printf("a:%f\n", a);
d_rawDisp[disIdx] = 6.6 ;
if (disIdx == 100)
printf("d_rawDisp:%f\n", d_rawDisp[disIdx]);
print d_rawDisp:6.600000
If I run
if (disIdx == 100)
float a = minDis;
It will cause
CUDA error in function 'WTAMatch' at /home/jetson/Desktop/depth/DataDeal.cu:116 (call: cudaDeviceSynchronize()):
Error code: 719
Error message: unspecified launch failure
There are details:
========= Invalid __global__ read of size 4 bytes
========= at wtamatchKernel()+0x390
========= by thread (3,2,0) in block (64,0,0)
========= Address 0x72b22470c is out of bounds
========= and is 6,272,781 bytes after the nearest allocation at 0x72a440000 of size 8,294,400 bytes
========= Saved host backtrace up to driver entry point at kernel launch time
========= Host Frame: [0x2841f3]
========= in /usr/lib/aarch64-linux-gnu/nvidia/libcuda.so.1
========= Host Frame: [0x1853b]
========= in /usr/local/cuda/lib64/libcudart.so.12
========= Host Frame:cudaLaunchKernel [0x80eeb]
========= Host Frame:cudaError cudaLaunchKernel<char>(char*, dim3, dim3, void**, unsigned long, CUstream_st*) in /usr/local/cuda/include/cuda_runtime.h:216 [0xa823]
========= in /home/jetson/Desktop/depth/bin/main
========= Host Frame:__device_stub__Z14wtamatchKernelv() in /tmp/tmpxft_00004572_00000000-10_DataDeal.cudafe1.stub.c:14 [0xa333]
========= Host Frame:wtamatchKernel() in /home/jetson/Desktop/depth/DataDeal.cu:56 [0xa3a7]
========= Host Frame:DataDeal::WTAMatch(cv::Mat*&, cv::Mat&, int) in /home/jetson/Desktop/depth/DataDeal.cu:112 [0x99bb]
========= Host Frame:DepthComputeToolTwo::rawImageDisparityCompute() in /home/jetson/Desktop/depth/DepthComputeToolTwo.cu:58 [0xb39b]
========= Host Frame:ToolTwoTestDemo::data5compute() in /home/jetson/Desktop/depth/ToolTwoTestDemo.cpp:256 [0x6b2b]
========= Host Frame:demo2() in /home/jetson/Desktop/depth/main.cu:42 [0x59fb]
========= Host Frame:main in /home/jetson/Desktop/depth/main.cu:61 [0x5aeb]
========= Host Frame:__libc_start_call_main in ../sysdeps/nptl/libc_start_call_main.h:58 [0x273fb]
========= in /lib/aarch64-linux-gnu/libc.so.6
========= Host Frame:__libc_start_main in ../csu/libc-start.c:392 [0x274cb]
========= Host Frame:_start [0x506f]
init parameter use time: 280904 ms
Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 Is it: 1 CUDA kernel execution time: 151355 ms
