Error code selection failed in OpenCL, not in CUDA Error: Code selection failed to select
The following kernel results in a [font=“Lucida Console”]Error: Code selection failed to select: 0000000012D695F0: i1 = select 0000000012D69EA8, 000000001303F020, 0000000012D6B110[/font]
when using OpenCL on NVIDIA, works fine in CUDA as well as in the ATI Stream SDK.
[codebox]__kernel void Bug_NVIDIA_Select (
const int 	a,
__global float* out)
float t = 1;
if (a) t -= 1;
*out = a;
}[/codebox]
Any idea how to work around this? Tried on a Quadro FX5800 with latest drivers (197.28).
I have problem like your, but it happens at the next code
[codebox]__kernel void a(__global unsigned long *x){
unsigned long W[80];
for(int i = 16; i < 80; ++i)
W[i] = W[i-7];
//for example
*x = W[50];
}[/codebox]
Error: Code selection failed to select: 0000000049865172 i64 = bswap 0000000053D65124
It seems to me that the reason for 64-bit numbers…
W[i] = W[i-7];
//for example
*x = W[50];
}[/codebox]
I have the same problem with my kernel.
Did you find a solution ? Or at least a clue about that error ?
It would be very nice that any one, and particularly Nvidia guys, provide support …
I find I get this error from type mismatches, e.g. if I try to pass a float or float vector to a function’s int argument.
I note the first example is trying to store an int into a dereferenced float pointer. Maybe casting to (float) first might help.
If that’s the case, it’s still a compiler error - such typecasts should be implicit.
Hi, I also have this problem with this code :
return ((scramble >> 8) & 0xffffff) / (float)(1 << 24);
The error :
Error: Code selection failed to select: 1B251F38: i32 = bswap 1B252FB0
Does someone has an idea ?
I have modified my code like this and it works, but don’t know why :
float u = (float)n;
float y = (((float)u) / 256);
return 0.f;
But when I try to return the good value I have the error message :
float u = (float)n;
return y;
