I am trying to convert a keras model (ResNet50 trained with ImageNet) to TensorRT 5.1.2.2 using ONNX. This is the way I am converting it to an ONNX model. And it seems that it works.
# It creates an ONNX file from a Keras model
def fromKeras2Onnx(outfile='proves.onnx'):
model = ResNet50(weights='imagenet')
onnx_model = onnxmltools.convert_keras(model,target_opset=7)
onnxmltools.utils.save_model(onnx_model, outfile)
However when I convert the ONNX model to TensorRT using this function:
# It creates a TensorRt engine from an ONNX model
def fromOnnx2TensorRtEngine(onnx_file_path, engine_file_path):
b = False
with trt.Builder(TRT_LOGGER) as builder, builder.create_network() as network, trt.OnnxParser(network, TRT_LOGGER) as parser:
builder.max_workspace_size = 1 << 30 #1GB
builder.max_batch_size = 1
builder.fp16_mode = True
if not os.path.exists(onnx_file_path):
print('ONNX file {} not found!'.format(onnx_file_path))
exit(0)
print('Loading ONNX file from path {}'.format(onnx_file_path))
with open(onnx_file_path,'rb') as model:
print('Beginning ONNX file parsing')
b = parser.parse(model.read()) # if the parsing was completed b is true
if b:
print('Completed parsing of ONNX file')
print('Building an engine from file {}; this may take a while'.format(onnx_file_path))
engine = builder.build_cuda_engine(network)
del parser
if(engine):
print('Completed creating Engine')
with open(engine_file_path,"wb") as f:
f.write(engine.serialize())
print('Engine saved')
else:
print('Error building engine')
exit(1)
else:
print('Number of errors: {}'.format(parser.num_errors))
error = parser.get_error(0) # if it gets more than one error this have to be changed
del parser
desc = error.desc()
line = error.line()
code = error.code()
print('Description of the error: {}'.format(desc))
print('Line where the error occurred: {}'.format(line))
print('Error code: {}'.format(code))
print("Model was not parsed successfully")
exit(0)
I do get an error while it is parsing the ONNX file:
Number of errors: 1
Description of the error: Assertion failed: onnx_padding[0] == 0 && onnx_padding[1] == 0 && onnx_padding[4] == 0 && onnx_padding[5] == 0
Line where the error occurred: 1366
Error code: UNSUPPORTED_NODE
My first guess is that there is some layer that is not supported by tensorRT. If this is the case, how can I solve it? Is there a way to know which layers are not supported by tensorRT?
The versions of some libraries/framework I am using:
Thanks for your time :D
