Error Compiling CUDA Samples
Hello, I install CUDA 11.4 with the necessary packages, also make the corresponding PATH. Which is attached below:
export PATH=/usr/local/cuda-11.4/bin${PATH:+:${PATH}}
export LD_LIBRARY_PATH=/usr/local/cuda-11.4/lib64${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
But when I want to compile (make) the samples it throws me the following errors. This error may be caused.
The error is shown in the attached image.
Extra data:
CUDA 11.4
gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-16)
Copyright (C) 2015 Free Software Foundation, Inc.
uname -r
3.10.0-693.5.2.el7.x86_64
x86_64
CentOS Linux release 7.4.1708 (Core)
NAME=“CentOS Linux”
VERSION=“7 (Core)”
ID=“centos”
ID_LIKE=“rhel fedora”
VERSION_ID=“7”
PRETTY_NAME=“CentOS Linux 7 (Core)”
ANSI_COLOR=“0;31”
CPE_NAME=“cpe:/o:centos:centos:7”
CENTOS_MANTISBT_PROJECT=“CentOS-7”
CENTOS_MANTISBT_PROJECT_VERSION=“7”
REDHAT_SUPPORT_PRODUCT=“centos”
REDHAT_SUPPORT_PRODUCT_VERSION=“7”
Cuda 11 requires at least gcc 6. Please update your system.
I can install an older version? I see that the 10.0.3 needs GCC 4.8.5…
Depends on the gpu, what model do you have?
Quadro K600
That works, you can also use cuda 10 with it.
