I’ve just installed a PGI 16.10 community version on my Ubuntu 16.10 x64.
Then I write a “hello world” program to test whether the compiler works well.
#include <iostream>
using namespace std;
int main() {
cout << "Hello PGI" << endl;
return 0;
Then I use “$ pgc++ -o test.out test.cc” and I get the following error messages:
"/usr/include/c++/6/exception", line 64: error: expected a ";"
virtual ~exception() _GLIBCXX_TXN_SAFE_DYN _GLIBCXX_USE_NOEXCEPT;
"/usr/include/c++/6/exception", line 69: error: expected a ";"
what() const _GLIBCXX_TXN_SAFE_DYN _GLIBCXX_USE_NOEXCEPT;
"/usr/include/c++/6/exception", line 81: error: expected a ";"
virtual ~bad_exception() _GLIBCXX_TXN_SAFE_DYN _GLIBCXX_USE_NOEXCEPT;
"/usr/include/c++/6/exception", line 85: error: expected a ";"
"/usr/include/c++/6/bits/basic_string.h", line 381: error: expected a ";"
_GLIBCXX_NOEXCEPT_IF(is_nothrow_default_constructible<_Alloc>::value)
"/usr/include/c++/6/bits/basic_string.h", line 5289: error: expected a ";"
_GLIBCXX_NOEXCEPT_IF(noexcept(__lhs.swap(__rhs)))
"/usr/include/c++/6/bits/basic_string.h", line 5312: error: "operator>>" is not
a class or function template name in the current scope
operator>>(basic_istream<char>& __is, basic_string<char>& __str);
"/usr/include/c++/6/bits/basic_string.tcc", line 348: error: declaration is
incompatible with "void std::__cxx11::basic_string<_CharT, _Traits,
_Alloc>::resize(std::__cxx11::basic_string<_CharT, _Traits,
_Alloc>::size_type)" (declared at line 827 of
"/usr/include/c++/6/bits/basic_string.h")
resize(size_type __n, _CharT __c)
"/usr/include/c++/6/stdexcept", line 120: error: expected a ";"
logic_error(const string& __arg) _GLIBCXX_TXN_SAFE;
"/usr/include/c++/6/stdexcept", line 132: error: expected a ";"
virtual ~logic_error() _GLIBCXX_TXN_SAFE_DYN _GLIBCXX_USE_NOEXCEPT;
"/usr/include/c++/6/stdexcept", line 137: error: expected a ";"
"/usr/include/c++/6/stdexcept", line 150: error: expected a ";"
explicit domain_error(const string& __arg) _GLIBCXX_TXN_SAFE;
"/usr/include/c++/6/stdexcept", line 161: error: expected a ";"
explicit invalid_argument(const string& __arg) _GLIBCXX_TXN_SAFE;
"/usr/include/c++/6/stdexcept", line 173: error: expected a ";"
explicit length_error(const string& __arg) _GLIBCXX_TXN_SAFE;
"/usr/include/c++/6/stdexcept", line 185: error: expected a ";"
explicit out_of_range(const string& __arg) _GLIBCXX_TXN_SAFE;
"/usr/include/c++/6/stdexcept", line 204: error: expected a ";"
runtime_error(const string& __arg) _GLIBCXX_TXN_SAFE;
"/usr/include/c++/6/stdexcept", line 216: error: expected a ";"
virtual ~runtime_error() _GLIBCXX_TXN_SAFE_DYN _GLIBCXX_USE_NOEXCEPT;
"/usr/include/c++/6/stdexcept", line 221: error: expected a ";"
"/usr/include/c++/6/stdexcept", line 233: error: expected a ";"
explicit range_error(const string& __arg) _GLIBCXX_TXN_SAFE;
"/usr/include/c++/6/stdexcept", line 244: error: expected a ";"
explicit overflow_error(const string& __arg) _GLIBCXX_TXN_SAFE;
"/usr/include/c++/6/stdexcept", line 255: error: expected a ";"
explicit underflow_error(const string& __arg) _GLIBCXX_TXN_SAFE;
21 errors detected in the compilation of "test.cc".
It seems that the g++ 6 headers are not correctly supported within the compiler. However, from the release information, http://www.pgroup.com/support/new_rel.htm
It says
PGI C++ Compiler
Comprehensive support of C++14, requires GCC version 5.0 or greater; full interoperability with GCC 5.1
. So I assume it should work with g++ 6 headers.
Could someone help me with this problem?
