==ERROR== Could not deploy stock section files toc
I cannot get rid of this error:
$ nv-nsight-cu-cli --mode=launch julia
==ERROR== Could not deploy stock section files to "/home/guy/Documents/NVIDIA Nsight Compute/2020.3.1/Sections".
~/Documents/NVIDIA Nsight Compute/2020.3.1/Sections$ ncu --section-folder-restore
No change of permissions fixes it. Creating the directories manually doesn’t fix it. Even changing home to /tmp does not fix it:
==ERROR== Could not deploy stock section files to "/tmp/Documents/NVIDIA Nsight Compute/2020.3.1/Sections".
Welcome to the NVIDIA Developer forums. I am moving this topic to the Nsight Compute category for better visibility.
Tom K
Can you check that the stock sections directory is actually present for you ncu installation? The directory structure from where the ncu binary is taken should look similar to this:
$ ls <ncu install dir>
docs  EULA.txt  extras  host  ncu  ncu-ui  nv-nsight-cu  nv-nsight-cu-cli  sections  target
The “sections” directory in this listing should include multiple .section and .py files.
You might also want to consider using a newer version of Nsight Compute, i.e. 2021.3.1. Newer versions are generally backwards-compatible with older drivers and CUDA toolkit versions.
