I cannot run a program compiled with -Mprof=hwcts. There seems to be a PAPI initialization error. However, I can compile a simple program using PAPI_library_init. Also papi_avail lists 36 available events.
[chulbert@fourier chulbert]$ cat pgeventc.c
int main(int argc, char *argv) {
__pgevents();
exit(0);
[chulbert@fourier chulbert]$ pgcc pgeventc.c -o pgevents -lpgnod_prof_papi -lpapi
[chulbert@fourier chulbert]$ ./pgevents
Selecting Events
setenv PGPROF_EVENTS event0[.over][:event1[.over]] …
The over is the number of events counted before the counter
overflows and increments a bucket, the default is 1000000.
See the PGI tools guide for more information concerning
PAPI interface initialization errors and warnings.
Error: Could not initialization PAPI interface
[chulbert@fourier chulbert]$ cat junk.c
#include <papi.h>
int main(void)
int x = PAPI_library_init(PAPI_VER_CURRENT);
printf(“PAPI initialization returned %d (PAPI_VER_CURRENT=%d)\n”,
x,PAPI_VER_CURRENT);
return 0;
[chulbert@fourier chulbert]$ pgcc -o junk junk.c -lpapi
[chulbert@fourier chulbert]$ ./junk
PAPI initialization returned 50724864 (PAPI_VER_CURRENT=50724864)
[chulbert@fourier chulbert]$ papi_avail
Available events and hardware information.
Vendor string and code : AuthenticAMD (2)
Model string and code : AMD K8 Revision C (15)
CPU Revision : 2.000000
CPU Megahertz : 2010.314941
CPU Clock Megahertz : 2010
CPU’s in this Node : 2
Nodes in this System : 1
Total CPU’s : 2
Number Hardware Counters : 4
Max Multiplex Counters : 32
The following correspond to fields in the PAPI_event_info_t structure.
Name Code Avail Deriv Description (Note)
PAPI_L1_DCM 0x80000000 Yes No Level 1 data cache misses
PAPI_L1_ICM 0x80000001 Yes No Level 1 instruction cache misses
PAPI_L2_DCM 0x80000002 Yes No Level 2 data cache misses
PAPI_L2_ICM 0x80000003 Yes No Level 2 instruction cache misses
PAPI_L3_DCM 0x80000004 No No Level 3 data cache misses
PAPI_L3_ICM 0x80000005 No No Level 3 instruction cache misses
PAPI_L1_TCM 0x80000006 Yes Yes Level 1 cache misses
PAPI_L2_TCM 0x80000007 Yes No Level 2 cache misses
PAPI_L3_TCM 0x80000008 No No Level 3 cache misses
PAPI_CA_SNP 0x80000009 No No Requests for a snoop
PAPI_CA_SHR 0x8000000a No No Requests for exclusive access to shared cache line
PAPI_CA_CLN 0x8000000b No No Requests for exclusive access to clean cache line
PAPI_CA_INV 0x8000000c No No Requests for cache line invalidation
PAPI_CA_ITV 0x8000000d No No Requests for cache line intervention
PAPI_L3_LDM 0x8000000e No No Level 3 load misses
PAPI_L3_STM 0x8000000f No No Level 3 store misses
PAPI_BRU_IDL 0x80000010 No No Cycles branch units are idle
PAPI_FXU_IDL 0x80000011 No No Cycles integer units are idle
PAPI_FPU_IDL 0x80000012 Yes No Cycles floating point units are idle
PAPI_LSU_IDL 0x80000013 No No Cycles load/store units are idle
PAPI_TLB_DM 0x80000014 Yes No Data translation lookaside buffer misses
PAPI_TLB_IM 0x80000015 Yes No Instruction translation lookaside buffer misses
PAPI_TLB_TL 0x80000016 Yes Yes Total translation lookaside buffer misses
PAPI_L1_LDM 0x80000017 No No Level 1 load misses
PAPI_L1_STM 0x80000018 No No Level 1 store misses
PAPI_L2_LDM 0x80000019 No No Level 2 load misses
PAPI_L2_STM 0x8000001a No No Level 2 store misses
PAPI_BTAC_M 0x8000001b No No Branch target address cache misses
PAPI_PRF_DM 0x8000001c No No Data prefetch cache misses
PAPI_L3_DCH 0x8000001d No No Level 3 data cache hits
PAPI_TLB_SD 0x8000001e No No Translation lookaside buffer shootdowns
PAPI_CSR_FAL 0x8000001f No No Failed store conditional instructions
PAPI_CSR_SUC 0x80000020 No No Successful store conditional instructions
PAPI_CSR_TOT 0x80000021 No No Total store conditional instructions
PAPI_MEM_SCY 0x80000022 No No Cycles Stalled Waiting for memory accesses
PAPI_MEM_RCY 0x80000023 No No Cycles Stalled Waiting for memory Reads
PAPI_MEM_WCY 0x80000024 No No Cycles Stalled Waiting for memory writes
PAPI_STL_ICY 0x80000025 Yes No Cycles with no instruction issue
PAPI_FUL_ICY 0x80000026 No No Cycles with maximum instruction issue
PAPI_STL_CCY 0x80000027 No No Cycles with no instructions completed
PAPI_FUL_CCY 0x80000028 No No Cycles with maximum instructions completed
PAPI_HW_INT 0x80000029 Yes No Hardware interrupts
PAPI_BR_UCN 0x8000002a No No Unconditional branch instructions
PAPI_BR_CN 0x8000002b No No Conditional branch instructions
PAPI_BR_TKN 0x8000002c Yes No Conditional branch instructions taken
PAPI_BR_NTK 0x8000002d No No Conditional branch instructions not taken
PAPI_BR_MSP 0x8000002e Yes No Conditional branch instructions mispredicted
PAPI_BR_PRC 0x8000002f No No Conditional branch instructions correctly predicted
PAPI_FMA_INS 0x80000030 No No FMA instructions completed
PAPI_TOT_IIS 0x80000031 No No Instructions issued
PAPI_TOT_INS 0x80000032 Yes No Instructions completed
PAPI_INT_INS 0x80000033 No No Integer instructions
PAPI_FP_INS 0x80000034 Yes No Floating point instructions
PAPI_LD_INS 0x80000035 No No Load instructions
PAPI_SR_INS 0x80000036 No No Store instructions
PAPI_BR_INS 0x80000037 Yes No Branch instructions
PAPI_VEC_INS 0x80000038 Yes No Vector/SIMD instructions
PAPI_RES_STL 0x80000039 Yes No Cycles stalled on any resource
PAPI_FP_STAL 0x8000003a No No Cycles the FP unit(s) are stalled
PAPI_TOT_CYC 0x8000003b Yes No Total cycles
PAPI_LST_INS 0x8000003c No No Load/store instructions completed
PAPI_SYC_INS 0x8000003d No No Synchronization instructions completed
PAPI_L1_DCH 0x8000003e Yes Yes Level 1 data cache hits
PAPI_L2_DCH 0x8000003f Yes Yes Level 2 data cache hits
PAPI_L1_DCA 0x80000040 Yes No Level 1 data cache accesses
PAPI_L2_DCA 0x80000041 Yes No Level 2 data cache accesses
PAPI_L3_DCA 0x80000042 No No Level 3 data cache accesses
PAPI_L1_DCR 0x80000043 No No Level 1 data cache reads
PAPI_L2_DCR 0x80000044 No No Level 2 data cache reads
PAPI_L3_DCR 0x80000045 No No Level 3 data cache reads
PAPI_L1_DCW 0x80000046 No No Level 1 data cache writes
PAPI_L2_DCW 0x80000047 No No Level 2 data cache writes
PAPI_L3_DCW 0x80000048 No No Level 3 data cache writes
PAPI_L1_ICH 0x80000049 Yes Yes Level 1 instruction cache hits
PAPI_L2_ICH 0x8000004a Yes No Level 2 instruction cache hits
PAPI_L3_ICH 0x8000004b No No Level 3 instruction cache hits
PAPI_L1_ICA 0x8000004c Yes No Level 1 instruction cache accesses
PAPI_L2_ICA 0x8000004d Yes No Level 2 instruction cache accesses
PAPI_L3_ICA 0x8000004e No No Level 3 instruction cache accesses
PAPI_L1_ICR 0x8000004f Yes No Level 1 instruction cache reads
PAPI_L2_ICR 0x80000050 No No Level 2 instruction cache reads
PAPI_L3_ICR 0x80000051 No No Level 3 instruction cache reads
PAPI_L1_ICW 0x80000052 No No Level 1 instruction cache writes
PAPI_L2_ICW 0x80000053 No No Level 2 instruction cache writes
PAPI_L3_ICW 0x80000054 No No Level 3 instruction cache writes
PAPI_L1_TCH 0x80000055 Yes Yes Level 1 total cache hits
PAPI_L2_TCH 0x80000056 Yes Yes Level 2 total cache hits
PAPI_L3_TCH 0x80000057 No No Level 3 total cache hits
PAPI_L1_TCA 0x80000058 Yes Yes Level 1 total cache accesses
PAPI_L2_TCA 0x80000059 Yes No Level 2 total cache accesses
PAPI_L3_TCA 0x8000005a No No Level 3 total cache accesses
PAPI_L1_TCR 0x8000005b No No Level 1 total cache reads
PAPI_L2_TCR 0x8000005c No No Level 2 total cache reads
PAPI_L3_TCR 0x8000005d No No Level 3 total cache reads
PAPI_L1_TCW 0x8000005e No No Level 1 total cache writes
PAPI_L2_TCW 0x8000005f No No Level 2 total cache writes
PAPI_L3_TCW 0x80000060 No No Level 3 total cache writes
PAPI_FML_INS 0x80000061 Yes No Floating point multiply instructions
PAPI_FAD_INS 0x80000062 Yes No Floating point add instructions
PAPI_FDV_INS 0x80000063 No No Floating point divide instructions
PAPI_FSQ_INS 0x80000064 No No Floating point square root instructions
PAPI_FNV_INS 0x80000065 No No Floating point inverse instructions
PAPI_FP_OPS 0x80000066 Yes No Floating point operations (Counts speculative adds and multiplies. Variable and higher than theoretical.)
Of 103 possible events, 36 are available, of which 8 are derived.
avail.c PASSED
