Error creating mfi archive for massflash Orin NX JetPack 7.2.1
I’m getting an error when trying to create an MFI archive according to the instructions. A patch has been released for Jetpack 7.2 and Jetson AGX. Is it still relevant for 7.2.1 and NX?
First, execute the command
sudo BOARDID=3767 BOARDSKU=0000 ./l4t_initrd_flash.sh --no-flash jetson-orin-nano-devkit-super internal
then I execute the command
sudo BOARDID=3767 BOARDSKU=0000 ROOTFS_ENC=1
./l4t_initrd_flash.sh --no-flash -S 16GiB --external-only --append -i /home/jetson/Linux_for_Tegra/source/tegra/optee-src/nv-optee/optee/samples/hwkey-agent/host/tool/gen_ekb/sym2_t234.key -p “–generic-passphrase”
–massflash 5 --showlogs jetson-orin-nano-devkit-super external
The last command fails and does not create an MFI file.
Update: If you set the massflash parameter to 1 instead of 5, the MFI archive is created, but when trying to flash the Jetson, errors are displayed.
Please refer to the below commands since orin nx dont have internal storage
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --massflash 10 \
  --external-device nvme0n1p1 \
  -c tools/kernel_flash/flash_l4t_external.xml \
  -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
  --showlogs --network usb0 jetson-orin-nano-devkit internal
