Good day to all,
I thank you if you can please help me with the following problem:
I work with programs that make use of the graphics card until yesterday 11.11.20 it worked without problems, today it was updated and it does not work for me:
When running the program, the following appears:
cuInit (): unknown error.
I tried to run a script from the nvidia page (Device node Verification Installation Guide Linux :: CUDA Toolkit Documentation):
mknod: / dev / nvidia0: File exists
mknod: / dev / nvidiactl: File exists
modprobe: ERROR: could not insert ‘nvidia_current_uvm’: Unknown symbol in module, or unknown parameter (see dmesg)
modprobe: ERROR: …/libkmod/libkmod-module.c:990 command_do () Error running install command 'modprobe nvidia; modprobe -i nvidia-current-uvm 'for module nvidia_uvm: retcode 1
modprobe: ERROR: could not insert ‘nvidia_uvm’: Invalid argument
Data that can help:
OS: Linux Debian 10.2.0-15
NVIDIA: GTX 1060 3GB
nvcc --version
Copyright (c) 2005-2020 NVIDIA Corporation
Built on Wed_Jul_22_19: 09: 09_PDT_2020
Cuda compilation tools, release 11.0, V11.0.221
Build cuda_11.0_bu.TC445_37.28845127_0 -
nvidia-smi
Thu Nov 12 14:10:58 2020
| NVIDIA-SMI 450.80.02 Driver Version: 450.80.02 CUDA Version: 11.0 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr: Usage / Cap | Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 GeForce GTX 1060 Off | 00000000: 01: 00.0 On | N / A |
| N / A 47C P8 6W / N / A | 248MiB / 3016MiB | 0% Default |
| | | N / A | -
| Processes: |
| ID ID Usage |
| 0 N / A N / A 1006 G / usr / lib / xorg / Xorg 243MiB |
| 0 N / A N / A 1295 G xfwm4 2MiB | -
