Error: curl failed with error 126
I am trying to install the license keys for PGI Fortran workstation.
When running the PGI license tool /usr/pgi/linux86/16.3/bin/pgi_license_tool
I have
ERROR: curl failed with error 126
What does it mean and what should I do?
Are you running on a 32-bit Linux system?
If you are running on a 64-bit Linux system, run
$PGI/linux86-64/16.3/bin/pgi_license_tool
and see if that works.
If not, do things manually. Send the output dialogs of the following to License@pgroup.com
  1. lsb_release
  2. /sbin/ifconfig
  3. lmutil lmhostid
  4. lmutil lmhostid -hostname
  5. lmutil lmhostid -internet
  6. ping localhost
  7. ping “the hostname revealed in (4)”
dave
