• Hardware (T4/V100/Xavier/Nano/etc)
v100
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc)
Action Recognition Net
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
root@IDC_GPU_Server-1:/opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-3d-action-recognition# ./deepstream-3d-action-recognition -c deepstream_action_recognition_config.txt
num-sources = 4
Now playing: file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_walk.mov, file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_ride_bike.mov, file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_run.mov, file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_push.mov,
0:00:02.997766186 605 0x7f31e4002350 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-3d-action-recognition/resnet18_3d_rgb_hmdb5_32.etlt_b4_gpu0_fp16.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [FullDims Engine Info]: layers num: 2
0 INPUT kFLOAT input_rgb 3x32x224x224 min: 1x3x32x224x224 opt: 4x3x32x224x224 Max: 4x3x32x224x224
1 OUTPUT kFLOAT fc_pred 5 min: 0 opt: 0 Max: 0
0:00:02.997883847 605 0x7f31e4002350 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-3d-action-recognition/resnet18_3d_rgb_hmdb5_32.etlt_b4_gpu0_fp16.engine
0:00:03.000249151 605 0x7f31e4002350 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:config_infer_primary_3d_action.txt sucessfully
sequence_image_process.cpp:496, [INFO: CUSTOM_LIB] 3D custom sequence network info(NCSHW), [N: 4, C: 3, S: 32, H: 224, W:224]
sequence_image_process.cpp:524, [INFO: CUSTOM_LIB] Sequence preprocess buffer manager initialized with stride: 1, subsample: 0
sequence_image_process.cpp:526, [INFO: CUSTOM_LIB] SequenceImagePreprocess initialized successfully
Using user provided processing height = 224 and processing width = 224
Decodebin child added: source
Decodebin child added: decodebin0
Decodebin child added: decodebin1
Decodebin child added: decodebin2
Decodebin child added: decodebin3
Running...
Decodebin child added: qtdemux0
Decodebin child added: qtdemux1
Decodebin child added: multiqueue1
Decodebin child added: multiqueue0
Decodebin child added: qtdemux2
Decodebin child added: qtdemux3
Decodebin child added: multiqueue2
Decodebin child added: h264parse0
Decodebin child added: multiqueue3
Decodebin child added: capsfilter0
Decodebin child added: h264parse1
Decodebin child added: h264parse2
Decodebin child added: capsfilter1
Decodebin child added: capsfilter2
Decodebin child added: h264parse3
Decodebin child added: capsfilter3
Decodebin child added: aacparse0
Decodebin child added: aacparse1
Decodebin child added: aacparse2
Decodebin child added: aacparse3
Decodebin child added: avdec_aac0
Decodebin child added: avdec_aac1
Decodebin child added: avdec_aac2
Decodebin child added: avdec_aac3
Decodebin child added: nvv4l2decoder0
Decodebin child added: nvv4l2decoder1
Decodebin child added: nvv4l2decoder2
Decodebin child added: nvv4l2decoder3
In cb_newpad
In cb_newpad
In cb_newpad
In cb_newpad
In cb_newpad
In cb_newpad
In cb_newpad
In cb_newpad
0:00:03.538095349 605 0x5644ad15d050 WARN nvinfer gstnvinfer.cpp:2288:gst_nvinfer_output_loop:<primary-nvinference-engine> error: Internal data stream error.
0:00:03.538156715 605 0x5644ad15d050 WARN nvinfer gstnvinfer.cpp:2288:gst_nvinfer_output_loop:<primary-nvinference-engine> error: streaming stopped, reason not-negotiated (-4)
ERROR from element primary-nvinference-engine: Internal data stream error.
Error details: gstnvinfer.cpp(2288): gst_nvinfer_output_loop (): /GstPipeline:preprocess-test-pipeline/GstNvInfer:primary-nvinference-engine:
Returned, stopping playback
sequence_image_process.cpp:586, [INFO: CUSTOM_LIB] SequenceImagePreprocess is deinitializing
Deleting pipeline
