Hello all,
I am having a really hard time compiling this code. When I try to compile it with nvcc I see a weird error. I have searched the internet (google) and the nvidia forums but haven’t seen a similar error.
Here is the code snippet followed by the error.
[codebox]
template <int s>
extern global void dec_kernel(float *, float *);
template <int l, int blockSize>
extern global void min_err(float *);
template <int l, int s>
host void decode(float *g_odata, float *g_idata)
dim3 dimBlock(l, 1, 1);
dim3 dimGrid(l, 1, 1);
int smemSize = l * sizeof(float);
dec_kernel<4><<< dimGrid, dimBlock, smemSize >>>(g_idata, g_odata);
merr <4,4><<< dimGrid, dimBlock, smemSize >>>(g_odata);
[/codebox]
NVCC output:
kernel.cu: In function `void decode(float*, float*)’:
kernel.cu:223: error: `_device_stub___globfunc__Z10dec_kernelILi4EEvPfS0’ undeclared (first use this function)
kernel.cu:223: error: (Each undeclared identifier is reported only once for each function it appears in.)
kernel.cu:224: error: `__device_stub___globfunc__Z7merrILi4ELi4EEvPf’ undeclared (first use this function)
Looks like the template instance of the function is being created but I still see a compilation error.
Has anyone seen this before? Can any one suggest ways to debug this or work around this?
-Kalyan
