hi
I use latest JetPack 5.0.1 to flash my NX dev kit, and use Jetson Linux 34.1.1 downloaded from Jetson Linux | NVIDIA Developer to build new Image.
Here is how I compile and create new Image and Image.sig
$ make clean
$ make ARCH=arm64 O=$TEGRA_KERNEL_OUT tegra_defconfig
$ make ARCH=arm64 O=$TEGRA_KERNEL_OUT Image
$ . /l4t_sign_image.sh --file $TEGRA_KERNEL_OUT/arch/arm64/boot/Image --chip 0x19
After I copy Image and Image.sig to SD card /boot folder and reboot system, I got error message for modules “disagrees about version of symbol module_layout”.
here is dmesg output
$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x4e0f0040]
[ 0.000000] Linux version 5.10.65-tegra (hwang@strix-ubuntu) (aarch64-linux-gnu-gcc (Linaro GCC 7.3-2018.05) 7.3.1 2012
[ 0.000000] Machine model: NVIDIA Jetson Xavier NX Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x254b11a98 SMBIOS=0xc7db0000 SMBIOS 3.0=0x253980000 MEMATTR=0x252751018 ESRT=0x253076b98 RNG=
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000000253076b98 to 0x0000000253076bd0.
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size B
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size B
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size B
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size B
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000027fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000aeffffff]
[ 0.000000] node 0: [mem 0x00000000af010000-0x00000000c7bfffff]
[ 0.000000] node 0: [mem 0x00000000c7d00000-0x00000000c7d9ffff]
[ 0.000000] node 0: [mem 0x00000000c7da0000-0x00000000c7dbffff]
[ 0.000000] node 0: [mem 0x00000000ca000000-0x00000000ca5fffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000000252fcffff]
[ 0.000000] node 0: [mem 0x0000000252fd0000-0x0000000252ffffff]
[ 0.000000] node 0: [mem 0x0000000253000000-0x000000025303ffff]
[ 0.000000] node 0: [mem 0x0000000253040000-0x000000025305ffff]
[ 0.000000] node 0: [mem 0x0000000253060000-0x00000002535a0fff]
[ 0.000000] node 0: [mem 0x00000002535a1000-0x000000025372ffff]
[ 0.000000] node 0: [mem 0x0000000253730000-0x000000025396ffff]
[ 0.000000] node 0: [mem 0x0000000253970000-0x000000025398ffff]
[ 0.000000] node 0: [mem 0x0000000253990000-0x000000025411ffff]
[ 0.000000] node 0: [mem 0x0000000254120000-0x000000025423ffff]
[ 0.000000] node 0: [mem 0x0000000254240000-0x00000002542fffff]
[ 0.000000] node 0: [mem 0x0000000254300000-0x00000002544dffff]
[ 0.000000] node 0: [mem 0x00000002544e0000-0x00000002544effff]
[ 0.000000] node 0: [mem 0x00000002544f0000-0x000000025453ffff]
[ 0.000000] node 0: [mem 0x0000000254540000-0x000000025459ffff]
[ 0.000000] node 0: [mem 0x00000002545a0000-0x00000002547affff]
[ 0.000000] node 0: [mem 0x00000002547b0000-0x00000002547bffff]
[ 0.000000] node 0: [mem 0x00000002547c0000-0x000000025481ffff]
[ 0.000000] node 0: [mem 0x0000000254820000-0x000000025485ffff]
[ 0.000000] node 0: [mem 0x0000000254860000-0x00000002548fffff]
[ 0.000000] node 0: [mem 0x0000000254900000-0x000000025490ffff]
[ 0.000000] node 0: [mem 0x0000000254910000-0x000000025492ffff]
[ 0.000000] node 0: [mem 0x0000000254930000-0x000000025494ffff]
[ 0.000000] node 0: [mem 0x0000000254950000-0x00000002549effff]
[ 0.000000] node 0: [mem 0x00000002549f0000-0x0000000254a6ffff]
[ 0.000000] node 0: [mem 0x0000000254a70000-0x0000000254b0ffff]
[ 0.000000] node 0: [mem 0x0000000254b10000-0x0000000254bfffff]
[ 0.000000] node 0: [mem 0x0000000254c00000-0x0000000254c9ffff]
[ 0.000000] node 0: [mem 0x0000000254ca0000-0x0000000254d3ffff]
[ 0.000000] node 0: [mem 0x0000000254d40000-0x0000000254ddffff]
[ 0.000000] node 0: [mem 0x0000000254de0000-0x0000000254e3ffff]
[ 0.000000] node 0: [mem 0x0000000254e40000-0x0000000254f2ffff]
[ 0.000000] node 0: [mem 0x0000000254f30000-0x000000025570ffff]
[ 0.000000] node 0: [mem 0x0000000255710000-0x00000002558effff]
[ 0.000000] node 0: [mem 0x00000002558f0000-0x000000027bc4ffff]
[ 0.000000] node 0: [mem 0x000000027bc50000-0x000000027bc9ffff]
[ 0.000000] node 0: [mem 0x000000027bca0000-0x000000027fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000027fffffff]
[ 0.000000] On node 0 totalpages: 1868464
[ 0.000000] DMA zone: 4619 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 295600 pages, LIFO batch:63
[ 0.000000] Normal zone: 24576 pages used for memmap
[ 0.000000] Normal zone: 1572864 pages, LIFO batch:63
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c3c00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 31 pages/cpu s90008 r8192 d28776 u126976
[ 0.000000] pcpu-alloc: s90008 r8192 d28776 u126976 alloc=31*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] CPU features: detected: Spectre-v2
[ 0.000000] CPU features: detected: NVIDIA Carmel CNP erratum
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1839269
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000b3c00000-0x00000000c3c00000] (256MB)
[ 0.000000] Memory: 6942184K/7473856K available (18560K kernel code, 3214K rwdata, 7140K rodata, 3904K init, 1075K bss)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x380/0x508 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000006] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.001072] Console: colour dummy device 80x25
[ 0.002977] printk: console [tty0] enabled
[ 0.003052] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.003094] pid_max: default: 32768 minimum: 301
[ 0.003354] LSM: Security Framework initializing
[ 0.003567] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.003620] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.007286] rcu: Hierarchical SRCU implementation.
[ 0.007700] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.008481] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../has
[ 0.008542] DTB Build time: May 16 2022 21:09:42
[ 0.011314] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.011764] Remapping and enabling EFI services.
[ 0.013927] smp: Bringing up secondary CPUs ...
[ 0.050668] Detected PIPT I-cache on CPU1
[ 0.050760] CPU1: Booted secondary processor 0x0000000001 [0x4e0f0040]
[ 0.080536] Detected PIPT I-cache on CPU2
[ 0.080624] CPU2: Booted secondary processor 0x0000000100 [0x4e0f0040]
[ 0.110437] Detected PIPT I-cache on CPU3
[ 0.110522] CPU3: Booted secondary processor 0x0000000101 [0x4e0f0040]
[ 0.140513] Detected PIPT I-cache on CPU4
[ 0.140603] CPU4: Booted secondary processor 0x0000000200 [0x4e0f0040]
[ 0.170583] Detected PIPT I-cache on CPU5
[ 0.170666] CPU5: Booted secondary processor 0x0000000201 [0x4e0f0040]
[ 0.171083] smp: Brought up 1 node, 6 CPUs
[ 0.171316] SMP: Total of 6 processors activated.
[ 0.171372] CPU features: detected: Privileged Access Never
[ 0.171401] CPU features: detected: LSE atomic instructions
[ 0.171419] CPU features: detected: User Access Override
[ 0.171435] CPU features: detected: 32-bit EL0 Support
[ 0.171451] CPU features: detected: RAS Extension Support
[ 0.171466] CPU features: detected: CRC32 instructions
[ 0.171482] CPU features: detected: 32-bit EL1 Support
[ 0.268023] CPU: All CPU(s) started at EL2
[ 0.274698] devtmpfs: initialized
[ 0.321952] Registered cp15_barrier emulation handler
[ 0.322071] Registered setend emulation handler
[ 0.322125] KASLR enabled
[ 0.322430] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.322467] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.324232] pinctrl core: initialized pinctrl subsystem
[ 0.325453] SMBIOS 3.0.0 present.
[ 0.325493] DMI: Unknown NVIDIA Jetson Xavier NX Developer Kit/NVIDIA Jetson Xavier NX Developer Kit, BIOS r34.1-975ee2
[ 0.326828] NET: Registered protocol family 16
[ 0.329172] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.329880] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.330932] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.331008] audit: initializing netlink subsys (disabled)
[ 0.331290] audit: type=2000 audit(0.328:1): state=initialized audit_enabled=0 res=1
[ 0.332740] printk: console [ramoops-1] enabled
[ 0.332765] pstore: Registered ramoops as persistent store backend
[ 0.332787] ramoops: using 0x200000@0xca600000, ecc: 0
[ 0.333400] thermal_sys: Registered thermal governor 'step_wise'
[ 0.333411] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.333437] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.335271] cpuidle: using governor menu
[ 0.335589] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.336110] ASID allocator initialised with 65536 entries
[ 0.336362] Serial: AMBA PL011 UART driver
[ 0.340908] Tegra reboot handler registered.
[ 0.341138] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../has
[ 0.341176] DTB Build time: May 16 2022 21:09:42
[ 0.419778] tegra19x-cbb 2300000.cbb-noc: secure_irq = 15, nonsecure_irq = 14>
[ 0.420103] tegra19x-cbb c600000.aon-noc: secure_irq = 17, nonsecure_irq = 16>
[ 0.420322] tegra19x-cbb d600000.bpmp-noc: secure_irq = 19, nonsecure_irq = 18>
[ 0.420603] tegra19x-cbb be00000.rce-noc: secure_irq = 21, nonsecure_irq = 20>
[ 0.420800] tegra19x-cbb b600000.sce-noc: secure_irq = 23, nonsecure_irq = 22>
[ 0.423492] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2c10000
[ 0.423541] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2c20000
[ 0.423599] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2c30000
[ 0.423635] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2c40000
[ 0.423691] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2c50000
[ 0.423727] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2b80000
[ 0.423762] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2b90000
[ 0.423797] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2ba0000
[ 0.423833] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2bb0000
[ 0.423868] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1700000
[ 0.423904] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1710000
[ 0.423944] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1720000
[ 0.423979] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1730000
[ 0.424013] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1740000
[ 0.424047] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1750000
[ 0.424082] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1760000
[ 0.424118] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1770000
[ 0.424230] mc-err: mcerr ops are set to t19x
[ 0.442731] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.442767] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.442789] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.442808] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.449939] ACPI: Interpreter disabled.
[ 0.451565] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.453245] iommu: Default domain type: Translated
[ 0.453345] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.453859] SCSI subsystem initialized
[ 0.454079] usbcore: registered new interface driver usbfs
[ 0.454142] usbcore: registered new interface driver hub
[ 0.454192] usbcore: registered new device driver usb
[ 0.454712] mc: Linux media interface: v0.10
[ 0.454756] videodev: Linux video capture interface: v2.00
[ 0.455178] pps_core: LinuxPPS API ver. 1 registered
[ 0.455196] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.455229] PTP clock support registered
[ 0.456275] Registered efivars operations
[ 0.456816] FPGA manager framework
[ 0.457110] Advanced Linux Sound Architecture Driver Initialized.
[ 0.457908] Bluetooth: Core ver 2.22
[ 0.457959] NET: Registered protocol family 31
[ 0.457978] Bluetooth: HCI device and connection manager initialized
[ 0.458000] Bluetooth: HCI socket layer initialized
[ 0.458019] Bluetooth: L2CAP socket layer initialized
[ 0.458046] Bluetooth: SCO socket layer initialized
[ 0.459561] camchar: rtcpu character device driver loaded
[ 0.460527] clocksource: Switched to clocksource arch_sys_counter
[ 0.854451] VFS: Disk quotas dquot_6.6.0
[ 0.854559] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.854940] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.855435] pnp: PnP ACPI: disabled
[ 0.856045] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000ce000000,704643072
[ 0.856078] nvmap_page_pool_init: Total RAM pages: 1751930
[ 0.856115] nvmap_page_pool_init: nvmap page pool size: 218991 pages (855 MB)
[ 0.856519] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.856813] misc nvmap: created heap vpr base 0x00000000ce000000 size (688128KiB)
[ 0.869309] la/ptsa driver initialized.
[ 0.869468] NET: Registered protocol family 2
[ 0.869712] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.876342] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.876461] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.876955] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.877613] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.877758] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.877961] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.878279] NET: Registered protocol family 1
[ 0.879262] RPC: Registered named UNIX socket transport module.
[ 0.879295] RPC: Registered udp transport module.
[ 0.879312] RPC: Registered tcp transport module.
[ 0.879329] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.879353] PCI: CLS 0 bytes, default 64
[ 0.879554] Trying to unpack rootfs image as initramfs...
[ 1.134766] Initramfs unpacking failed: invalid magic at start of compressed archive
[ 1.137900] Freeing initrd memory: 8196K
[ 1.143500] hw perfevents: failed to parse interrupt-affinity[6] for arm-pmu
[ 1.143544] hw perfevents: /arm-pmu: failed to register PMU devices!
[ 1.143584] armv8-pmu: probe of arm-pmu failed with error -22
[ 1.144063] kvm [1]: IPA Size Limit: 40 bits
[ 1.144636] kvm [1]: vgic interrupt IRQ9
[ 1.145199] kvm [1]: VHE mode initialized successfully
[ 1.146970] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.153616] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.154483] NFS: Registering the id_resolver key type
[ 1.154528] Key type id_resolver registered
[ 1.154545] Key type id_legacy registered
[ 1.154631] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.154657] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.154721] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.165654] NET: Registered protocol family 38
[ 1.165718] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[ 1.166055] io scheduler mq-deadline registered
[ 1.166081] io scheduler kyber registered
[ 1.172799] tegra186-dpaux-pinctrl 155f0000.dpaux: can not get clock
[ 1.175848] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.175930] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.176004] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.176106] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.176202] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.182397] scrncapt: init (heads:4 wins:6 planes:4)
[ 1.182627] tegradccommon 15200000.display-hub: Nvhost Channel map failed
[ 1.183467] EINJ: ACPI disabled.
[ 1.186418] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 1.186447] tegra-pmc: ### PMC reset source: SYS_RESET_N
[ 1.186465] tegra-pmc: ### PMC reset level: L0
[ 1.186482] tegra-pmc: ### PMC reset status reg: 0x0
[ 1.186535] tegra-pmc: PMC Prod config success
[ 1.191648] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.276035] random: fast init done
[ 1.277141] printk: console [ttyTCU0] enabled
[ 2.831134] arm-smmu 10000000.iommu: probing hardware configuration...
[ 2.835160] arm-smmu 10000000.iommu: SMMUv2 with:
[ 2.839723] arm-smmu 10000000.iommu: stage 1 translation
[ 2.845560] arm-smmu 10000000.iommu: stage 2 translation
[ 2.850970] arm-smmu 10000000.iommu: nested translation
[ 2.856055] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 2.863224] arm-smmu 10000000.iommu: 64 context banks (0 stage-2 only)
[ 2.873736] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 2.876411] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.882996] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.891043] arm-smmu 12000000.iommu: probing hardware configuration...
[ 2.896289] arm-smmu 12000000.iommu: SMMUv2 with:
[ 2.901018] arm-smmu 12000000.iommu: stage 1 translation
[ 2.906289] arm-smmu 12000000.iommu: stage 2 translation
[ 2.911949] arm-smmu 12000000.iommu: nested translation
[ 2.917117] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 2.924553] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 2.935213] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 2.937675] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.943976] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.951628] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 2.961211] tegra_profiler: version: 1.146, samples/io: 49/28
[ 2.964750] tegra_profiler: auth: init
[ 2.968969] THERMAL EST: found 3 subdevs
[ 2.972303] THERMAL EST num_resources: 0
[ 2.975951] [THERMAL EST subdev 0]
[ 2.979500] [THERMAL EST subdev 1]
[ 2.982677] [THERMAL EST subdev 2]
[ 2.986156] THERMAL EST: Found 2 profiles, default profile is quiet
[ 2.992384] THERMAL EST: thz register success.
[ 2.996619] THERMAL EST: end of probe, return err: 0
[ 3.005616] libphy: Fixed MDIO Bus: probed
[ 3.006197] tun: Universal TUN/TAP device driver, 1.6
[ 3.012133] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 3.018198] hns3: Copyright (c) 2017 Huawei Corporation.
[ 3.024036] e1000e: Intel(R) PRO/1000 Network Driver
[ 3.028936] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.034583] igb: Intel(R) Gigabit Ethernet Network Driver
[ 3.040063] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.046304] PPP generic driver version 2.4.2
[ 3.050748] PPP BSD Compression module registered
[ 3.055291] PPP Deflate Compression module registered
[ 3.060542] PPP MPPE Compression module registered
[ 3.065285] usbcore: registered new interface driver r8152
[ 3.070800] usbcore: registered new interface driver asix
[ 3.076502] usbcore: registered new interface driver ax88179_178a
[ 3.082599] usbcore: registered new interface driver cdc_ether
[ 3.088308] usbcore: registered new interface driver net1080
[ 3.093892] usbcore: registered new interface driver cdc_subset
[ 3.099932] usbcore: registered new interface driver zaurus
[ 3.105629] usbcore: registered new interface driver cdc_ncm
[ 3.111303] usbcore: registered new interface driver aqc111
[ 3.116945] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.123300] ohci-pci: OHCI PCI platform driver
[ 3.127322] ohci-platform: OHCI generic platform driver
[ 3.133150] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 3.139124] usbcore: registered new interface driver uas
[ 3.143631] usbcore: registered new interface driver usb-storage
[ 3.149723] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 3.155956] mousedev: PS/2 mouse device common for all mice
[ 3.161057] usbcore: registered new interface driver xpad
[ 3.168770] tegra_rtc c2a0000.rtc: registered as rtc1
[ 3.171515] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:25 UTC (25)
[ 3.179325] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.185783] i2c /dev entries driver
[ 3.189495] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 3.195271] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 3.204791] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 3.205829] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 3.211147] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 3.216632] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 3.222262] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 3.235582] device-mapper: uevent: version 1.0.3
[ 3.236046] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 3.241884] cpuidle: Initializing cpuidle driver
[ 3.246831] sdhci: Secure Digital Host Controller Interface driver
[ 3.251114] sdhci: Copyright(c) Pierre Ossman
[ 3.255492] Synopsys Designware Multimedia Card Interface Driver
[ 3.261721] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.267689] sdhci-tegra 3400000.sdhci: Adding to iommu group 3
[ 3.272029] pstore: ignoring unexpected backend 'efi'
[ 3.278868] SMCCC: SOC_ID: ID = jep106:036b:0019 Revision = 0x00000102
[ 3.286226] tegra-bpmp bpmp: firmware: 128431eec76692047e1ac1ebc0392266
[ 3.309057] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 3.319753] vdd-1v0: supplied by regulator-dummy
[ 3.325686] vdd-1v8-hs: supplied by regulator-dummy
[ 3.330760] vdd-1v8-ls: supplied by regulator-dummy
[ 3.335937] vdd-1v8-ao: supplied by regulator-dummy
[ 3.340177] vddio-ddr-1v1: supplied by regulator-dummy
[ 3.345350] vdd-rtc: supplied by regulator-dummy
[ 3.347492] spmic-ldo1: supplied by regulator-dummy
[ 3.349365] vdd-ao-3v3: supplied by regulator-dummy
[ 3.356169] vddio-emmc-3v3: supplied by regulator-dummy
[ 3.362840] spmic-ldo4: supplied by regulator-dummy
[ 3.364650] vdd-usb-3v3: supplied by regulator-dummy
[ 3.371601] vddio-sdmmc1-3v3: supplied by regulator-dummy
[ 3.378402] vdd-csi-1v2: supplied by vdd-1v8-ls
[ 3.384583] spmic-ldo8: supplied by vdd-1v8-ls
[ 3.386761] gpio-510 (gpio_default): hogged as output/high
[ 3.388677] gpio-511 (gpio_default): hogged as output/high
[ 3.391659] gpiochip0: registered GPIOs 504 to 511 on max77620-gpio
[ 3.528042] max77686-rtc max77620-rtc: registered as rtc0
[ 3.529464] max77620-power max20024-power: Event recorder REG_NVERC : 0x44
[ 3.529875] max77620 4-003c: max77620 probe successful
[ 4.379893] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 4.381458] hid: raw HID events driver (C) Jiri Kosina
[ 4.382411] usbcore: registered new interface driver usbhid
[ 4.382571] usbhid: USB HID core driver
[ 4.385057] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 4
[ 4.386528] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 4.467443] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 4.468201] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x10
[ 4.469943] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 4.471120] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x50
[ 4.473266] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x30
[ 4.474029] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[5120
[ 4.474661] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x0
[ 4.476429] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (49)
[ 4.476958] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.479466] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=82ae0be041c774c05e582b08ce8b33b9db5d6
[ 4.484170] tegra_aon c1a0000.aon: Adding to iommu group 5
[ 4.491716] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.495726] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.502197] denver_knobs_init:MTS_VERSION:55637613
[ 4.513369] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 4.513802] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 4.521350] t19x_cache tegra-cache: probed
[ 4.527223] optee: probing for conduit method.
[ 4.528733] optee: revision 3.13 (6f444acf)
[ 4.530331] optee: dynamic shared memory is enabled
[ 4.538137] optee: initialized driver
[ 4.544732] nvpmodel: initialized successfully
[ 4.545829] tegra_hv: get_hvd: not initialized yet
[ 4.550067] user_ivc_mempool: hypervisor not present
[ 4.556240] usbcore: registered new interface driver snd-usb-audio
[ 4.562835] u32 classifier
[ 4.563900] input device check on
[ 4.567633] Actions configured
[ 4.570795] Initializing XFRM netlink socket
[ 4.575625] NET: Registered protocol family 10
[ 4.582708] Segment Routing with IPv6
[ 4.583176] NET: Registered protocol family 17
[ 4.587512] NET: Registered protocol family 15
[ 4.591955] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_n.
[ 4.606185] Bluetooth: RFCOMM socket layer initialized
[ 4.610372] Bluetooth: RFCOMM ver 1.11
[ 4.614013] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.620114] Bluetooth: HIDP socket layer initialized
[ 4.625941] 9pnet: Installing 9P2000 support
[ 4.629540] Key type dns_resolver registered
[ 4.635144] registered taskstats version 1
[ 4.638294] pstore: Using crash dump compression: deflate
[ 4.644646] tegra194-pcie 14160000.pcie: Adding to iommu group 6
[ 4.654799] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 4.656464] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 4.664901] tegra194-pcie 14160000.pcie: MEM 0x1400000000..0x173fffffff -> 0x1400000000
[ 4.673697] tegra194-pcie 14160000.pcie: MEM 0x1740000000..0x17ffffffff -> 0x0040000000
[ 4.788551] tegra194-pcie 14160000.pcie: Link up
[ 4.791693] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 4.791998] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 4.792268] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 4.792737] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 4.793074] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 4.793554] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 4.794124] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 4.807290] pci 0004:01:00.0: [10ec:c822] type 00 class 0x028000
[ 4.807808] pci 0004:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 4.808243] pci 0004:01:00.0: reg 0x18: [mem 0x1740000000-0x174000ffff 64bit]
[ 4.809861] pci 0004:01:00.0: supports D1 D2
[ 4.810057] pci 0004:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 4.819611] pci 0004:00:00.0: BAR 14: assigned [mem 0x1740000000-0x17400fffff]
[ 4.819993] pci 0004:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 4.820340] pci 0004:01:00.0: BAR 2: assigned [mem 0x1740000000-0x174000ffff 64bit]
[ 4.820958] pci 0004:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 4.821323] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 4.821577] pci 0004:00:00.0: bridge window [io 0x1000-0x1fff]
[ 4.823335] pci 0004:00:00.0: bridge window [mem 0x1740000000-0x17400fffff]
[ 4.830799] pci 0004:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 4.839601] pci 0004:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 4.849360] pcieport 0004:00:00.0: Adding to iommu group 6
[ 4.854075] pcieport 0004:00:00.0: PME: Signaling with IRQ 24
[ 4.859504] pcieport 0004:00:00.0: AER: enabled with IRQ 24
[ 4.866700] tegra194-pcie 141a0000.pcie: Adding to iommu group 7
[ 4.875337] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 4.877295] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 4.885434] tegra194-pcie 141a0000.pcie: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 4.894174] tegra194-pcie 141a0000.pcie: MEM 0x1f40000000..0x1fffffffff -> 0x0040000000
[ 6.009310] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 6.009994] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 6.010221] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 6.010425] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 6.010782] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 6.011082] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 6.011598] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 6.012065] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 6.030550] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 6.030928] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 6.032805] pcieport 0005:00:00.0: Adding to iommu group 7
[ 6.034111] pcieport 0005:00:00.0: PME: Signaling with IRQ 26
[ 6.035884] pcieport 0005:00:00.0: AER: enabled with IRQ 26
[ 6.037859] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 6.038832] pci 0005:00:00.0: Removing from iommu group 7
[ 6.039159] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 6.068043] tegra-gpcdma 2600000.dma: Adding to iommu group 2
[ 6.072959] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 6.074002] host1x 13e10000.host1x: Adding to iommu group 8
[ 6.099523] host1x 13e10000.host1x: initialized
[ 6.101527] iommu_context_dev 13e10000.host1x:ctx0: Adding to iommu group 9
[ 6.102657] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 6.103836] iommu_context_dev 13e10000.host1x:ctx1: Adding to iommu group 10
[ 6.104812] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 6.105950] iommu_context_dev 13e10000.host1x:ctx2: Adding to iommu group 11
[ 6.106709] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 6.107779] iommu_context_dev 13e10000.host1x:ctx3: Adding to iommu group 12
[ 6.108384] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 6.115296] iommu_context_dev 13e10000.host1x:ctx4: Adding to iommu group 13
[ 6.122035] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 6.132318] iommu_context_dev 13e10000.host1x:ctx5: Adding to iommu group 14
[ 6.138957] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61, iommu=smmu.0x0000000012000000)
[ 6.149088] iommu_context_dev 13e10000.host1x:ctx6: Adding to iommu group 15
[ 6.156088] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62, iommu=smmu.0x0000000012000000)
[ 6.165768] iommu_context_dev 13e10000.host1x:ctx7: Adding to iommu group 16
[ 6.172937] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63, iommu=smmu.0x0000000012000000)
[ 6.182800] falcon 15340000.vic: Adding to iommu group 17
[ 6.197518] falcon 15340000.vic: initialized
[ 6.198649] falcon 15380000.nvjpg: Adding to iommu group 17
[ 6.204562] falcon 15380000.nvjpg: initialized
[ 6.205090] falcon 154c0000.nvenc: Adding to iommu group 17
[ 6.215803] falcon 154c0000.nvenc: initialized
[ 6.216654] falcon 15a80000.nvenc1: Adding to iommu group 17
[ 6.226039] falcon 15a80000.nvenc1: initialized
[ 6.226643] nvdec 15480000.nvdec: Adding to iommu group 17
[ 6.238730] nvdec 15480000.nvdec: initialized
[ 6.239313] nvdec 15140000.nvdec1: Adding to iommu group 17
[ 6.249420] nvdec 15140000.nvdec1: initialized
[ 6.250074] tsec 15500000.tsec: Adding to iommu group 18
[ 6.256338] tsec 15500000.tsec: initialized
[ 6.256979] tsec 15100000.tsecb: Adding to iommu group 19
[ 6.262931] tsec 15100000.tsecb: initialized
[ 6.267108] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 6.290025] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 6.301987] gpio-374 (wifi-enable): hogged as output/high
[ 6.302250] gpio-431 (camera-control-output-low): hogged as output/low
[ 6.302482] gpio-432 (camera-control-output-low): hogged as output/low
[ 6.304311] gpiochip1: registered GPIOs 335 to 503 on tegra194-gpio
[ 6.306434] gpiochip2: registered GPIOs 305 to 334 on tegra194-gpio-aon
[ 6.307234] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 6.314300] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 6.319564] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 6.325273] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 6.331011] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 6.339242] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 6.346295] tegra194-isp5 13e10000.host1x:isp@14800000: Adding to iommu group 20
[ 6.357620] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 6.363079] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: initialized
[ 6.368921] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[ 6.378040] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[ 6.387756] tegra194-vi5 15c10000.vi: Adding to iommu group 21
[ 6.394693] scare-pigeon 13e10000.host1x:vi-thi@15f00000: context isolation disabled due to no IOMMU
[ 6.402240] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 6.407944] scare-pigeon 13e10000.host1x:vi-thi@15f00000: grid-of-semaphores not supported
[ 6.416608] scare-pigeon 13e10000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 6.426167] scare-pigeon 13e10000.host1x:isp-thi@14b00000: initialized
[ 6.432385] scare-pigeon 13e10000.host1x:isp-thi@14b00000: grid-of-semaphores not supported
[ 6.440991] pva 16000000.pva0: Adding to iommu group 22
[ 6.468839] pva 16000000.pva0: initialized
[ 6.474096] pva 16800000.pva1: Adding to iommu group 23
[ 6.487887] pva 16800000.pva1: initialized
[ 6.492254] nvdla 15880000.nvdla0: Adding to iommu group 24
[ 6.506722] nvdla 15880000.nvdla0: initialized
[ 6.507942] nvdla 158c0000.nvdla1: Adding to iommu group 25
[ 6.519545] nvdla 158c0000.nvdla1: initialized
[ 6.524182] tegradc 15200000.display: Adding to iommu group 26
[ 6.524241] tegradccommon 15200000.display-hub: host1x channel mapped
[ 6.524979] tegradccommon 15200000.display-hub: dc_common syncpt # 1 allocated
[ 6.525382] tegradccommon 15200000.display-hub: dma mapping done
[ 6.525968] tegradc 15200000.display: disp0 connected to head0->sor1
[ 6.526377] generic_infoframe_type: 0x87
[ 6.526608] tegradc 15200000.display: DT parsed successfully
[ 6.526878] tegradc 15200000.display: Display dc.(____ptrval____) registered with id=0
[ 6.528241] tegradc 15210000.display: Adding to iommu group 26
[ 6.530643] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=63
[ 6.532676] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 6.532702] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[ 6.532718] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 6.533502] tegradc 15200000.display: vblank syncpt # 8 for dc 0
[ 6.533512] tegradc 15200000.display: vpulse3 syncpt # 9 for dc 0
[ 6.536971] tegradc 15200000.display: hdmi: can't get adpater for ddc bus 3
[ 6.542875] tegra_cec 3960000.tegra_cec: Unpowergated DISP
[ 6.554923] tegradc 15200000.display: out->type:1 out_ops->init err = -517
[ 6.560909] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 6.605425] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 6.607036] tegradc 15210000.display: disp0 connected to head1->sor
[ 6.610958] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 6.617284] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[ 6.622584] tegra_cec 3960000.tegra_cec: probed
[ 6.623393] kfuse 3830000.kfuse: initialized
[ 6.630430] tegradc 15210000.display: DT parsed successfully
[ 6.635513] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 6.639552] tegradc 15210000.display: Display dc.(____ptrval____) registered with id=0
[ 6.645165] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 6.645831] serial-tegra 3100000.serial: Adding to iommu group 2
[ 6.653598] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 6.660171] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 31, base_baud = 0) is a TEGRA_UART
[ 6.666022] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[ 6.666028] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 6.667000] tegradc 15210000.display: vblank syncpt # 11 for dc 1
[ 6.673853] serial-tegra 3110000.serial: Adding to iommu group 2
[ 6.680398] tegradc 15210000.display: vpulse3 syncpt # 12 for dc 1
[ 6.690063] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 32, base_baud = 0) is a TEGRA_UART
[ 6.715215] tegradc 15210000.display: probed
[ 6.719568] serial-tegra 3140000.serial: Adding to iommu group 2
[ 6.743499] Console: switching to colour frame buffer device 80x30
[ 6.743975] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 33, base_baud = 0) is a TEGRA_UART
[ 6.749167] tegradc 15210000.display: fb registered
[ 6.768678] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 6.769825] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 6.770712] tegra-xusb 3610000.xhci: Firmware timestamp: 2020-09-11 16:55:03 UTC, Version: 60.09 release
[ 6.777617] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 6.787292] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 6.787352] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 6.805656] tegradc 15210000.display: blank - powerdown
[ 6.806390] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x0000000000050810
[ 6.811038] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 6.820576] tegra-xusb 3610000.xhci: irq 187, io mem 0x03610000
[ 6.828302] Extcon DP: HPD disabled
[ 6.835270] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 6.838011] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 6.838035] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 6.846443] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.853235] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 6.873497] usb usb1: Product: xHCI Host Controller
[ 6.878421] usb usb1: Manufacturer: Linux 5.10.65-tegra xhci-hcd
[ 6.884247] usb usb1: SerialNumber: 3610000.xhci
[ 6.890122] hub 1-0:1.0: USB hub found
[ 6.892864] hub 1-0:1.0: 4 ports detected
[ 6.897982] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 6.902689] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 6.910114] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 6.917539] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 6.925542] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.932827] usb usb2: Product: xHCI Host Controller
[ 6.937489] usb usb2: Manufacturer: Linux 5.10.65-tegra xhci-hcd
[ 6.943606] usb usb2: SerialNumber: 3610000.xhci
[ 6.948894] hub 2-0:1.0: USB hub found
[ 6.951960] hub 2-0:1.0: 4 ports detected
[ 6.990389] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 6.996878] imx219 9-0010: ------------ 20220614-01 --------
[ 6.997126] imx219 9-0010: probing v4l2 sensor at addr 0x10
[ 6.997331] imx219 9-0010: ---------------------------------
[ 6.998151] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 7.015273] tegra-camrtc-capture-vi tegra-capture-vi: subdev imx219 9-0010 bound
[ 7.018394] i2c i2c-2: Added multiplexed i2c bus 9
[ 7.019926] imx219 10-0010: ------------ 20220614-01 --------
[ 7.020137] imx219 10-0010: probing v4l2 sensor at addr 0x10
[ 7.020337] imx219 10-0010: ---------------------------------
[ 7.021141] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 7.032589] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 7.038193] imx219 10-0010: board setup failed
[ 7.038526] imx219: probe of 10-0010 failed with error -121
[ 7.038835] i2c i2c-2: Added multiplexed i2c bus 10
[ 7.042559] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 7.063097] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1305000 KHz, changing to: 1344000 KHz
[ 7.065810] irq: IRQ254: trimming hierarchy from :pmc@c360000
[ 7.066177] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 7.066279] usb-conn-gpio 3520000.xusb_padctl:ports:usb2-0:connector: repeated role: 0
[ 7.070352] sdhci-tegra 3400000.sdhci: BWMGR client registration for eMC Successful
[ 7.079048] tegra194-isp5 13e10000.host1x:isp@14800000: initialized
[ 7.095042] irq: IRQ255: trimming hierarchy from :pmc@c360000
[ 7.096908] tegra194-vi5 15c10000.vi: initialized
[ 7.098199] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 255
[ 7.103543] tegradc 15200000.display: disp1 connected to head0->sor1
[ 7.110231] nvethernet 2490000.ethernet: Adding to iommu group 27
[ 7.115642] generic_infoframe_type: 0x87
[ 7.121881] nvethernet 2490000.ethernet: failed to read skip mac reset flag, default 0
[ 7.125635] tegradc 15200000.display: DT parsed successfully
[ 7.133576] nvethernet 2490000.ethernet: failed to read MDIO address
[ 7.133588] nvethernet 2490000.ethernet: setting to default DMA bit mask
[ 7.139204] tegradc 15200000.display: Display dc.(____ptrval____) registered with id=1
[ 7.144689] mmc0: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 7.145538] nvethernet 2490000.ethernet: set default TXQ to TC mapping
[ 7.145546] nvethernet 2490000.ethernet: Setting default PTP RX queue
[ 7.152613] tegradc 15200000.display: vblank syncpt # 13 for dc 0
[ 7.160485] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 7.168513] tegradc 15200000.display: vpulse3 syncpt # 14 for dc 0
[ 7.168518] nvethernet 2490000.ethernet: failed to get eqos_rx_m clk
[ 7.168528] nvethernet 2490000.ethernet: failed to get eqos_rx_input clk
[ 7.168534] nvethernet 2490000.ethernet: failed to get eqos_tx_divider clk
[ 7.169760] nvethernet 2490000.ethernet: Ethernet MAC address: 48:b0:2d:2f:93:6d
[ 7.169806] -->macsec_probe()
[ 7.169812] <--macsec_probe()
[ 7.169815] nvethernet 2490000.ethernet: Macsec not supported
[ 7.170972] nvethernet 2490000.ethernet: eth0 (HW ver: 50) created with 1 DMA channels
[ 7.171951] irq: IRQ257: trimming hierarchy from :pmc@c360000
[ 7.172023] irq: IRQ258: trimming hierarchy from :interrupt-controller@3881000
[ 7.172139] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 7.173075] tegra-se-nvhost 15810000.se: Adding to iommu group 28
[ 7.174580] tegra-se-nvhost 15810000.se: initialized
[ 7.179969] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 7.182590] tegradc 15200000.display: hdmi: invalid prod list prod_list_hdmi_board
[ 7.187898] tegra-se-nvhost 15820000.se: Adding to iommu group 29
[ 7.194042] tegradc 15200000.display: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 7.220368] tegra-se-nvhost 15820000.se: initialized
[ 7.261417] tegradc 15200000.display: probed
[ 7.263471] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 7.310030] mmc0: host does not support reading read-only switch, assuming write-enable
[ 7.315950] tegra-se-nvhost 15830000.se: Adding to iommu group 30
[ 7.329792] tegradc 15200000.display: fb registered
[ 7.330441] tegra-se-nvhost 15830000.se: initialized
[ 7.334378] irq: IRQ259: trimming hierarchy from :pmc@c360000
[ 7.340844] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 7.342864] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489, bcdDevice= 1.40
[ 7.342871] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.342879] usb 1-2: Product: 4-Port USB 2.0 Hub
[ 7.342885] usb 1-2: Manufacturer: Generic
[ 7.344649] hub 1-2:1.0: USB hub found
[ 7.346790] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 7.351505] hub 1-2:1.0: 4 ports detected
[ 7.351901] tegra-se-nvhost 15840000.se: Adding to iommu group 31
[ 7.359757] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 7.366735] tegra-se-nvhost 15840000.se: initialized
[ 7.378270] tegradc 15200000.display: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 7.381504] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 7.387363] tegradc 15200000.display: hdmi: get YCC quant from EDID.
[ 7.390659] tegra_actmon d230000.actmon: in actmon_register()...
[ 7.399714] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 7.406694] tegra_actmon d230000.actmon: bwmgr_disable = 0
[ 7.415570] Extcon AUX1(HDMI) enable
[ 7.428366] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 7.458691] hvc_sysfs: hypervisor is not present
[ 7.473390] usb 2-3: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[ 7.485268] ALSA device list:
[ 7.485375] No soundcards found.
[ 7.486627] Freeing unused kernel memory: 3904K
[ 7.486829] Run /init as init process
[ 7.486926] with arguments:
[ 7.486930] /init
[ 7.486933] nv-auto-config
[ 7.486936] with environment:
[ 7.486939] HOME=/
[ 7.486942] TERM=linux
[ 7.509922] usb 2-3: New USB device found, idVendor=0bda, idProduct=0489, bcdDevice= 1.40
[ 7.510154] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.510357] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 7.510475] usb 2-3: Manufacturer: Generic
[ 7.521074] hub 2-3:1.0: USB hub found
[ 7.523079] hub 2-3:1.0: 4 ports detected
[ 7.534659] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[ 7.535390] mmcblk0: mmc0:aaaa SC64G 59.5 GiB
[ 7.536751] Root device found: mmcblk0p1
[ 7.542882] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19
[ 7.567832] tegradc 15200000.display: blank - powerdown
[ 7.612553] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 7.612558] Extcon AUX1(HDMI) disable
[ 7.616507] tegra_cec 3960000.tegra_cec: Can't find physical addresse.
[ 7.616532] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 7.628516] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 7.635608] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 7.636541] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 7.682898] tegradc 15200000.display: unblank
[ 7.684239] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 7.684428] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 7.689417] tegradc 15200000.display: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 7.690934] tegradc 15200000.display: hdmi: get YCC quant from EDID.
[ 7.695022] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 7.695026] Extcon AUX1(HDMI) enable
[ 7.707682] tegradc 15200000.display: sync windows ret = 247
[ 7.711772] extcon-disp-state external-connection:disp-state: cable 53 state 1
[ 7.719035] Extcon HDMI: HPD enabled
[ 7.722958] tegradc 15200000.display: hdmi: plugged
[ 7.745601] Found dev node: /dev/mmcblk0p1
[ 7.777736] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[ 7.777981] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 7.778176] usb 1-3: Product: Bluetooth Radio
[ 7.778329] usb 1-3: Manufacturer: Realtek
[ 7.778445] usb 1-3: SerialNumber: 00e04c000001
[ 7.807871] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.811518] Rootfs mounted over mmcblk0p1
[ 7.853875] Switching from initrd to actual rootfs
[ 8.088572] usb 1-2.3: new full-speed USB device number 4 using tegra-xusb
[ 8.143361] systemd[1]: System time before build time, advancing clock.
[ 8.178516] x_tables: disagrees about version of symbol module_layout
[ 8.194180] usb 1-2.3: New USB device found, idVendor=248a, idProduct=8367, bcdDevice= 1.00
[ 8.194388] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.194546] usb 1-2.3: Product: Wireless Receiver
[ 8.194651] usb 1-2.3: Manufacturer: Telink
[ 8.201524] input: Telink Wireless Receiver Mouse as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/0003:248A1
[ 8.202210] input: Telink Wireless Receiver Consumer Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.2
[ 8.219638] systemd[1]: systemd 245.4-4ubuntu3.17 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK )
[ 8.221748] systemd[1]: Detected architecture arm64.
[ 8.256590] systemd[1]: Set hostname to <ubuntu>.
[ 8.260698] input: Telink Wireless Receiver System Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/3
[ 8.261130] hid-generic 0003:248A:8367.0001: input,hidraw0: USB HID v1.11 Mouse [Telink Wireless Receiver] on usb-36100
[ 8.264276] input: Telink Wireless Receiver as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.1/0003:248A:8367.4
[ 8.324843] hid-generic 0003:248A:8367.0002: input,hidraw1: USB HID v1.11 Keyboard [Telink Wireless Receiver] on usb-31
[ 8.800377] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.800775] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support B.
[ 8.801043] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 8.805225] systemd[1]: Created slice system-modprobe.slice.
[ 8.805976] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.807459] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 8.807819] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.809359] systemd[1]: Created slice User and Session Slice.
[ 8.810039] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 8.811187] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 8.811748] systemd[1]: Reached target User and Group Name Lookups.
[ 8.812159] systemd[1]: Reached target Slices.
[ 8.812562] systemd[1]: Reached target Swap.
[ 8.813505] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 8.813711] random: crng init done
[ 8.813720] random: 6 urandom warning(s) missed due to ratelimiting
[ 8.817044] systemd[1]: Listening on Syslog Socket.
[ 8.821826] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 8.828507] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 8.835474] systemd[1]: Listening on Journal Audit Socket.
[ 8.840237] systemd[1]: Listening on Journal Socket (/dev/log).
[ 8.846768] systemd[1]: Listening on Journal Socket.
[ 8.851810] systemd[1]: Listening on udev Control Socket.
[ 8.856958] systemd[1]: Listening on udev Kernel Socket.
[ 8.866962] systemd[1]: Mounting Huge Pages File System...
[ 8.872200] systemd[1]: Mounting POSIX Message Queue File System...
[ 8.878450] systemd[1]: Mounting RPC Pipe File System...
[ 8.884121] systemd[1]: Mounting Kernel Debug File System...
[ 8.889978] systemd[1]: Mounting Kernel Trace File System...
[ 8.896373] systemd[1]: Starting Journal Service...
[ 8.901781] systemd[1]: Starting Set the console keyboard layout...
[ 8.906657] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 8.911002] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 8.923335] systemd[1]: Started Nameserver information manager.
[ 8.925615] systemd[1]: Reached target Network (Pre).
[ 8.932382] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 8.939130] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 8.945019] systemd[1]: Starting Load Kernel Modules...
[ 8.958765] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 8.965079] systemd[1]: Starting udev Coldplug all Devices...
[ 8.973005] systemd[1]: Mounted Huge Pages File System.
[ 8.973849] systemd[1]: Mounted POSIX Message Queue File System.
[ 8.977636] systemd[1]: Mounted RPC Pipe File System.
[ 8.982047] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 8.990593] systemd[1]: Mounted Kernel Debug File System.
[ 8.993272] systemd[1]: Mounted Kernel Trace File System.
[ 9.001056] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 9.008947] ina3221: disagrees about version of symbol module_layout
[ 9.012516] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 9.025026] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 9.027928] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 9.042053] systemd[1]: Starting Load/Save Random Seed...
[ 9.048226] systemd[1]: Starting Create System Users...
[ 9.084668] nvgpu: disagrees about version of symbol module_layout
[ 9.088149] systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
[ 9.089322] systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
[ 9.092437] systemd[1]: Failed to start Load Kernel Modules.
[ 9.093883] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 9.098208] systemd[1]: Mounting Kernel Configuration File System...
[ 9.103091] systemd[1]: Started OP-TEE Client Supplicant.
[ 9.109820] systemd[1]: Starting Apply Kernel Variables...
[ 9.114098] systemd[1]: Mounted Kernel Configuration File System.
[ 9.135917] systemd[1]: Finished Load/Save Random Seed.
[ 9.142399] systemd[1]: Finished Create System Users.
[ 9.147422] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 9.169822] systemd[1]: Finished Apply Kernel Variables.
[ 9.173527] systemd[1]: Finished Set the console keyboard layout.
[ 9.191694] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 9.192623] systemd[1]: Reached target Local File Systems (Pre).
[ 9.192851] systemd[1]: Reached target Local File Systems.
[ 9.193140] systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
[ 9.197335] systemd[1]: Starting Enable support for additional executable binary formats...
[ 9.201891] systemd[1]: Starting Set console font and keymap...
[ 9.206517] systemd[1]: Starting Preprocess NFS configuration...
[ 9.212018] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[ 9.212360] systemd[1]: Condition check resulted in Load AppArmor profiles managed internally by snapd being skipped.
[ 9.212686] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[ 9.212874] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[ 9.219171] systemd[1]: Starting udev Kernel Device Manager...
[ 9.223417] systemd[1]: Finished Set console font and keymap.
[ 9.225289] systemd[1]: nfs-config.service: Succeeded.
[ 9.227486] systemd[1]: Finished Preprocess NFS configuration.
[ 9.228262] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, trigger)
[ 9.232162] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ 9.232744] systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
[ 9.232983] systemd[1]: Reached target NFS client services.
[ 9.233974] systemd[1]: Started Journal Service.
[ 9.252762] binfmt_misc: disagrees about version of symbol module_layout
[ 9.266595] systemd-journald[253]: Received client request to flush runtime journal.
[ 9.268126] binfmt_misc: disagrees about version of symbol module_layout
[ 10.154639] using random self ethernet address
[ 10.154787] using random host ethernet address
[ 10.259640] loop: disagrees about version of symbol module_layout
[ 10.297856] nvgpu: disagrees about version of symbol module_layout
[ 10.572720] spi_tegra114: disagrees about version of symbol module_layout
[ 10.573122] spi_tegra114: disagrees about version of symbol module_layout
[ 10.573306] spi_tegra210_qspi: disagrees about version of symbol module_layout
[ 10.595642] snd_hda_core: disagrees about version of symbol module_layout
[ 10.596085] snd_hda_core: disagrees about version of symbol module_layout
[ 10.620559] tegra210_adma: disagrees about version of symbol module_layout
[ 10.620951] tegra210_adma: disagrees about version of symbol module_layout
[ 10.631327] snd_soc_tegra210_ahub: disagrees about version of symbol module_layout
[ 10.642213] userspace_alert: disagrees about version of symbol module_layout
[ 10.644889] nv_imx219: disagrees about version of symbol module_layout
[ 10.659500] nv_imx219: disagrees about version of symbol module_layout
[ 10.700754] nvadsp: disagrees about version of symbol module_layout
[ 10.707802] ina3221: disagrees about version of symbol module_layout
[ 10.736385] userspace_alert: disagrees about version of symbol module_layout
[ 10.739075] cfg80211: disagrees about version of symbol module_layout
[ 10.745752] tegra_bpmp_thermal: disagrees about version of symbol module_layout
[ 10.751195] max77620_thermal: disagrees about version of symbol module_layout
[ 10.938807] userspace_alert: disagrees about version of symbol module_layout
[ 10.964236] userspace_alert: disagrees about version of symbol module_layout
[ 10.988708] leds_gpio: disagrees about version of symbol module_layout
[ 10.990085] pwm_fan: disagrees about version of symbol module_layout
[ 11.065169] snd_soc_simple_card_utils: disagrees about version of symbol module_layout
[ 11.116660] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 11.116664] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 11.116702] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 11.116801] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 11.116920] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 11.117064] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 11.117414] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 11.117703] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 11.118093] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 11.118156] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 11.118615] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 11.118642] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 11.118794] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 11.119003] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 11.176843] sha1_ce: disagrees about version of symbol module_layout
[ 11.177821] sha1_ce: disagrees about version of symbol module_layout
[ 11.181054] sha256_arm64: disagrees about version of symbol module_layout
[ 11.181748] tegra_udrm: disagrees about version of symbol module_layout
[ 11.182220] sha1_ce: disagrees about version of symbol module_layout
[ 11.182711] sha256_arm64: disagrees about version of symbol module_layout
[ 11.182714] ghash_ce: disagrees about version of symbol module_layout
[ 11.183275] ghash_ce: disagrees about version of symbol module_layout
[ 11.183533] aes_ce_cipher: disagrees about version of symbol module_layout
[ 11.183689] aes_ce_cipher: disagrees about version of symbol module_layout
[ 11.188149] sha256_arm64: disagrees about version of symbol module_layout
[ 11.188703] aes_ce_cipher: disagrees about version of symbol module_layout
[ 11.197685] sha1_ce: disagrees about version of symbol module_layout
[ 11.208694] sha1_ce: disagrees about version of symbol module_layout
[ 11.226700] sha1_ce: disagrees about version of symbol module_layout
[ 11.227187] sha256_arm64: disagrees about version of symbol module_layout
[ 11.241443] ghash_ce: disagrees about version of symbol module_layout
[ 11.241921] aes_ce_cipher: disagrees about version of symbol module_layout
[ 11.246633] aes_ce_cipher: disagrees about version of symbol module_layout
[ 11.260881] sha256_arm64: disagrees about version of symbol module_layout
[ 11.261284] ghash_ce: disagrees about version of symbol module_layout
[ 11.265638] aes_ce_cipher: disagrees about version of symbol module_layout
[ 11.277799] sha256_arm64: disagrees about version of symbol module_layout
[ 11.279903] ghash_ce: disagrees about version of symbol module_layout
[ 11.286037] aes_ce_cipher: disagrees about version of symbol module_layout
[ 11.289734] ghash_ce: disagrees about version of symbol module_layout
[ 11.297144] aes_ce_cipher: disagrees about version of symbol module_layout
[ 11.300620] btintel: disagrees about version of symbol module_layout
[ 11.309535] aes_ce_cipher: disagrees about version of symbol module_layout
[ 11.310961] btintel: disagrees about version of symbol module_layout
[ 11.311098] btintel: disagrees about version of symbol module_layout
[ 11.317020] btintel: disagrees about version of symbol module_layout
[ 11.320970] rtk_btusb: disagrees about version of symbol module_layout
[ 11.322036] aes_ce_cipher: disagrees about version of symbol module_layout
[ 11.322498] aes_ce_cipher: disagrees about version of symbol module_layout
[ 11.322715] aes_ce_cipher: disagrees about version of symbol module_layout
[ 11.328555] rtk_btusb: disagrees about version of symbol module_layout
[ 11.532519] input_leds: disagrees about version of symbol module_layout
[ 11.556173] loop: disagrees about version of symbol module_layout
[ 18.534295] libphy: nvethernet_mdio_bus: probed
[ 21.527713] overlay: disagrees about version of symbol module_layout
[ 21.629438] zram: disagrees about version of symbol module_layout
[ 22.688825] nvethernet 2490000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 22.688877] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 23.746227] overlay: disagrees about version of symbol module_layout
[ 26.181120] overlay: disagrees about version of symbol module_layout
[ 28.630511] overlay: disagrees about version of symbol module_layout
[ 33.401811] tegradc 15210000.display: blank - powerdown
[ 33.585448] fuse: disagrees about version of symbol module_layout
[ 37.857085] vdd-1v8-sd: disabling
[ 37.857179] vdd-3v3-cvb: disabling
[ 37.857220] vdd-1v8-cvb: disabling
[ 37.857255] vdd-epb-1v0: disabling
[ 37.857289] vdd-fan: disabling
[ 37.857327] vdd_sys_en: disabling
[ 37.857386] avdd-cam-2v8: disabling
[ 190.308819] fuse: disagrees about version of symbol module_layout
Here is other related info:
$ cat /etc/nv_tegra_release
# R34 (release), REVISION: 1.1, GCID: 30414990, BOARD: t186ref, EABI: aarch64, DATE: Tue May 17 04:20:55 UTC 2022
$ uname –a
Linux ubuntu 5.10.65-tegra #2 SMP PREEMPT Tue Jun 14 11:40:53 PDT 2022 aarch64 aarch64 aarch64 GNU/Linux
$ modinfo nvgpu
filename: /lib/modules/5.10.65-tegra/kernel/drivers/gpu/nvgpu/nvgpu.ko
license: GPL v2
alias: of:N*T*Cnvidia,ga10b-vgpuC*
alias: of:N*T*Cnvidia,ga10bC*
alias: of:N*T*Cnvidia,gv11b-vgpuC*
alias: of:N*T*Cnvidia,gv11bC*
alias: of:N*T*Cnvidia,tegra210-gm20bC*
depends:
intree: Y
vermagic: 5.10.65-tegra SMP preempt mod_unload modversions aarch64
$ lsmod
Module Size Used by
(no item list)
I can log in through UART terminal, but no display as nvgpu does not load correctly.
Please help have a look and advise.
Thanks,
hal.
