Error downloading Components SDK version 2.2.0.12028 to flash/install onto nvme drive
Trying to setup my new Jetson Orin Nano. I have a 22.04LTS UB VM with the USB port passed to it. SDK See’s the DEV board in Recovery Mode.
Here is the error I get
VM has no FW turned on or does the host… ATM I am not sure what’s causing the errors
For Shits and Giggles same error with 20.04 as well.
The VM is not supported by SDK manager/JetPack, please have a native Ubuntu host mechine to flash your device.
Installed 22.04 on a Dell Laptop. Same error. To rule out my home network I tried my hotspot from my phone and received the same error
There is a “EXPORT LOGS” button in your sdkmanager GUI. Use it to share out the full log but not such screenshot.
Your screenshot does not provide much information. Also, it is telling error to install CUDA to your host. In brief, it has nothing to do with your Jetson. Jetson is not using the CUDA on your host…
As the software on host does not matter to us, you could select and skip the installation on the host too.
Its not just me. Something Borked on the backend
Yes, maybe something wrong in the backend but you should share out your log too. but not just a screenshot.
I will get you the logs shortly.
SDKM_logs_JetPack_6.1_(rev._1)Linux_for_Jetson_Orin_Nano[8GB_developer_kit_version]_2024-12-30_19-50-36.zip|attachment (128.3 KB)
SDKM_logs_2024-12-30_19-56-26.zip (159.1 KB)
The SDK manager server issue has been fixed, is this still an issue in your side? Any result can be shared?
