error during deserializing deconvolution layer with INT8
I have got this error when deserializing my INT8 plan file.
I tried to find cudnnSerializationUtils.h but it does not exist.
cudnnSerializationUtils.h:67: const T& nvinfer1::cudnn::extractBlobs(const ifb::LayerParams&) [with T = ifb::CaskDeconvolutionBlobs; ifb::BlobsUnion tag = (ifb::BlobsUnion)5u]: Assertion `x == tag’ failed.
my Deconovolution parameter is
(Caffe)
kernel_size : 2
stride : 2
pad : 0
bias true
Environment :
NVIDIA drive px2(AutoChauffeur)
DGPU
cuda 9.0
cudnn 7.1.2
tensorrt 4.1.1(?)
can you try TensorRT 5RC? and see if this problem still persists?
@NVES
Thanks for reply.
I implemented custom deconvolution plugin layer and the error disappeared.
(It is cudnn based so I think the logic is same as the built-in)
But I wonder why inference and int8 converting memory access different.
First I implemented my last layer as custom plugin layer using host memory for some outputs.
But when I convert the model to INT8, that must use device memory so I have two streams, one device memory code for coverting, one host memory code for inference.
how do you deal with this problem?
could you share you code ?
thanks
