Hi Experts
I am using the script:
https://gist.github.com/dusty-nv/ef2b372301c00c0a9d3203e42fd83426
with the pip3.
When I run:
python3 setup.py build_deps
I get the error message below. Any hints?
[ 11%] Building CXX object c10/CMakeFiles/c10.dir/DeviceType.cpp.o
In file included from /home/nvidia/pytorch/third_party/ideep/mkl-dnn/src/cpu/jit_generator.hpp:35:0,
from /home/nvidia/pytorch/third_party/ideep/mkl-dnn/src/cpu/cpu_barrier.hpp:22,
from /home/nvidia/pytorch/third_party/ideep/mkl-dnn/src/cpu/cpu_reducer.hpp:28,
from /home/nvidia/pytorch/third_party/ideep/mkl-dnn/src/cpu/jit_sse42_1x1_convolution.hpp:23,
from /home/nvidia/pytorch/third_party/ideep/mkl-dnn/src/cpu/jit_sse42_1x1_convolution.cpp:20:
/home/nvidia/pytorch/third_party/ideep/mkl-dnn/src/cpu/xbyak/xbyak_util.h:84:21: fatal error: cpuid.h: No such file or directory
compilation terminated.
We recently found there are some issues in this script due to pytorch source update.
You can try this script:
https://github.com/Bfzanchetta/DLARM/blob/master/jetsontx2/pytorch_install.sh
Hi AastaLLL
When I run the above script I get:
sudo alien ninja-1.8.2-3.mga7.aarch64.rpm
warning: ninja-1.8.2-3.mga7.aarch64.rpm: Header V4 RSA/SHA256 Signature, key ID 80420f66: NOKEY
This is after the wget…
Any hints…
Thanks again…
Sojohans
Hi AAstaLLL
Thanks…
When I do as above I get:
sudo dpkg -i ninja_1.8.2-4_arm64.deb
dpkg: error processing archive ninja_1.8.2-4_arm64.deb (–install):
cannot access archive: No such file or directory
Errors were encountered while processing:
Any hints?
sojohans
The error shows that it cannot find the ninja package.
Have you executed this command when running the script?
wget https://rpmfind.net/linux/mageia/distrib/cauldron/aarch64/media/core/release/ninja-1.8.2-3.mga7.aarch64.rpm
Is there any error when downloading the ninja package?
Hi AastaLLL
No there were no errors when I downloaded the package…
Thanks,
sojohans
So you should already download the .deb file, right?
Then you can pass the correct path for error in comment #5.
If you still have issues in installing ninja, you can try this command:
$ pip install ninja --user
Hi AastaLLL
I have the ninja-1.8.2-3.mga7,aarch64.rpm file.
By the way I updated my cmake to 3.12. and also tried to run
pip3 install ninja --user
but that also gave an error.
In addition I have the following folders:
ninja-1.8.2 and ninja-1.8.2.orig
ninja-1.8.2-3.mga.7.aarch64
Happy thanksgivning,
sojohans
It looks like ninja for python3 has some issue.
Could you check if this page helps?
[url]http://arm.ninja/[/url]
Hi AastaLLL
Thanks again. This is a bit too technical for me…
I will wait to somebody makes a new script for installing pytorch on tx2.
Sojohans
Hi AastaLLL
The script by Singularity worked.
Thanks,
sojohans
