Hi ,
I using deepstream 6.3 and I created a Docker container using the test1 image from NVIDIA, but I encountered this error when trying to run the image. How can I resolve this problem?
docker run --gpus all -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY deepstream_test1_dgpu
2024-12-17 11:30:27.970 INFO gxf/gxe/gxe.cpp@182: Creating context
2024-12-17 11:30:28.086 INFO gxf/gxe/gxe.cpp@107: Loading app: ‘deepstream-test1.yaml’
2024-12-17 11:30:28.086 INFO gxf/std/yaml_file_loader.cpp@170: Loading GXF entities from YAML file ‘deepstream-test1.yaml’…
2024-12-17 11:30:28.088 INFO gxf/gxe/gxe.cpp@107: Loading app: ‘parameters.yaml’
2024-12-17 11:30:28.088 INFO gxf/std/yaml_file_loader.cpp@170: Loading GXF entities from YAML file ‘parameters.yaml’…
2024-12-17 11:30:28.088 INFO gxf/gxe/gxe.cpp@259: Initializing…
(gst-plugin-scanner:19): GStreamer-WARNING **: 11:30:28.166: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:19): GStreamer-WARNING **: 11:30:28.200: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpeg2enc.so’: libmpeg2encpp-2.1.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:19): GStreamer-WARNING **: 11:30:28.204: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstchromaprint.so’: libavcodec.so.58: cannot open shared object file: No such file or directory
(gst-plugin-scanner:19): GStreamer-WARNING **: 11:30:28.214: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstopenmpt.so’: libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:19): GStreamer-WARNING **: 11:30:28.238: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpg123.so’: libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:19): GStreamer-WARNING **: 11:30:28.258: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpeg2dec.so’: libmpeg2.so.0: cannot open shared object file: No such file or directory
2024-12-17 11:30:28.321 INFO extensions/nvdsbase/nvds_scheduler.cpp@270: This program is linked against GStreamer 1.16.3
2024-12-17 11:30:28.322 INFO extensions/nvdssource/nvurisrcbin.hpp@24: initialize: nvurisrcbin single_source_input
2024-12-17 11:30:28.323 INFO extensions/nvdsmuxdemux/nvstreammux.hpp@27: initialize: nvstreammux streammux
2024-12-17 11:30:28.323 INFO extensions/nvdsinference/nvinferbin.hpp@24: initialize: nvinferbin object_detector
2024-12-17 11:30:28.323 INFO extensions/nvdsvisualization/nvosdbin.hpp@24: initialize: nvosdbin onscreen_display
2024-12-17 11:30:28.323 INFO extensions/nvdsoutputsink/nvvideorenderersinkbin.hpp@24: initialize: nvvideorenderersinkbin video_renderer
2024-12-17 11:30:28.324 INFO gxf/gxe/gxe.cpp@266: Running…
2024-12-17 11:30:28.324 INFO extensions/nvdsbase/nvds_scheduler.cpp@121: Scheduling 5 elements and 1 components
2024-12-17 11:30:28.324 INFO extensions/nvdssource/nvurisrcbin.hpp@32: create_element: nvurisrcbin single_source_input
2024-12-17 11:30:28.376 INFO extensions/nvdssource/nvurisrcbin.hpp@56: bin_add: nvurisrcbin single_source_input
2024-12-17 11:30:28.376 INFO extensions/nvdsmuxdemux/nvstreammux.hpp@37: create_element: nvstreammux streammux
2024-12-17 11:30:28.376 INFO extensions/nvdsmuxdemux/nvstreammux.hpp@61: bin_add: nvstreammux streammux
2024-12-17 11:30:28.376 INFO extensions/nvdsinference/nvinferbin.hpp@32: create_element: nvinferbin object_detector
2024-12-17 11:30:28.377 INFO extensions/nvdsinference/nvinferbin.hpp@56: bin_add: nvinferbin object_detector
2024-12-17 11:30:28.377 INFO extensions/nvdsvisualization/nvosdbin.hpp@32: create_element: nvosdbin onscreen_display
2024-12-17 11:30:28.378 INFO extensions/nvdsvisualization/nvosdbin.hpp@56: bin_add: nvosdbin onscreen_display
2024-12-17 11:30:28.378 INFO extensions/nvdsoutputsink/nvvideorenderersinkbin.hpp@32: create_element: nvvideorenderersinkbin video_renderer
2024-12-17 11:30:28.378 INFO extensions/nvdsoutputsink/nvvideorenderersinkbin.hpp@54: bin_add: nvvideorenderersinkbin video_renderer
2024-12-17 11:30:28.434 ERROR extensions/nvdsbase/nvds_scheduler.cpp@184: Failed to set GStreamer pipeline to PLAYING
Returned, stopping playback
Deleting pipeline
