In the following cuda program, a (device))function is called which is defined in another source file. During compilation it gives following error:
Error: External calls are not supported (found non-inlined call to _Z5func2P4RootPi)
Following is the complete program source files:
# cat func.h
typedef struct Root
int a;
float f;
__device__ void func2(struct Root *root_d, int *x);
# cat func2.cu
#include "func.h"
root_d->a=root_d->a + 10;
root_d->f = root_d->f + 10.0;
*x=root_d->a;
*x = *x +10;
# cat func_multi.cu
#include<stdio.h>
#include<cuda.h>
#include "func.h"
__global__ void func1(struct Root *root_d)
int *x;
func2(root_d, x);
void func3( struct Root *root_d)
func1<<<1,1>>>(root_d);
int main()
struct Root *root, *root_d;
root= (Root *) malloc(1*sizeof(Root));
root->a=10;
root->f=11.11;
cudaMalloc((void **)&root_d, 1*sizeof(Root));
cudaMemcpy(root_d, root, 1*sizeof(Root), cudaMemcpyHostToDevice);
func3(root_d);
cudaMemcpy(root, root_d, 1*sizeof(Root), cudaMemcpyDeviceToHost);
printf("\n AFTER COMPLETE ITERATIONS : \n a = %d \t f = %f \n ", root->a, root->f);
return 0;
The compilation it throws following error:
# nvcc -arch sm_20 func_multi.cu func2.cu -o func2_multi
func.h(7): warning: declaration requires a typedef name
func_multi.cu(30): warning: variable "x" is used before its value is set
func_multi.cu(30): warning: variable "__cuda_local_var_39372_6_non_const_x" is used before its value is set
./func_multi.cu(30): Error: External calls are not supported (found non-inlined call to _Z5func2P4RootPi)
The GPU device is: Tesla C2050 and cuda version is:
nvcc --version
nvcc: NVIDIA ® Cuda compiler driver
Copyright © 2005-2011 NVIDIA Corporation
Built on Thu_May_12_11:09:45_PDT_2011
Cuda compilation tools, release 4.0, V0.2.1221
Is there anything wrong in compilation? How to compile it?
