Hi kayccc,
I have not yet been able to flash the Xavier. I have even gone so far as to try from a different host PC running Ubuntu as well. With both host PC’s, I get the connection lost error and the process errors out.
Hi kayccc,
Just to confirm, did you see lsusb gives out a device with “NVIDIA Corp” after put device into recovery mode?
Hello, I have the same problem like described above ( Ubuntu 18.04.2).
Nothing helps. Flashing Jetson OS stops on about 7% of total flashing progress with errors.
Regarding to question i can see in logs lusb “NVIDIA Corp” in commands after put device in recovery mode.
First received ERROR:
09:40:12 DEBUG : running command < lsusb | grep " NVIDIA Corp" >
09:40:12 INFO : Bus 003 Device 008: ID 0955:7019 [01;31m[KNVIDIA Corp[m[K.
09:40:12 INFO : command finished successfully
09:40:12 DEBUG : running command < lsusb | grep 0955:7020 >
09:40:12 ERROR : command terminated with error
09:40:12 INFO : Jetson device is in recovery mode.
BR
How about directly flash device through flash script?
Please find this folder “Linux_for_Tegra” on your host and then use
#put device
sudo ./flash jetson-xaiver mmcblk0p1
I tried manually flashing my device.
I have two main folders on Host PC:
First: Downloads/nvidia/sdkm_downloads where are a lot of packed packages (tbz2 or deb files). There is inside Jetson_Linux_R32.1.0_aarch64.tbz2. I guess that this is Jetson OS package. When I unpacked manually and try to run manually flashing i get Error that there is a missing package.
Probably there is required another package.
Second: Nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888Linux_for_Tegra/, but this folder is empty.
I guess that SDK manager on Host PC on the fly unpacking necessary packages to temporary folder during automatic installation.
The file should be under the second folder.
Nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888/Linux_for_Tegra/ Is your host with ethernet connected?
Yes, I my host has ethernet connection.
Folder Nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888/Linux_for_Tegra/ is empty.
Do you have “Tegra_Linux_Sample-Root-Filesystem_R32.1.0_aarch64.tbz2” under your first folder?
Please untar that folder to Linux_for_Tegra/rootfs
The same error. is there a possibility to run SDK manager directly on Jetson?
No, it is not possible. Please share what error you’ve met on both sdk manager and direct flash with us.
Below full listing from automatic flashing OS. Flashing stops in about 10% of total.
09:31:37 INFO : Flash Jetson AGX Xavier : USB port and is in recovery mode.
• 09:31:37 INFO : Flash Jetson AGX Xavier : exit status 1
• 09:31:37 INFO : Flash Jetson AGX Xavier : [ Component Install Finished with Error ]
• 09:31:37 ERROR : Flash Jetson AGX Xavier : NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP command sudo ./flash.sh jetson-xavier mmcblk0p1 finished with error
• 09:31:37 INFO : Flash Jetson AGX Xavier : [ 20.00 KB used. Disk Avail: 197.78 GB ]
• 09:31:37 INFO : Flash Jetson AGX Xavier : [ NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP Install took 4m47s ]
• 09:31:37 INFO : Flash Jetson AGX Xavier : command sudo ./flash.sh jetson-xavier mmcblk0p1 finished with error
• 09:31:37 ERROR : Flash Jetson AGX Xavier : command terminated with error
• 09:31:37 ERROR : Flash Jetson AGX Xavier : install ‘Flash Jetson AGX Xavier’ failure, command < cd ‘/home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888’ ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=‘install’ -c=‘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’ -i=‘NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP’ -v=‘32.1’ -l=‘/home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888’ -L=‘/home/userPC/.nvsdkm/logs/JetPack_4.2_Linux’ -p=‘7981’ -t=‘P2888’ -e=‘undefined’ > terminated with error
• 09:31:37 INFO : Device Mode Host Setup in Target SDK : install ‘Device Mode Host Setup in Target SDK’ Skipped
• 09:31:37 INFO : DateTime Target Setup : install ‘DateTime Target Setup’ Skipped
• 09:31:38 INFO : CUDA Toolkit for L4T : install ‘CUDA Toolkit for L4T’ Skipped
• 09:31:38 INFO : cuDNN on Target : install ‘cuDNN on Target’ Skipped
• 09:31:38 INFO : TensorRT on Target : install ‘TensorRT on Target’ Skipped
• 09:31:38 INFO : OpenCV on Target : install ‘OpenCV on Target’ Skipped
• 09:31:38 INFO : VisionWorks on Target : install ‘VisionWorks on Target’ Skipped
• 09:31:38 INFO : Multimedia API : install ‘Multimedia API’ Skipped
• 09:31:40 INFO : All done!
• 09:50:40 INFO : *** Retrying to install. attempt number: 3
• 09:50:42 INFO : CUDA on Host : download ‘CUDA on Host’ success
• 09:50:42 INFO : Drivers for Jetson AGX : download ‘Drivers for Jetson AGX’ success
• 09:50:42 INFO : OpenCV on Host : download ‘OpenCV on Host’ success
• 09:50:42 INFO : File System and OS : download ‘File System and OS’ success
• 09:50:42 INFO : NVIDIA Nsight Graphics : download ‘NVIDIA Nsight Graphics’ success
• 09:50:42 INFO : NVIDIA Nsight Systems : download ‘NVIDIA Nsight Systems’ success
• 09:50:42 INFO : VisionWorks on Host : download ‘VisionWorks on Host’ success
• 09:50:42 INFO : DevTools Documentation : download ‘DevTools Documentation’ success
• 09:50:42 INFO : CUDA Cross Compile Package on Host : download ‘CUDA Cross Compile Package on Host’ success
• 09:50:42 INFO : CUDA on Host : install ‘CUDA on Host’ success
• 09:50:42 INFO : Drivers for Jetson AGX : install ‘Drivers for Jetson AGX’ success
• 09:50:43 INFO : OpenCV on Host : install ‘OpenCV on Host’ success
• 09:50:43 INFO : File System and OS : install ‘File System and OS’ success
• 09:50:43 INFO : NVIDIA Nsight Graphics : install ‘NVIDIA Nsight Graphics’ success
• 09:50:43 INFO : NVIDIA Nsight Systems : install ‘NVIDIA Nsight Systems’ success
• 09:50:43 INFO : VisionWorks on Host : install ‘VisionWorks on Host’ success
• 09:50:44 INFO : DevTools Documentation : install ‘DevTools Documentation’ success
• 09:50:44 INFO : CUDA Cross Compile Package on Host : install ‘CUDA Cross Compile Package on Host’ success
• 09:50:45 INFO : OpenCV on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
• 09:50:45 INFO : OpenCV on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
• 09:50:46 INFO : OpenCV on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libopencv-samples_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
• 09:50:46 INFO : OpenCV on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libopencv-python_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
• 09:50:47 INFO : CUDA Toolkit for L4T : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb with correct checksum, skip downloading.
• 09:50:47 INFO : cuDNN on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libcudnn7-doc_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:50:47 INFO : cuDNN on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:50:47 INFO : cuDNN on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:50:48 INFO : TensorRT on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libnvinfer5_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:50:48 INFO : TensorRT on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:50:49 INFO : TensorRT on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libnvinfer-samples_5.0.6-1+cuda10.0_all.deb with correct checksum, skip downloading.
• 09:50:50 INFO : TensorRT on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/tensorrt_5.0.6.3-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:50:50 INFO : TensorRT on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/python-libnvinfer_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:50:50 INFO : TensorRT on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/python-libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:50:51 INFO : TensorRT on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/python3-libnvinfer_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:50:51 INFO : TensorRT on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/python3-libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:50:51 INFO : TensorRT on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/graphsurgeon-tf_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:50:51 INFO : TensorRT on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/uff-converter-tf_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:50:51 INFO : Multimedia API : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/Tegra_Multimedia_API_R32.1.0_aarch64.tbz2 with correct checksum, skip downloading.
• 09:50:52 INFO : VisionWorks on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libvisionworks-sfm-repo_0.90.4_arm64.deb with correct checksum, skip downloading.
• 09:50:52 INFO : VisionWorks on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libvisionworks-repo_1.6.0.500n_arm64.deb with correct checksum, skip downloading.
• 09:50:52 INFO : VisionWorks on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libvisionworks-tracking-repo_0.88.2_arm64.deb with correct checksum, skip downloading.
• 09:51:23 DEBUG : running command < ip addr | grep 192.168.55.100/24 >
• 09:51:23 ERROR : command terminated with error
• 09:51:23 DEBUG : running command < lsusb | grep “NVidia Corp” >
• 09:51:24 INFO : Bus 003 Device 014: ID 0955:7019 #[01;31m#[KNVidia Corp#[m#[K.
• 09:51:24 INFO : command finished successfully
• 09:51:24 INFO : Jetson device is in recovery mode.
• 09:51:24 INFO : Device Mode Host Setup in Flash : Start to install ‘Device Mode Host Setup in Flash’
• 09:51:24 DEBUG : Device Mode Host Setup in Flash : running command < cd ‘/home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888’ ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=‘install’ -c=‘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’ -i=‘NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH’ -v=‘1.0’ -l=‘/home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888’ -L=‘/home/userPC/.nvsdkm/logs/JetPack_4.2_Linux’ -p=‘7981’ -t=‘P2888’ -e=‘undefined’ >
• 09:51:24 INFO : Device Mode Host Setup in Flash : [ Disk Avail:197.78 GB ]
• 09:51:24 INFO : Device Mode Host Setup in Flash : Using GenericInstaller to Install NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH
• 09:51:24 INFO : Device Mode Host Setup in Flash : enter working directory: /home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888
• 09:51:24 INFO : Device Mode Host Setup in Flash : [ Component Install Started ]
• 09:51:25 INFO : Device Mode Host Setup in Flash : current working directory is /home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888
• 09:51:25 INFO : Device Mode Host Setup in Flash : exec_command [host]:
• 09:51:25 INFO : Device Mode Host Setup in Flash : **********************
• 09:51:25 INFO : Device Mode Host Setup in Flash : #!/bin/bash
• 09:51:25 INFO : Device Mode Host Setup in Flash : set -e
• 09:51:25 INFO : Device Mode Host Setup in Flash : set +e
• 09:51:25 INFO : Device Mode Host Setup in Flash : eth_port_name=$(ip route show default | awk ‘/default via/ {print $5; exit}’)
• 09:51:25 INFO : Device Mode Host Setup in Flash : if [[ $eth_port_name == ‘’ ]]; then
• 09:51:25 INFO : Device Mode Host Setup in Flash : echo ‘Can not found route default $eth_port_name, device mode setup failed!’
• 09:51:25 INFO : Device Mode Host Setup in Flash : exit 0
• 09:51:25 INFO : Device Mode Host Setup in Flash : fi
• 09:51:25 INFO : Device Mode Host Setup in Flash : echo ‘Found route default’ $eth_port_name’, setting up device mode’
• 09:51:25 INFO : Device Mode Host Setup in Flash : setup_t=‘192.168.55.0/24’
• 09:51:25 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A POSTROUTING -s $setup_t -o $eth_port_name -j MASQUERADE
• 09:51:25 INFO : Device Mode Host Setup in Flash : sudo iptables -A FORWARD -s $setup_t -o $eth_port_name -j ACCEPT
• 09:51:25 INFO : Device Mode Host Setup in Flash : sudo iptables -A FORWARD -d $setup_t -m state --state ESTABLISHED,RELATED -i $eth_port_name -j ACCEPT
• 09:51:25 INFO : Device Mode Host Setup in Flash : sudo sysctl -w net.ipv4.ip_forward=1
• 09:51:25 INFO : Device Mode Host Setup in Flash : check_google_dns=$(dig @8.8.8.8 nvidia.com || true)
• 09:51:25 INFO : Device Mode Host Setup in Flash : if [[ $check_google_dns == ‘Got answer’ ]]; then
• 09:51:25 INFO : Device Mode Host Setup in Flash : echo ‘Device mode on host successfuly set with DNS 8.8.8.8!’
• 09:51:25 INFO : Device Mode Host Setup in Flash : else
• 09:51:25 INFO : Device Mode Host Setup in Flash : echo ‘Default google DNS is not working, trying to find a valid server in local host settings!’
• 09:51:25 INFO : Device Mode Host Setup in Flash : dns_list=$(nmcli -t device show $eth_port_name | grep ‘DNS’ | grep -o '[^:]*)
• 09:51:25 INFO : Device Mode Host Setup in Flash : for dns in $dns_list; do
• 09:51:25 INFO : Device Mode Host Setup in Flash : check_dns=$(dig @$dns nvidia.com || true)
• 09:51:25 INFO : Device Mode Host Setup in Flash : if [[ $check_dns == ‘Got answer’ ]]; then
• 09:51:25 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A PREROUTING -p tcp -d 8.8.8.8 --dport 53 -j DNAT --to-destination $dns
• 09:51:25 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A PREROUTING -p udp -d 8.8.8.8 --dport 53 -j DNAT --to-destination $dns
• 09:51:25 INFO : Device Mode Host Setup in Flash : echo ‘Device mode on host successfuly set with DNS’ $dns’!’
• 09:51:25 INFO : Device Mode Host Setup in Flash : done
• 09:51:25 INFO : Device Mode Host Setup in Flash : echo ‘Can not found a valid DNS server, device mode setup failed!’
• 09:51:25 INFO : Device Mode Host Setup in Flash : echo ‘If needed to use device mode, please change the target default dns to a valid server by following the steps in release note.’
• 09:51:25 INFO : Device Mode Host Setup in Flash : exec_command: /tmp/tmp_NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH.sh
• 09:51:25 INFO : Device Mode Host Setup in Flash : Found route default eno1, setting up device mode
• 09:51:25 INFO : Device Mode Host Setup in Flash : [host] [sudo] password for userPC:
• 09:51:25 INFO : Device Mode Host Setup in Flash : net.ipv4.ip_forward = 1
• 09:51:40 INFO : Device Mode Host Setup in Flash : Default google DNS is not working, trying to find a valid server in local host settings!
• 09:51:55 INFO : Device Mode Host Setup in Flash : Device mode on host successfuly set with DNS 130.171.200.151!
• 09:51:55 INFO : Device Mode Host Setup in Flash : [ Component Install Finished Successfully ]
• 09:51:55 INFO : Device Mode Host Setup in Flash : [ 16.00 KB used. Disk Avail: 197.78 GB ]
• 09:51:55 INFO : Device Mode Host Setup in Flash : [ NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH Install took 31s ]
• 09:51:55 INFO : Device Mode Host Setup in Flash : command finished successfully
• 09:51:55 INFO : Device Mode Host Setup in Flash : install ‘Device Mode Host Setup in Flash’ success
• 09:51:55 INFO : Flash Jetson AGX Xavier : Start to install ‘Flash Jetson AGX Xavier’
• 09:51:55 DEBUG : Flash Jetson AGX Xavier : running command < cd ‘/home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888’ ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=‘install’ -c=‘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’ -i=‘NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP’ -v=‘32.1’ -l=‘/home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888’ -L=‘/home/userPC/.nvsdkm/logs/JetPack_4.2_Linux’ -p=‘7981’ -t=‘P2888’ -e=‘undefined’ >
• 09:51:55 INFO : Flash Jetson AGX Xavier : [ Disk Avail:197.78 GB ]
• 09:51:55 INFO : Flash Jetson AGX Xavier : Using GenericInstaller to Install NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP
• 09:51:55 INFO : Flash Jetson AGX Xavier : enter working directory: /home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888/Linux_for_Tegra
• 09:51:55 INFO : Flash Jetson AGX Xavier : [ Component Install Started ]
• 09:51:55 INFO : Flash Jetson AGX Xavier : current working directory is /home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888/Linux_for_Tegra
• 09:51:55 INFO : Flash Jetson AGX Xavier : exec_command [target]:
• 09:51:55 INFO : Flash Jetson AGX Xavier : **********************
• 09:51:55 INFO : Flash Jetson AGX Xavier : #!/bin/bash
• 09:51:55 INFO : Flash Jetson AGX Xavier : set -e
• 09:51:55 INFO : Flash Jetson AGX Xavier : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
• 09:51:55 INFO : Flash Jetson AGX Xavier : sudo reboot forced-recovery
• 09:51:55 INFO : Flash Jetson AGX Xavier : exec_command: scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh nvidia@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 “~/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh && rm -f ~/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh”
• 09:54:06 ERROR : Flash Jetson AGX Xavier : lost connection
• 09:56:17 INFO : Flash Jetson AGX Xavier : exit status 255
• 09:56:17 WARNING : Flash Jetson AGX Xavier : command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh nvidia@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 “~/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh && rm -f ~/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh” finished with error, but ignored
• 09:56:17 INFO : Flash Jetson AGX Xavier : exec_command: sleep 20
• 09:56:37 INFO : Flash Jetson AGX Xavier : exec_command: sudo ./flash.sh jetson-xavier mmcblk0p1
• 09:56:37 INFO : Flash Jetson AGX Xavier : ###############################################################################
• 09:56:37 INFO : Flash Jetson AGX Xavier : # L4T BSP Information:
• 09:56:37 INFO : Flash Jetson AGX Xavier : # R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t186ref, EABI: aarch64,
• 09:56:37 INFO : Flash Jetson AGX Xavier : # DATE: Wed Mar 13 07:41:08 UTC 2019
• 09:56:42 INFO : Flash Jetson AGX Xavier : Error: probing the target board failed.
• 09:56:42 INFO : Flash Jetson AGX Xavier : Make sure the target board is connected through
• 09:56:42 INFO : Flash Jetson AGX Xavier : USB port and is in recovery mode.
• 09:56:42 INFO : Flash Jetson AGX Xavier : exit status 1
• 09:56:42 INFO : Flash Jetson AGX Xavier : [ Component Install Finished with Error ]
• 09:56:42 ERROR : Flash Jetson AGX Xavier : NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP command sudo ./flash.sh jetson-xavier mmcblk0p1 finished with error
• 09:56:42 INFO : Flash Jetson AGX Xavier : [ 8.00 KB used. Disk Avail: 197.78 GB ]
• 09:56:42 INFO : Flash Jetson AGX Xavier : [ NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP Install took 4m47s ]
• 09:56:42 INFO : Flash Jetson AGX Xavier : command sudo ./flash.sh jetson-xavier mmcblk0p1 finished with error
• 09:56:42 ERROR : Flash Jetson AGX Xavier : command terminated with error
• 09:56:43 ERROR : Flash Jetson AGX Xavier : install ‘Flash Jetson AGX Xavier’ failure, command < cd ‘/home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888’ ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=‘install’ -c=‘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’ -i=‘NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP’ -v=‘32.1’ -l=‘/home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888’ -L=‘/home/userPC/.nvsdkm/logs/JetPack_4.2_Linux’ -p=‘7981’ -t=‘P2888’ -e=‘undefined’ > terminated with error
• 09:56:43 INFO : Device Mode Host Setup in Target SDK : install ‘Device Mode Host Setup in Target SDK’ Skipped
• 09:56:43 INFO : DateTime Target Setup : install ‘DateTime Target Setup’ Skipped
• 09:56:43 INFO : CUDA Toolkit for L4T : install ‘CUDA Toolkit for L4T’ Skipped
• 09:56:43 INFO : cuDNN on Target : install ‘cuDNN on Target’ Skipped
• 09:56:44 INFO : TensorRT on Target : install ‘TensorRT on Target’ Skipped
• 09:56:44 INFO : OpenCV on Target : install ‘OpenCV on Target’ Skipped
• 09:56:44 INFO : VisionWorks on Target : install ‘VisionWorks on Target’ Skipped
• 09:56:44 INFO : Multimedia API : install ‘Multimedia API’ Skipped
• 09:56:46 INFO : All done!
• 09:57:21 INFO : *** Retrying to install. attempt number: 4
• 09:57:23 INFO : CUDA on Host : download ‘CUDA on Host’ success
• 09:57:23 INFO : Drivers for Jetson AGX : download ‘Drivers for Jetson AGX’ success
• 09:57:23 INFO : OpenCV on Host : download ‘OpenCV on Host’ success
• 09:57:23 INFO : File System and OS : download ‘File System and OS’ success
• 09:57:23 INFO : NVIDIA Nsight Graphics : download ‘NVIDIA Nsight Graphics’ success
• 09:57:23 INFO : NVIDIA Nsight Systems : download ‘NVIDIA Nsight Systems’ success
• 09:57:23 INFO : VisionWorks on Host : download ‘VisionWorks on Host’ success
• 09:57:23 INFO : DevTools Documentation : download ‘DevTools Documentation’ success
• 09:57:23 INFO : CUDA Cross Compile Package on Host : download ‘CUDA Cross Compile Package on Host’ success
• 09:57:23 INFO : CUDA on Host : install ‘CUDA on Host’ success
• 09:57:24 INFO : Drivers for Jetson AGX : install ‘Drivers for Jetson AGX’ success
• 09:57:24 INFO : OpenCV on Host : install ‘OpenCV on Host’ success
• 09:57:24 INFO : File System and OS : install ‘File System and OS’ success
• 09:57:25 INFO : NVIDIA Nsight Graphics : install ‘NVIDIA Nsight Graphics’ success
• 09:57:25 INFO : NVIDIA Nsight Systems : install ‘NVIDIA Nsight Systems’ success
• 09:57:25 INFO : VisionWorks on Host : install ‘VisionWorks on Host’ success
• 09:57:25 INFO : DevTools Documentation : install ‘DevTools Documentation’ success
• 09:57:26 INFO : CUDA Cross Compile Package on Host : install ‘CUDA Cross Compile Package on Host’ success
• 09:57:26 INFO : OpenCV on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
• 09:57:26 INFO : OpenCV on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
• 09:57:28 INFO : CUDA Toolkit for L4T : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb with correct checksum, skip downloading.
• 09:57:28 INFO : OpenCV on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libopencv-python_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
• 09:57:28 INFO : OpenCV on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libopencv-samples_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
• 09:57:29 INFO : cuDNN on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:57:30 INFO : cuDNN on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libcudnn7-doc_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:57:30 INFO : cuDNN on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:57:31 INFO : TensorRT on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libnvinfer5_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:57:32 INFO : TensorRT on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:57:32 INFO : TensorRT on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libnvinfer-samples_5.0.6-1+cuda10.0_all.deb with correct checksum, skip downloading.
• 09:57:32 INFO : TensorRT on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/tensorrt_5.0.6.3-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:57:33 INFO : TensorRT on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/python-libnvinfer_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:57:34 INFO : TensorRT on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/python-libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:57:34 INFO : TensorRT on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/python3-libnvinfer_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:57:34 INFO : TensorRT on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/python3-libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:57:34 INFO : TensorRT on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/graphsurgeon-tf_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:57:35 INFO : TensorRT on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/uff-converter-tf_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
• 09:57:35 INFO : VisionWorks on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libvisionworks-repo_1.6.0.500n_arm64.deb with correct checksum, skip downloading.
• 09:57:35 INFO : Multimedia API : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/Tegra_Multimedia_API_R32.1.0_aarch64.tbz2 with correct checksum, skip downloading.
• 09:57:36 INFO : VisionWorks on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libvisionworks-sfm-repo_0.90.4_arm64.deb with correct checksum, skip downloading.
• 09:57:37 INFO : VisionWorks on Target : Found file /home/userPC/Downloads/nvidia/sdkm_downloads/libvisionworks-tracking-repo_0.88.2_arm64.deb with correct checksum, skip downloading.
• 09:57:43 DEBUG : running command < ip addr | grep 192.168.55.100/24 >
• 09:57:43 ERROR : command terminated with error
• 09:57:43 DEBUG : running command < lsusb | grep “NVidia Corp” >
• 09:57:43 INFO : Bus 003 Device 016: ID 0955:7019 #[01;31m#[KNVidia Corp#[m#[K.
• 09:57:43 INFO : command finished successfully
• 09:57:44 INFO : Jetson device is in recovery mode.
• 09:57:44 INFO : Device Mode Host Setup in Flash : Start to install ‘Device Mode Host Setup in Flash’
• 09:57:44 DEBUG : Device Mode Host Setup in Flash : running command < cd ‘/home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888’ ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=‘install’ -c=‘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’ -i=‘NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH’ -v=‘1.0’ -l=‘/home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888’ -L=‘/home/userPC/.nvsdkm/logs/JetPack_4.2_Linux’ -p=‘7981’ -t=‘P2888’ -e=‘undefined’ >
• 09:57:44 INFO : Device Mode Host Setup in Flash : [ Disk Avail:197.78 GB ]
• 09:57:44 INFO : Device Mode Host Setup in Flash : Using GenericInstaller to Install NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH
• 09:57:44 INFO : Device Mode Host Setup in Flash : enter working directory: /home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888
• 09:57:44 INFO : Device Mode Host Setup in Flash : [ Component Install Started ]
• 09:57:44 INFO : Device Mode Host Setup in Flash : current working directory is /home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888
• 09:57:44 INFO : Device Mode Host Setup in Flash : exec_command [host]:
• 09:57:44 INFO : Device Mode Host Setup in Flash : **********************
• 09:57:44 INFO : Device Mode Host Setup in Flash : #!/bin/bash
• 09:57:44 INFO : Device Mode Host Setup in Flash : set -e
• 09:57:44 INFO : Device Mode Host Setup in Flash : set +e
• 09:57:44 INFO : Device Mode Host Setup in Flash : eth_port_name=$(ip route show default | awk ‘/default via/ {print $5; exit}’)
• 09:57:44 INFO : Device Mode Host Setup in Flash : if [[ $eth_port_name == ‘’ ]]; then
• 09:57:44 INFO : Device Mode Host Setup in Flash : echo ‘Can not found route default $eth_port_name, device mode setup failed!’
• 09:57:44 INFO : Device Mode Host Setup in Flash : exit 0
• 09:57:44 INFO : Device Mode Host Setup in Flash : fi
• 09:57:44 INFO : Device Mode Host Setup in Flash : echo ‘Found route default’ $eth_port_name’, setting up device mode’
• 09:57:44 INFO : Device Mode Host Setup in Flash : setup_t=‘192.168.55.0/24’
• 09:57:44 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A POSTROUTING -s $setup_t -o $eth_port_name -j MASQUERADE
• 09:57:44 INFO : Device Mode Host Setup in Flash : sudo iptables -A FORWARD -s $setup_t -o $eth_port_name -j ACCEPT
• 09:57:44 INFO : Device Mode Host Setup in Flash : sudo iptables -A FORWARD -d $setup_t -m state --state ESTABLISHED,RELATED -i $eth_port_name -j ACCEPT
• 09:57:44 INFO : Device Mode Host Setup in Flash : sudo sysctl -w net.ipv4.ip_forward=1
• 09:57:44 INFO : Device Mode Host Setup in Flash : check_google_dns=$(dig @8.8.8.8 nvidia.com || true)
• 09:57:44 INFO : Device Mode Host Setup in Flash : if [[ $check_google_dns == ‘Got answer’ ]]; then
• 09:57:44 INFO : Device Mode Host Setup in Flash : echo ‘Device mode on host successfuly set with DNS 8.8.8.8!’
• 09:57:44 INFO : Device Mode Host Setup in Flash : else
• 09:57:44 INFO : Device Mode Host Setup in Flash : echo ‘Default google DNS is not working, trying to find a valid server in local host settings!’
• 09:57:44 INFO : Device Mode Host Setup in Flash : dns_list=$(nmcli -t device show $eth_port_name | grep ‘DNS’ | grep -o '[^:]*)
• 09:57:44 INFO : Device Mode Host Setup in Flash : for dns in $dns_list; do
• 09:57:44 INFO : Device Mode Host Setup in Flash : check_dns=$(dig @$dns nvidia.com || true)
• 09:57:44 INFO : Device Mode Host Setup in Flash : if [[ $check_dns == ‘Got answer’ ]]; then
• 09:57:44 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A PREROUTING -p tcp -d 8.8.8.8 --dport 53 -j DNAT --to-destination $dns
• 09:57:44 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A PREROUTING -p udp -d 8.8.8.8 --dport 53 -j DNAT --to-destination $dns
• 09:57:44 INFO : Device Mode Host Setup in Flash : echo ‘Device mode on host successfuly set with DNS’ $dns’!’
• 09:57:44 INFO : Device Mode Host Setup in Flash : done
• 09:57:44 INFO : Device Mode Host Setup in Flash : echo ‘Can not found a valid DNS server, device mode setup failed!’
• 09:57:44 INFO : Device Mode Host Setup in Flash : echo ‘If needed to use device mode, please change the target default dns to a valid server by following the steps in release note.’
• 09:57:44 INFO : Device Mode Host Setup in Flash : exec_command: /tmp/tmp_NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH.sh
• 09:57:44 INFO : Device Mode Host Setup in Flash : Found route default eno1, setting up device mode
• 09:57:44 INFO : Device Mode Host Setup in Flash : net.ipv4.ip_forward = 1
• 09:57:59 INFO : Device Mode Host Setup in Flash : Default google DNS is not working, trying to find a valid server in local host settings!
• 09:58:14 INFO : Device Mode Host Setup in Flash : Device mode on host successfuly set with DNS 130.171.200.151!
• 09:58:14 INFO : Device Mode Host Setup in Flash : [ Component Install Finished Successfully ]
• 09:58:14 INFO : Device Mode Host Setup in Flash : [ 16.00 KB used. Disk Avail: 197.78 GB ]
• 09:58:14 INFO : Device Mode Host Setup in Flash : [ NV_L4T_DEVICE_MODE_SETUP_COMP_IN_FLASH Install took 31s ]
• 09:58:14 INFO : Device Mode Host Setup in Flash : command finished successfully
• 09:58:15 INFO : Device Mode Host Setup in Flash : install ‘Device Mode Host Setup in Flash’ success
• 09:58:15 INFO : Flash Jetson AGX Xavier : Start to install ‘Flash Jetson AGX Xavier’
• 09:58:15 DEBUG : Flash Jetson AGX Xavier : running command < cd ‘/home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888’ ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=‘install’ -c=‘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’ -i=‘NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP’ -v=‘32.1’ -l=‘/home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888’ -L=‘/home/userPC/.nvsdkm/logs/JetPack_4.2_Linux’ -p=‘7981’ -t=‘P2888’ -e=‘undefined’ >
• 09:58:15 INFO : Flash Jetson AGX Xavier : [ Disk Avail:197.78 GB ]
• 09:58:15 INFO : Flash Jetson AGX Xavier : Using GenericInstaller to Install NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP
• 09:58:15 INFO : Flash Jetson AGX Xavier : enter working directory: /home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888/Linux_for_Tegra
• 09:58:15 INFO : Flash Jetson AGX Xavier : [ Component Install Started ]
• 09:58:15 INFO : Flash Jetson AGX Xavier : current working directory is /home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888/Linux_for_Tegra
• 09:58:15 INFO : Flash Jetson AGX Xavier : exec_command [target]:
• 09:58:15 INFO : Flash Jetson AGX Xavier : **********************
• 09:58:15 INFO : Flash Jetson AGX Xavier : #!/bin/bash
• 09:58:15 INFO : Flash Jetson AGX Xavier : set -e
• 09:58:15 INFO : Flash Jetson AGX Xavier : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
• 09:58:15 INFO : Flash Jetson AGX Xavier : sudo reboot forced-recovery
• 09:58:15 INFO : Flash Jetson AGX Xavier : exec_command: scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh nvidia@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 “~/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh && rm -f ~/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh”
• 10:00:25 ERROR : Flash Jetson AGX Xavier : lost connection
• 10:02:36 INFO : Flash Jetson AGX Xavier : exit status 255
• 10:02:36 WARNING : Flash Jetson AGX Xavier : command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh nvidia@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 “~/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh && rm -f ~/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh” finished with error, but ignored
• 10:02:36 INFO : Flash Jetson AGX Xavier : exec_command: sleep 20
• 10:02:56 INFO : Flash Jetson AGX Xavier : exec_command: sudo ./flash.sh jetson-xavier mmcblk0p1
• 10:02:56 INFO : Flash Jetson AGX Xavier : ###############################################################################
• 10:02:56 INFO : Flash Jetson AGX Xavier : # L4T BSP Information:
• 10:02:56 INFO : Flash Jetson AGX Xavier : # R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t186ref, EABI: aarch64,
• 10:02:56 INFO : Flash Jetson AGX Xavier : # DATE: Wed Mar 13 07:41:08 UTC 2019
• 10:02:56 INFO : Flash Jetson AGX Xavier : # Target Board Information:
• 10:02:56 INFO : Flash Jetson AGX Xavier : # Name: jetson-xavier, Board Family: t186ref, SoC: Tegra 194,
• 10:02:56 INFO : Flash Jetson AGX Xavier : # OpMode: production, Boot Authentication: NS,
• 10:02:56 INFO : Flash Jetson AGX Xavier : copying soft_fuses(/home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)… done.
• 10:02:56 INFO : Flash Jetson AGX Xavier : ./tegraflash.py --chip 0x19 --applet “/home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888/Linux_for_Tegra/bootloader/mb1_t194_prod.bin” --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins “mb2_applet nvtboot_applet_t194.bin” --cmd “dump eeprom boardinfo cvm.bin;reboot recovery”
• 10:02:56 ERROR : Flash Jetson AGX Xavier : /usr/bin/env: ‘python’
• 10:02:56 ERROR : Flash Jetson AGX Xavier : : No such file or directory
• 10:02:56 INFO : Flash Jetson AGX Xavier : Reading board information failed.
• 10:02:56 INFO : Flash Jetson AGX Xavier : exit status 1
• 10:02:56 INFO : Flash Jetson AGX Xavier : [ Component Install Finished with Error ]
• 10:02:56 ERROR : Flash Jetson AGX Xavier : NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP command sudo ./flash.sh jetson-xavier mmcblk0p1 finished with error
• 10:02:56 INFO : Flash Jetson AGX Xavier : [ 8.00 KB used. Disk Avail: 197.78 GB ]
• 10:02:56 INFO : Flash Jetson AGX Xavier : [ NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP Install took 4m41s ]
• 10:02:56 INFO : Flash Jetson AGX Xavier : command sudo ./flash.sh jetson-xavier mmcblk0p1 finished with error
• 10:02:56 ERROR : Flash Jetson AGX Xavier : command terminated with error
• 10:02:56 ERROR : Flash Jetson AGX Xavier : install ‘Flash Jetson AGX Xavier’ failure, command < cd ‘/home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888’ ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a=‘install’ -c=‘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’ -i=‘NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP’ -v=‘32.1’ -l=‘/home/userPC/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888’ -L=‘/home/userPC/.nvsdkm/logs/JetPack_4.2_Linux’ -p=‘7981’ -t=‘P2888’ -e=‘undefined’ > terminated with error
• 10:02:57 INFO : Device Mode Host Setup in Target SDK : install ‘Device Mode Host Setup in Target SDK’ Skipped
• 10:02:57 INFO : DateTime Target Setup : install ‘DateTime Target Setup’ Skipped
• 10:02:57 INFO : CUDA Toolkit for L4T : install ‘CUDA Toolkit for L4T’ Skipped
• 10:02:57 INFO : cuDNN on Target : install ‘cuDNN on Target’ Skipped
• 10:02:57 INFO : TensorRT on Target : install ‘TensorRT on Target’ Skipped
• 10:02:58 INFO : OpenCV on Target : install ‘OpenCV on Target’ Skipped
• 10:02:58 INFO : VisionWorks on Target : install ‘VisionWorks on Target’ Skipped
• 10:02:58 INFO : Multimedia API : install ‘Multimedia API’ Skipped
• 10:02:59 INFO : All done!
FLASHING FAILED
Review terminal tab for details. Resolve and RETRY.
Installation of target SDK components was skipped
EXPORT LOGS
RETRY
FAILED ITEMS
STOP TRYING
• Copyright © 2019, NVIDIA CORPORATION. All rights reserved. | NVIDIA Developer[i][/i][/i][/i][i][/i]
According to below log, it looks like manually flash still has something to do.
Could you share me the log of manual flash? Manual flash measn using flash script.
Are you using a VM as host?
Also, to make sure it is not a hardware issue, you could also try to install through Jetpack4.1.1 first.
Thanks for hints!
I have been installed first Jetpack 4.1.1 and after that I have been tried to install again Jetpack 4.2.
Now I have installed Jetpack 4.2 on my Jetson.
BR,
Apparently all USB connections are not built the same.
I have a Xavier DevKit and it only comes with a factory LFT load and no CUDA stuff. OK.
Went to install JetPack 4.2 using a copy of Ubuntu 18.04 in a Virtual Box VM. No go - the USB ports on the VM are not reliable enough to get through the install.
Installed Ubuntu on an ASUS N551JK laptop, and had four failed attempts to install the JetPack 4.2.
Finally determined that the USB port on the left-front of the laptop could get through the flash/install. Not all USB ports are built the same; this port is marked “Charger+”. The left-back port did not work; not marked “+”. Suggest the “+” port may have superior drive capability.
Samples compile and run. YEAY!
The above entry that suggests installing 4.1.1 first may put the USB port on the Xavier into a more resilient state to talk to a sub-optimal USB on the host.
Also, just after I started the successful flash attempt, I realized I had the keyboard and mouse plugged into the Xavier. Note the non-verbal instructions with the Xavier show the keyboard and mouse to in AFTER the flash exercise. Note the Xavier would not boot on the first attempt with the keyboard and mouse connected. My issue with USB “lost connection” may also have been due to the keyboard and mouse being connected while trying to flash.
Hopefully some of this is helpful to others. Good luck. and good RTX-ing…
3 Dec 2019 - UPDATE
Just updated my Xavier to 4.2.3. Took about 2-1/2 hours from start to finish including updating the N551JK and downloading the new software. No issues.
Samples compile and run. YEAY! AGAIN!
I DID try the VM again - and again it was a non-starter. A difference - the previous clearly said there was a USB timeout on the flash process; in this attempt it just says “ERROR” on “RAW” and “SKP” operations. No details that I can tell.
Oh, and, the flash installer needs Python, which Ubuntu does not apparently install by default…
To install Deepstream on a TX2 I needed to flash with jetpack 3.1. And guess what: this only works with Ubuntu 16.04, not with the machine I had especially prepared with 18.04 for flashing Jetpack 4.2. And of course, a VM is not recommended…
Newer Ubuntu comes with Python 3, but Python 2 is needed as an extra package by SDK Manager.
I’m had a whole lot of problems with flashing Xavier with the SDKmanager.
First error that happens is the “Flash Jetson AGX Xavier : lost connection”
Second error is “/use/bin/env: ‘python’”
" : No such file or directory"
The host was a new dual boot system with python3 on it.
That seemed to be my problem. When I downgraded to python2, then I was able to flash the Xavier.
Oh BTW, I have a vertical 768 pixel display, but was able to get to the check box and continue buttons on the bottom of the window usint the Tab key.
Best Regards.
Having a lot of problems with flashing Xavier…
Seems Like Disk Avail: 321.80 MB, not sufficient…
Here is the log. Please Help…!!!
13:51:39 INFO : Flash Jetson AGX Xavier : [ Disk Avail:321.80 MB ]
13:51:39 INFO : Flash Jetson AGX Xavier : Using GenericInstaller to Install NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP
13:51:39 INFO : Flash Jetson AGX Xavier : change working directory to /home/beckman/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888/Linux_for_Tegra
13:51:39 INFO : Flash Jetson AGX Xavier : [ Component Install Started ]
13:51:39 INFO : Flash Jetson AGX Xavier : current working directory is /home/beckman/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888/Linux_for_Tegra
13:51:39 INFO : Flash Jetson AGX Xavier : exec_command [target]:
13:51:39 INFO : Flash Jetson AGX Xavier : **********************
13:51:39 INFO : Flash Jetson AGX Xavier : #!/bin/bash
13:51:39 INFO : Flash Jetson AGX Xavier : set -e
13:51:39 INFO : Flash Jetson AGX Xavier : function safe_apt_install {
13:51:39 INFO : Flash Jetson AGX Xavier : echo “*begin $1, $2”
13:51:39 INFO : Flash Jetson AGX Xavier : tmp_log=/tmp/jetpack_dpkg_log.txt
13:51:39 INFO : Flash Jetson AGX Xavier : sudo rm -f $tmp_log
13:51:39 INFO : Flash Jetson AGX Xavier : set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
13:51:39 INFO : Flash Jetson AGX Xavier : while [ ${CMD_STATUS} -ne 0 ]; do
13:51:39 INFO : Flash Jetson AGX Xavier : if grep -q -e “is locked by another process” -e “E: Could not get lock /var/lib” $tmp_log; then
13:51:39 INFO : Flash Jetson AGX Xavier : echo “Waiting $2 seconds for apt to be available”; sleep ${2}
13:51:39 INFO : Flash Jetson AGX Xavier : else
13:51:39 INFO : Flash Jetson AGX Xavier : echo “Unhandled error when running $1”; exit 1
13:51:39 INFO : Flash Jetson AGX Xavier : fi
13:51:39 INFO : Flash Jetson AGX Xavier : done
13:51:39 INFO : Flash Jetson AGX Xavier : }
13:51:39 INFO : Flash Jetson AGX Xavier : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
13:51:39 INFO : Flash Jetson AGX Xavier : sudo reboot forced-recovery
13:51:39 INFO : Flash Jetson AGX Xavier : exec_command: scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh nvidia@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 “~/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh && rm -f ~/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh”
13:53:49 ERROR : Flash Jetson AGX Xavier : lost connection
13:56:00 INFO : Flash Jetson AGX Xavier : exit status 255
13:56:00 WARNING : Flash Jetson AGX Xavier : command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh nvidia@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 “~/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh && rm -f ~/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh” finished with error, but ignored
13:56:00 INFO : Flash Jetson AGX Xavier : exec_command: sleep 20
13:56:20 INFO : Flash Jetson AGX Xavier : exec_command: sudo ./flash.sh jetson-xavier mmcblk0p1
13:56:20 ERROR : Flash Jetson AGX Xavier : sudo: ./flash.sh: command not found
13:56:20 INFO : Flash Jetson AGX Xavier : exit status 1
13:56:20 INFO : Flash Jetson AGX Xavier : [ Component Install Finished with Error ]
13:56:20 ERROR : Flash Jetson AGX Xavier : NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP command sudo ./flash.sh jetson-xavier mmcblk0p1 finished with error
13:56:20 INFO : Flash Jetson AGX Xavier : [ 0.00 B released. Disk Avail: 321.80 MB ]
13:56:20 INFO : Flash Jetson AGX Xavier : [ NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP Install took 4m41s ]
13:56:20 INFO : Flash Jetson AGX Xavier : command sudo ./flash.sh jetson-xavier mmcblk0p1 finished with error
13:56:20 ERROR : Flash Jetson AGX Xavier : command terminated with error
13:56:20 ERROR : install ‘Flash Jetson AGX Xavier’ failure, command < cd ‘/home/beckman/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP’ -v=‘32.1’ -l=‘/home/beckman/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888’ -L=‘/home/beckman/.nvsdkm/logs/JetPack_4.2_Linux’ -p=‘3682’ -t=‘P2888’ -e=‘undefined’ > terminated with error
13:56:21 INFO : All done!
