Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Dear @hirofumi_momose,
Is the host has enough space? Could you clean up to get some more space before trying to flash. I notice No space left error in the log
20:19:31.170 - error: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: --- Logging error ---
20:19:31.171 - info: Event: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX - error is: --- Logging error ---
20:19:31.172 - error: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: Traceback (most recent call last):
20:19:31.172 - info: Event: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX - error is: Traceback (most recent call last):
20:19:31.172 - error: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: File "logging/__init__.py", line 984, in emit
20:19:31.172 - info: Event: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX - error is: File "logging/__init__.py", line 984, in emit
20:19:31.173 - error: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: File "logging/__init__.py", line 964, in flush
20:19:31.173 - info: Event: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX - error is: File "logging/__init__.py", line 964, in flush
20:19:31.173 - error: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: OSError: [Errno 28] No space left on device
20:19:31.173 - info: Event: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX - error is: OSError: [Errno 28] No space left on device
Besides that, could you attach the error as text instead of image to be able to search by the community
Umm. Host machine has enough space to do the job.
Following is df -k result.
/dev/sda1 holds install image (downloaded prior to)
/dev/sda2 is working directory (specified for sdkmanager)
but /dev/loop is 100%.
I am not sure what these are.
is /dev/sda2 partition is etx4? I notice some flashing earlier if the partition is not ext4. Could you confirm that? Also, Could you check installing at $HOME folder?
I can not find a log file containing same message with the screen.
Instead re-tried today and copy and paste message below .
(entire text cant be copied , sorry)
10:32:50 INFO: Flash Xavier A+B in parallel - flash: exec_command: [ -e /dev/ttyUSB3 ] || echo Failed to flash device: detected no board connected to host with USB cable. >&2
10:32:50 INFO: Flash Xavier A+B in parallel - flash: '` dialout
10:32:50 INFO: Flash Xavier A+B in parallel - flash: exec_command: cd pdkinstaller && ./pdkinstaller --installtype bindflash --boardtype ES --pdkinstalledpath /media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS --configjson ./manifests/install_pdk_config/av_ddp_pegasus_hyp71_linux_tegraAB_install_config.json --consoleout enable
10:34:50 INFO: Flash Xavier A+B in parallel - flash: Password for momose:
10:34:50 INFO: Flash Xavier A+B in parallel - flash: Aurix port /dev/ttyUSB3 found. Fetching board revision from InfoROM …
10:34:59 INFO: Flash Xavier A+B in parallel - flash: BOARD SKU : 940-63550-2000-100
10:34:59 INFO: Flash Xavier A+B in parallel - flash: Executing bind cmd make -f Makefile.bind PCT=linux BOARD=e3550b03-t194a PCT_VARIANT=dev_nonrt
10:35:03 INFO: Flash Xavier A+B in parallel - flash: Executing bind cmd make -f Makefile.bind PCT=linux BOARD=e3550b03-t194b PCT_VARIANT=dev_nonrt
10:35:06 INFO: Flash Xavier A+B in parallel - flash: Bind partitions done!
10:35:06 INFO: Flash Xavier A+B in parallel - flash: Processor found in ttyUSB3
10:35:14 INFO: Flash Xavier A+B in parallel - flash: BOARD SKU : 940-63550-2000-100
10:35:14 INFO: Flash Xavier A+B in parallel - flash: Running flash command: sudo -E /media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation//tools/host/flashtools/bootburn_t19x/bootburn.sh -b e3550b03-t194 -B qspi -x /dev/ttyUSB3 --updtcfga gos1-fs:dirname:/media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux/targetfs_a --updtcfgb gos1-fs:dirname:/media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux/targetfs_b -w
10:35:43 INFO: Flash Xavier A+B in parallel - flash:
10:35:43 INFO: Flash Xavier A+B in parallel - flash: ‘/media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/…/…/…/…//firmwares/bin/t19x/mb1/mb1_safe_t194_prod.bin’ → ‘/media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/_temp_dump/_temp_dump_Ddxi72S9de/rcm-flash/safe_mb1_recovery.bin’
10:35:43 INFO: Flash Xavier A+B in parallel - flash: ==> /media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/_temp_dump/TegraBLog_f3drupjnkJ.txt <==
10:35:44 INFO: Flash Xavier A+B in parallel - flash: /media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/_temp_dump/_temp_dump_Ddxi72S9de/rcm-flash/applet /media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/_temp_dump/_temp_dump_Ddxi72S9de/rcm-flash /media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x /media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/pdkinstaller
10:35:45 INFO: Flash Xavier A+B in parallel - flash:
10:35:45 INFO: Flash Xavier A+B in parallel - flash: ==> /media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/_temp_dump/TegraBLog_f3drupjnkJ.txt <==
10:35:45 INFO: Flash Xavier A+B in parallel - flash: ==> /media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/_temp_dump/TegraALog_wHPfbEUIGN.txt <==
10:35:45 INFO: Flash Xavier A+B in parallel - flash: ‘/media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/…/…/…/…//tools/host/flashtools/flash/t19x/rcmfirmware/tegra194-a02-bpmp-e3550-0001-b01-B.dtb’ → ‘/media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/_temp_dump/_temp_dump_Ddxi72S9de/rcm-flash/bpmp.dtb’
10:35:48 INFO: Flash Xavier A+B in parallel - flash: Generating MB1_BCT File
10:35:48 INFO: Flash Xavier A+B in parallel - flash: f_FlashingMB2Applet = /media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/…/…/…/…//tools/host/flashtools/flash/t19x/rcmbl/nvtboot_applet.bin
10:35:54 INFO: Flash Xavier A+B in parallel - flash: ==> /media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/_temp_dump/TegraBLog_f3drupjnkJ.txt <==
10:35:54 INFO: Flash Xavier A+B in parallel - flash: [… ] 032% [… ] 035%
10:35:54 INFO: Flash Xavier A+B in parallel - flash: ==> /media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/_temp_dump/TegraALog_wHPfbEUIGN.txt <==
10:35:56 INFO: Flash Xavier A+B in parallel - flash: [… ] 037%
10:35:56 INFO: Flash Xavier A+B in parallel - flash: [… ] 053%
10:35:56 INFO: Flash Xavier A+B in parallel - flash: ==> /media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/_temp_dump/TegraBLog_f3drupjnkJ.txt <==
10:35:57 INFO: Flash Xavier A+B in parallel - flash: ‘/media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/…/…/…/…//firmwares/bin/t19x/mts/mce_c10_prod_grp.bin’ → ‘/media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/_temp_dump/_temp_dump_Ddxi72S9de/flash-images/mce_c10_grp.bin’
10:35:58 INFO: Flash Xavier A+B in parallel - flash: ==> /media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/_temp_dump/TegraALog_wHPfbEUIGN.txt <==
10:37:58 INFO: Flash Xavier A+B in parallel - flash: [… ] 081%
10:49:46 INFO: Flash Xavier A+B in parallel - flash: ‘/media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/…/…/…/…//firmwares/bin/t19x/mb1/mb1_safe_t194_prod.bin’ → ‘/media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/_temp_dump/_temp_dump_pw7Vn1K3Vj/flash-images/safe_mb1.bin’
10:49:46 ERROR: Flash Xavier A+B in parallel - flash: Traceback (most recent call last):
10:49:46 ERROR: Flash Xavier A+B in parallel - flash: During handling of the above exception, another exception occurred:
10:49:46 ERROR: Flash Xavier A+B in parallel - flash: File “/usr/lib/python3.5/traceback.py”, line 487, in init
10:49:46 ERROR: Flash Xavier A+B in parallel - flash: command terminated with error
10:49:46 SUMMARY: Flash Xavier A+B in parallel - flash: First Error: Installation failed.
10:49:46 DEBUG: running command < true >
10:49:46 INFO: command finished successfully
10:49:46 DEBUG: DRIVE Linux Release Notes - target_image: using adapter to install NV_DRIVE_LINUX_RELEASE_NOTES@DDPX to /media/momose/0184b7ed-16f5-4549-bb97-3e41f85d9129/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER
10:49:46 INFO: DRIVE Linux Release Notes - target_image: command finished successfully
10:49:46 SUMMARY: DRIVE Linux Release Notes - target_image: Install completed successfully.
I am not sure what version was installed before flashing 5.2.6.
But prior to flashing 5.2.6 , AGX was just unboxed.
It must be factory default.
Please tell me how to identify what version is installed.
I have another AGX and am able to read the version.
Thank you.
Hello, SivaRamaKrishnaNV
Another AGX’s version-ubuntu-rootfs.txt is 5.1.6.1-16902563
GUI display of above machine works.
5.2.6 flashed has no GUI display.
I am confusing that 5.1.6 with GUI but 5.2.6 without GUI.
Regards,
Hiro.
Yes I tried this finalize step on 5.2.6
Console shell/ethernet works , but nothing obtained from HDMI port .
Stucking of installing drive os 10.0 make me thought of
re-installing 5.2.6…
Thank you.
