Hi Steve,
I indeed plug-in USB to Pegasus’s debug port (it seems the same as situation in “https://devtalk.nvidia.com/default/topic/1048765/general/error-flashing-drive-pegasus/post/5323484/#5323484 ”). Anything I can try to do again for providing further debug information?
Thank Steve’s help!
Gary
@SteveNV ,
I cannot flash by my nvonline account (I tried it before by my NV developer account).
Gary
Dear Garywang,
Are you using USB3 or USB2?
If use USB3, could you please try USB2 for this issue? Thanks.
kayccc
May 10, 2019, 1:50am
#24
Hi Gary,
May I know is there any different between your nvonline account and NV developer account?
Are they all with @itri.org.tw ?
Yes! please refer my nvonline account (garywang@itri.org.tw).
kayccc
May 13, 2019, 2:44am
#26
Hi garywang,
Please contact with our representative directly, they will guide you how to do.
SteveNV
September 5, 2019, 5:25am
#27
Dear garywang,
Could you please let me know if this topic is still issue? Thanks.
SteveNV
October 16, 2019, 1:34am
#28
Dear garywang,
We will close this topic and bug please re-open if you have any issue. Thanks.
Hi SteveNV,
I can not flash successfully.
It shows information below:
11:28:45 INFO: *** Retrying to install. attempt number: 2
11:28:53 DEBUG: running command < true >
11:28:53 INFO: command finished successfully
11:28:53 DEBUG: running command < stat /dev/ttyUSB1 >
11:28:53 INFO: Device: 6h/6d Inode: 477 Links: 1 Device type: bc,1
11:28:53 DEBUG: running command < lsof /dev/ttyUSB1 2>/dev/null >
11:28:54 DEBUG: command terminated with error
11:28:54 DEBUG: running command < true >
11:28:54 INFO: command finished successfully
11:28:54 DEBUG: Flash Tegra A: using adapter to install NV_FLASH_TEGRA_A_COMP@PX2_AUTOCHAUFFEUR to /home/cts/nvidia/nvidia_sdk/DRIVE_OS_5.0.10.3_SDK_with_DriveWorks_Linux_OS_PX2_AUTOCHAUFFEUR
11:28:54 INFO: Flash Tegra A: Return success directly for empty component
11:28:54 INFO: Flash Tegra A: command finished successfully
11:28:54 INFO: All done!
but there is nothing new software int target actually.
could you please help me solve the issue.
thanks
Dear @liubingxiang ,
Could you please file new topic and attach flashing logs for further guidance.
