I’m encountering an issue while attempting to flash my Jetson TX2 device. I followed the flashing process using [Flashing Software Name and Version], but I encountered the following error:
ERROR: File System and OS - target_image: command terminated with error
SUMMARY: Flash Jetson TX2 - flash: Depends on failed component
Mainly I have lost my root user password of my TX2 device, so I need to flash my device. While creating the img file of the system, it shows the error, I have attached a zip file which is exported log from SDK manager. My host machine is native UBUNTU 16.04.
are you downloading the BSP into some portable drives?
Using rootfs directory of: /media/tanvir/Work/nvidia/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/rootfs
||||||||||||||||||||||| ERROR |||||||||||||||||||||||
1. The root filesystem, provided with this package,
has to be extracted to this directory:
2. The root filesystem, provided with this package,
has to be extracted with 'sudo' to this directory:
Consult the Development Guide for instructions on
extracting and flashing your device.
Please set the download path inside the disk where the Ubuntu system is installed, so it’s guaranteed that you have the root permission there.
