Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.1.8928
other
Host Machine Version
native Ubuntu 18.04
other
Was trying to compile the leo-drive / Drivers / sekonix_camera · GitLab on target machine.
Had an issue of linking error /usr/lib/libgdal.so.20: undefined reference to `xercesc_3_2::XMLString::transcode(char16_t const*, xercesc_3_2::MemoryManager*)’
Based on the steps given by FabianWeise tried to remove gdal-bin which removed CUDA.
The jsk_rviz_plugin for ROS will use this lib. This plugin can display overlayText in RViz.
While re-flashing the target system, getting the error - ERROR: DRIVE AGX Packages - target_image: command terminated with error
Attached are the sdkm logs.
sdkm-2022-01-03-19-40-13.log.tar.gz (18.5 KB)
VickNV
January 3, 2022, 3:10pm
2
Hi, @hitesh.pandya1
The below snippet is from your log. It looks like some problems in applying patches.
Please try to install again after removing ~/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX directory.
19:41:14.075 - info: NV_DPX_PACKAGES_COMP@DDPX: exec_command: /home/hitesh/nvidia/downloads/sdkm_downloads/drive-t186ref-linux-5.1.6.1-16911241-dpx-patch-v0.7.run
19:41:16.233 - info: NV_DPX_PACKAGES_COMP@DDPX: Linux/5.1.6.1_2144485.patch
19:41:16.235 - info: NV_DPX_PACKAGES_COMP@DDPX: patching file drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn.sh
19:41:16.235 - info: NV_DPX_PACKAGES_COMP@DDPX: Reversed (or previously applied) patch detected! Assume -R? [n]
19:41:16.235 - info: NV_DPX_PACKAGES_COMP@DDPX: Apply anyway? [n]
19:41:16.236 - info: NV_DPX_PACKAGES_COMP@DDPX: Skipping patch.
19:41:16.236 - info: NV_DPX_PACKAGES_COMP@DDPX: 13 out of 13 hunks ignored -- saving rejects to file drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn.sh.rej
19:41:16.236 - info: NV_DPX_PACKAGES_COMP@DDPX: patching file drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn_lib.sh
19:41:16.236 - info: NV_DPX_PACKAGES_COMP@DDPX: Reversed (or previously applied) patch detected! Assume -R? [n]
19:41:16.236 - info: NV_DPX_PACKAGES_COMP@DDPX: Apply anyway? [n]
19:41:16.236 - info: NV_DPX_PACKAGES_COMP@DDPX: 14 out of 14 hunks ignored -- saving rejects to file drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn_lib.sh.rej
19:41:16.236 - info: NV_DPX_PACKAGES_COMP@DDPX: patching file drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/create_bsp_images.sh
19:41:16.236 - info: NV_DPX_PACKAGES_COMP@DDPX: 2 out of 2 hunks ignored -- saving rejects to file drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/create_bsp_images.sh.rej
19:41:16.238 - info: NV_DPX_PACKAGES_COMP@DDPX: [ Package Install Finished with Error ]
19:41:16.238 - info: NV_DPX_PACKAGES_COMP@DDPX: [host] [ 36.00 KB used. Disk Avail: 131.79 GB ]
19:41:16.238 - info: NV_DPX_PACKAGES_COMP@DDPX: [ NV_DPX_PACKAGES_COMP Install took 2s ]
19:41:16.239 - error: cmd finished failure SDKM_END_CODE_FAILURE_e0b80906-4508-480e-9ae2-3f80d0ab1723_33
19:41:16.239 - error: command error code: 33
19:41:16.239 - info: Event: NV_DPX_PACKAGES_COMP@DDPX - error code is: 1033
19:41:16.239 - error: NV_DPX_PACKAGES_COMP@DDPX: command terminated with error
19:41:16.239 - info: Event: NV_DPX_PACKAGES_COMP@DDPX - error is: command terminated with error
19:41:16.242 - info: Event: NV_DPX_PACKAGES_COMP@DDPX - install ended - failure
19:41:16.242 - error: Session first failure occurred while Installing. Root cause component: NV_DPX_PACKAGES_COMP@DDPX. Root cause error code: (1033: RUN file ended with error)
Ok thanks VickNV. Works after removing the directory.
VickNV
January 4, 2022, 2:03pm
4
Good to hear that you solved the problem.
