ERROR: from element /GstPipeline:pipeline0/GstNv3dSink:nv3dsink0
Setting pipeline to PAUSED …
ERROR: Pipeline doesn’t want to pause.
ERROR: from element /GstPipeline:pipeline0/GstNv3dSink:nv3dsink0: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Additional debug info:
gstbasesink.c(5367): gst_base_sink_change_state (): /GstPipeline:pipeline0/GstNv3dSink:nv3dsink0:
Failed to start
• DeepStream Version
• TensorRT Version
• The pipeline being used
Hardware Platform (Jetson agx orin)
• DeepStream Version(6.2)
• JetPack Version (5.1.1)
• TensorRT Version(8.5)
command:gst-launch-1.0 -v v4l2src device=/dev/video2 ! video/x-raw,framerate=30/1,width=1280,height=960 ! nvvidconv ! ‘video/x-raw(memory:NVMM), format=NV12’ ! nv3dsink
issue:
Failed to start
docker:
sudo docker run -id --name=test2 --net=host --runtime nvidia -e DISPLAY=$DISPLAY
-w /opt/nvidia/deepstream/deepstream-6.2 -v /tmp/.X11-unix/:/tmp/.X11-unix
nvcr.io/nvidia/deepstream-l4t:6.2-samples
Sorry for the long delay, are there any problems now?
Before running docker, it may be useful to execute xhost+
Hence we are closing this topic. If need further support, please open a new one. Thanks
