遇到類似的問題
我使用兩個MIPI sensor 輸入. 長時間測試約半小時到四小時
會出現錯誤!
只用一個MIPI sensor超過八小時 未出現錯誤,但沒設備持續長時間測
root@Jetson:/home/nvidia# cat /etc/nv_tegra_release
# R35 (release), REVISION: 5.0, GCID: 35550185, BOARD: t186ref, EABI: aarch64, DATE: Tue Feb 20 04:46:31 UTC 2024
測試指令
gst-launch-1.0 -vvv nvarguscamerasrc sensor_id=0 ! video/x-raw(memory:NVMM), width=(int)1500, height=(int)1500, framerate=30/1, format=(string)NV12 ! nvvidconv ! nvegltransform ! nveglglessink -e"
gst-launch-1.0 -vvv nvarguscamerasrc sensor_id=1 ! video/x-raw(memory:NVMM), width=(int)800, height=(int)800, framerate=30/1, format=(string)NV12 ! nvvidconv ! nvegltransform ! nveglglessink -e"
root@Jetson:/home/nvidia# CONSUMER: ERROR OCCURRED
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: UNAVAILABLE
Additional debug info:
Argus Error Status
EOS on shutdown enabled -- waiting for EOS after Error
Waiting for EOS...
Got EOS from element "pipeline0".
EOS received - stopping pipeline...
Execution ended after 5:35:46.250582592
Setting pipeline to NULL ...
GST_ARGUS: Cleaning up
(Argus) Error Timeout: (propagating from src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 137)
(Argus) Error Timeout: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
Freeing pipeline ...
(Argus) Error InvalidState: Argus client is exiting with 4 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 366)
目前增加
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
與修改測試指令 重作長時間測試
gst-launch-1.0 -vvv nvarguscamerasrc sensor_id=1 ! video/x-raw(memory:NVMM), width=(int)800, height=(int)800, framerate=30/1, format=(string)NV12 ! nvvidconv ! fpsdisplaysink video-sink=fakesink --verbose"
請問還有其他建議嗎???
