ERROR from mpegpsdemux0: Internal data stream error
I run a classification sample in the docker nvcr.io/nvidia/deepstream:5.1-21.02-triton, and change the file source30_1080p_dec_infer-resnet_tiled_display_int8.txt a little. I add the sources like this:
[source12]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=file:///workspace/deepstream/stream/3.mp4
num-sources=15
gpu-id=0
(0): memtype_device - Memory type Device
(1): memtype_pinned - Memory type Host Pinned
(2): memtype_unified - Memory type Unified
cudadec-memtype=0
But I encounter this:
WARNING from primary_gie: Configuration file batch-size reset to: 12
Debug info: gstnvinferserver_impl.cpp(242): validatePluginConfig (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInferServer:primary_gie
WARNING from primary_gie: Configuration file unique-id reset to: 1
Debug info: gstnvinferserver_impl.cpp(248): validatePluginConfig (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInferServer:primary_gie
ERROR from mpegpsdemux0: Internal data stream error.
Debug info: gstmpegdemux.c(2941): gst_ps_demux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin0/GstMpegPSDemux:mpegpsdemux0:
It seems that the plugin GstNvInferServer cannot handle this stream? But it also seems that the mpegpsdemux0 has some errors.
PS. This file source30_1080p_dec_infer-resnet_tiled_display_int8.txt can set the inferring configure file, config_infer_plan_engine_primary.txt, but where to set the inferring engine? The model like .tlt, .engine, .caffemodel, and so on. In config_infer_primary.txt there is a set of properties like these:
model-file=…/…/models/Primary_Detector/resnet10.caffemodel
proto-file=…/…/models/Primary_Detector/resnet10.prototxt
model-engine-file=…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
labelfile-path=…/…/models/Primary_Detector/labels.txt
int8-calib-file=…/…/models/Primary_Detector/cal_trt.bin
But where to point the model in the deepstream-app-trtis configure files?
Sorry for the late response, we will do the investigation and update soon.
Sorry for delay!
From above error, looks decoder failed to decode the video clip - /workspace/deepstream/stream/3.mp4 .
Could you try below commands to check if they can generate the H264 mp4 file correctly?
$ gst-launch-1.0 filesrc location=/workspace/deepstream/stream/3.mp4 ! qtdemux ! h265parse ! nvv4l2decoder ! queue ! nvvideoconvert ! “video/x-raw(memory:NVMM), format=I420” ! nvv4l2h264enc ! h264parse ! qtmux ! filesink location=test.mp4
or
$ gst-launch-1.0 filesrc location=/workspace/deepstream/stream/3.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! queue ! nvvideoconvert ! “video/x-raw(memory:NVMM), format=I420” ! nvv4l2h264enc ! h264parse ! qtmux ! filesink location=test.mp4
