ERROR from primary_gie: Failed to create NvDsInferContext instance, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
**• Jetson Orin Nano DeveloperKit **
• Deep Stream: 6.4.0
• JetPack Version: 6.0-b52
• TensorRT Version: 8.6.2.3-1+cuda12.2
*• CUDA: 12.2
I am trying to run YOLOV7 on Jetson Orin Nano. I have converted the yolov7_training.pt file into onnx format. Then I updated the “config_infer_primary_yoloV7.txt” with following settings:
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-color-format=0
onnx-file=yolov7.onnx
model-engine-file=model_b1_gpu0_fp32.engine
#int8-calib-file=calib.table
labelfile-path=labels.txt
batch-size=1
network-mode=0
num-detected-classes=80
interval=0
gie-unique-id=1
process-mode=1
network-type=0
cluster-mode=2
maintain-aspect-ratio=1
symmetric-padding=1
#workspace-size=2000
parse-bbox-func-name=NvDsInferParseYolo
#parse-bbox-func-name=NvDsInferParseYoloCuda
custom-lib-path=nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so
engine-create-func-name=NvDsInferYoloCudaEngineGet
[class-attrs-all]
nms-iou-threshold=0.45
pre-cluster-threshold=0.25
topk=300
then I upated the ‘deepstream_app_config.txt’ with the following settings:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
type=3
uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4
num-sources=1
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
type=2
sync=0
gpu-id=0
nvbuf-memory-type=0
[osd]
enable=1
gpu-id=0
border-width=5
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=0
batch-size=1
batched-push-timeout=40000
width=1920
height=1080
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
gie-unique-id=2
operate-on-gie-id=1
operate-on-class-ids=0
nvbuf-memory-type=0
config-file=config_infer_primary_yoloV7.txt
[tests]
file-loop=0
when i run it using deepstream-app -c deepstream_app_config.txt, it gives me the following error:
ailed to build CUDA engine
ERROR: Failed to create network using custom network creation function
ERROR: Failed to get cuda engine from custom library API
0:08:20.237117120 22787 0xaaaaed823e70 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 2]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2126> [UID = 2]: build engine file failed
0:08:20.661601186 22787 0xaaaaed823e70 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 2]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2212> [UID = 2]: build backend context failed
0:08:20.661676165 22787 0xaaaaed823e70 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 2]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1351> [UID = 2]: generate backend failed, check config file settings
0:08:20.662771448 22787 0xaaaaed823e70 WARN nvinfer gstnvinfer.cpp:898:gst_nvinfer_start:<primary_gie> error: Failed to create NvDsInferContext instance
0:08:20.662810490 22787 0xaaaaed823e70 WARN nvinfer gstnvinfer.cpp:898:gst_nvinfer_start:<primary_gie> error: Config file path: /home/jetson/faizan/yolos/DeepStream-Yolo/config_infer_primary_yoloV7.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
** ERROR: main:716: Failed to set pipeline to PAUSED
Quitting
nvstreammux: Successfully handled EOS for source_id=0
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(898): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
App run failed
I am using deepstream-yolo github repo form here for yolov7 usage: DeepStream-Yolo/docs/YOLOv7.md at master · marcoslucianops/DeepStream-Yolo · GitHub, could anyone suggest what is the problem. I am exactly following the instructions but still getting the error.
since you have created engine, please comment out engine-create-func-name in config_infer_primary_yoloV7.txt.
