Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:740 No cameras available
I have Jetson Nano 2gb with camera imx 477 and it can’t recognize the camera.
Command:
gst-launch-1.0 nvarguscamerasrc sensor_mode=0 ! ‘video/x-raw(memory:NVMM),width=3820, height=2464, framerate=21/1, format=NV12’ ! nvvidconv flip-method=0 ! ‘video/x-raw,width=960, height=616’ ! nvvidconv ! nvegltransform ! nveglglessink -e
Result:
Setting pipeline to PAUSED …
Using winsys: x11
Pipeline is live and does not need PREROLL …
Got context from element ‘eglglessink0’: gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING …
New clock: GstSystemClock
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.154417152
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
Please help me. I have tried everything at this point. Thank you.
hello AlexLee44867,
may I know which JetPack release you’re using?
had you use the Jetson-IO to update device tree overlay for loading IMX477 camera driver?
please configure [Jetson Nano CSI Connector] to select overlay file.
