Error generated. /.../gstnvarguscamerasrc.cpp, execute:543 Failed to create CaptureSession
I’m encountering this error:
In another thread someone suggested running: nvgstcapture-1.0
This is the tail end of the output:
This issue started when the program I’m working on crashed. My guess is that the driver is hung. I’m wondering if there’s a way to reset the driver without rebooting, or if I have no other option than to reboot.
Does it a always failed problem or got failed sometimes?
What does the v4l2-ctl --list-devices show?
Hello oseberg,
This may happen if there is another session using this same camera (hung or alive) and try to use same camera again; if this issue is happening sometimes. You can close all sessions and reset the nvargus-daemon to reset the argus framework and try nvgstcapture-1.0 again.
sudo service nvargus-daemon restart
Thanks and Regards
Sarath S
Hello ,
I have faced with the same problem when I want to update filter ,
caps = gst_caps_from_string(“video/x-raw(memory:NVMM) , width=1920, height=1080, format=(string)NV12, framerate=(fraction)10/1”);
g_object_set(G_OBJECT(filter), “caps”, caps, NULL);
gst_caps_unref(caps);
while creating pipeline there isn’t any problem. But when I want to update the width height and frame rate it gave me this output.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:543 Failed to create CaptureSession
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
How do you update the width/height and frame rate?
