We are using the TLT sample yolo notebook to retrain the model with our custom dataset. We converted our dataset to the KITTI format, referencing this page. We then ran this command to generate tfrecords:
!tlt-dataset-convert -d $SPECS_DIR/yolo_tfrecords_kitti_trainval.txt -o $DATA_DOWNLOAD_DIR/tfrecords/kitti_trainval/kitti_trainval
And then got this error:
2021-02-02 17:49:41.748521: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
Using TensorFlow backend.
2021-02-02 17:49:44,461 - iva.detectnet_v2.dataio.build_converter - INFO - Instantiating a kitti converter
2021-02-02 17:49:44,462 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Creating output directory /workspace/maskrcnn_experiment/yolo/Shoe_Data/tfrecords/kitti_trainval
2021-02-02 17:49:44,467 - iva.detectnet_v2.dataio.kitti_converter_lib - INFO - Num images in
Train: 114 Val: 18
2021-02-02 17:49:44,467 - iva.detectnet_v2.dataio.kitti_converter_lib - INFO - Validation data in partition 0. Hence, while choosing the validationset during training choose validation_fold 0.
2021-02-02 17:49:44,467 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 0
WARNING:tensorflow:From /home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataio/dataset_converter_lib.py:142: The name tf.python_io.TFRecordWriter is deprecated. Please use tf.io.TFRecordWriter instead.
2021-02-02 17:49:44,467 - tensorflow - WARNING - From /home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataio/dataset_converter_lib.py:142: The name tf.python_io.TFRecordWriter is deprecated. Please use tf.io.TFRecordWriter instead.
/usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:273: VisibleDeprecationWarning: Reading unicode strings without specifying the encoding argument is deprecated. Set the encoding, use None for the system default.
2021-02-02 17:49:44,482 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 1
2021-02-02 17:49:44,488 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 2
2021-02-02 17:49:44,493 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 3
2021-02-02 17:49:44,498 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 4
File "/usr/local/bin/tlt-dataset-convert", line 8, in <module>
sys.exit(main())
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/dataset_convert.py", line 64, in main
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataio/dataset_converter_lib.py", line 71, in convert
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataio/dataset_converter_lib.py", line 105, in _write_partitions
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataio/dataset_converter_lib.py", line 146, in _write_shard
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataio/kitti_converter_lib.py", line 176, in _create_example_proto
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataio/kitti_converter_lib.py", line 279, in _add_targets
AssertionError: Ground truth kitti labels should have only 15 fields.
However, the text files are in this format (following the format included in the Nvidia link above) and they do only have 15 fields:
Air_Force_1 0.00 0 0.0 105.00 128.00 683.00 440.00 0.0 0.0 0.0 0.0 0.0 0.0 0.0
We also verified this was the case for all the files in the label_2 directory with a python script that looped through the files in the directory, split the text into a list/array, and printed the length, which was 15.
Would appreciate any advice on how to solve this issue.
