Error: gst-library-error-quark: Could not initialize supporting library. (3): gstnvmsgbroker.cpp(373): legacy_gst_nvmsgbroker_start (): /GstPipeline:p
Error: gst-library-error-quark: Could not initialize supporting library. (3): gstnvmsgbroker.cpp(373): legacy_gst_nvmsgbroker_start (): /GstPipeline:pipeline0/GstNvMsgBroker:nvmsg-broker:
unable to open shared library
β€’ Hardware Platform (Jetson / GPU)
β€’ DeepStream Version
β€’ JetPack Version (valid for Jetson only)
β€’ TensorRT Version
β€’ NVIDIA GPU Driver Version (valid for GPU only)
β€’ Issue Type( questions, new requirements, bugs)
β€’ How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
β€’ Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
**β€’ Hardware Platform GPU
**β€’ DeepStream Version 6.0
**β€’ TensorRT Version 8.0
**β€’ NVIDIA GPU Driver Version 510.47.03
**β€’ Issue Type error
python3 deepstream_test_4.py -i /opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.h264 -p /opt/nvidia/deepstream/deepstream-6.0/lib --conn-str=β€œlocalhost;9092;test” -s 0
β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating EGLSink
Playing file /opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.h264
Adding elements to Pipeline
Linking elements in the Pipeline
Starting pipeline
deepstream-test4-app -i /opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.h264 -p /opt/nvidia/deepstream/deepstream-6.0/lib --conn-str=β€œlocalhost;9092;test” -s 0
Now playing: /opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.h264
Running…
ERROR from element nvmsg-broker: Could not initialize supporting library.
Error details: gstnvmsgbroker.cpp(373): legacy_gst_nvmsgbroker_start (): /GstPipeline:dstest4-pipeline/GstNvMsgBroker:nvmsg-broker:
Returned, stopping playback
Deleting pipeline
Please check your cloud server config and connections
