Playing file /opt/nvidia/deepstream/deepstream-5.1/samples/streams/sample_720p.h264
Adding elements to Pipeline
Linking elements in the Pipeline
Starting pipeline
Error: gst-library-error-quark: Could not configure supporting library. (5): gstnvmsgbroker.c(388): legacy_gst_nvmsgbroker_start (): /GstPipeline:pipeline0/GstNvMsgBroker:nvmsg-broker:
unable to connect to broker library
Which platform you are running on? you need to connect monitor for nveglglessink to work, you can either run from desktop or run through remote terminal, but export DISPLAY firstly before run,
export DISPLAY=:0 or 1 //xrandr to check display if exported
if you run with Tesla cards, it does not have display port or hdmi port, you can either follow this Deepstream/FAQ - eLinux.org 5A to setup virtual display or you can use rtspstreamming to see the output.
Yes. you can create queue to bind the queue with exchange with specified routing key.
check this,
sources/libs/amqp_protocol_adaptor/README
Test & verify messages published:
