ERROR:gstqueue.c:1143:gst_queue_leak_downstream: assertion failed: (leak != NULL)
**• Hardware Platform (Jetson / GPU) GPU
**• DeepStream Version: 6.0
**• TensorRT Version: 8001
**• NVIDIA GPU Driver Version (valid for GPU only): 11.7
**• Issue Type( questions, new requirements, bugs): bugs
**• How to reproduce the issue ?
i run with : ./deepstream-app -c config_file
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
[sink0]
enable=1
type=1
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=1
batch-size=8
batched-push-timeout=40000
width=1920
height=1080
enable-padding=0
nvbuf-memory-type=0
attach-sys-ts-as-ntp=1
[primary-gie]
enable=1
gpu-id=0
batch-size=8
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
bbox-border-color4=1;1;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_detect.txt
[secondary-gie0]
enable=1
gpu-id=0
gie-unique-id=2
batch-size=8
nvbuf-memory-type=0
operate-on-gie-id=1
operate-on-class-ids=1
config-file=config_infer_traffic_accident_classify.txt
[tracker]
enable=1
tracker-width=640
tracker-height=384
ll-config-file=config_tracker_NvDCF_perf.yml
ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
enable-batch-process=1
enable-past-frame=0
display-tracking-id=1
[source0]
camera-id=588
select-rtp-protocol=4
uri=rtsp://xxxx
enable=1
type=4
gpu-id=0
cudadec-memtype=0
num-sources=15
rtsp-reconnect-interval-sec=5
rtsp-reconnect-attempts=-1
drop-frame-interval=5
smart-record=1
smart-rec-cache=25
smart-rec-duration=10
smart-rec-start-time=10
smart-rec-container=0
smart-rec-file-prefix=traffic_accident
smart-rec-dir-path=/data
[nvds-analytics]
enable=1
config-file=config_nvdsanalytics.txt
and i received this error:
Bail out! ERROR:gstqueue.c:1143:gst_queue_leak_downstream: assertion failed: (leak != NULL)
can anyone help me how to solve it? thanks very much
There is no update from you for a period, assuming this is not an issue any more. Hence we are closing this topic. If need further support, please open a new one. Thanks.
  1. did you modify the code? did this error happen every time? how log it will happen? could you share a whole log?
  2. could you simplify the configurations to narrow down this issue? for example, disable tracker, sgie, analytics temporarily.
