basi info:
Driver Version: 525.105.17
CUDA Version: 11.8
Compute Capability 8.6
when use function in cuda_fp16.h at .cu, it will report identifier xxx is undefined like this:
(14:14:24) ERROR: /apollo/modules/perception/common/inference/tensorrt/BUILD:7:12: Compiling modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu failed: (Exit 1): crosstool_wrapper_driver_is_not_gcc failed: error executing command external/local_config_cuda/crosstool/clang/bin/crosstool_wrapper_driver_is_not_gcc -MD -MF … (remaining 223 arguments skipped)
nvcc warning : The ‘compute_35’, ‘compute_37’, ‘sm_35’, and ‘sm_37’ architectures are deprecated, and may be removed in a future release (Use -Wno-deprecated-gpu-targets to suppress warning).
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(40): error: identifier “__hdiv” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(113): error: identifier “__hfma” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(122): error: identifier “__hfma2” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(221): error: identifier “__hmul” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(222): error: identifier “__hsub” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(225): error: identifier “hcos” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(225): error: identifier “hsin” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(225): error: more than one conversion function from “const __half” to a built-in type applies:
function “__half::operator float() const”
/usr/local/cuda-11.8/bin/…/targets/x86_64-linux/include/cuda_fp16.hpp(204): here
function “__half::operator short() const”
/usr/local/cuda-11.8/bin/…/targets/x86_64-linux/include/cuda_fp16.hpp(222): here
function “__half::operator unsigned short() const”
/usr/local/cuda-11.8/bin/…/targets/x86_64-linux/include/cuda_fp16.hpp(225): here
function “__half::operator int() const”
/usr/local/cuda-11.8/bin/…/targets/x86_64-linux/include/cuda_fp16.hpp(228): here
function “__half::operator unsigned int() const”
/usr/local/cuda-11.8/bin/…/targets/x86_64-linux/include/cuda_fp16.hpp(231): here
function “__half::operator long long() const”
/usr/local/cuda-11.8/bin/…/targets/x86_64-linux/include/cuda_fp16.hpp(234): here
function “__half::operator unsigned long long() const”
/usr/local/cuda-11.8/bin/…/targets/x86_64-linux/include/cuda_fp16.hpp(237): here
function “__half::operator __nv_bool() const”
/usr/local/cuda-11.8/bin/…/targets/x86_64-linux/include/cuda_fp16.hpp(241): here
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(232): error: identifier “__hfma” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(241): error: identifier “__hdiv” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(320): error: identifier “__hmul” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(321): error: identifier “__hsub” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(324): error: identifier “hcos” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(324): error: identifier “hsin” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(324): error: more than one conversion function from “const __half” to a built-in type applies:
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(333): error: identifier “__hfma2” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(332): error: identifier “__hadd2” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(339): error: identifier “__hmul2” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(339): error: identifier “__h2div” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(572): error: identifier “__hmul” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(573): error: identifier “__hsub” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(576): error: identifier “hcos” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(576): error: identifier “hsin” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(576): error: more than one conversion function from “const __half” to a built-in type applies:
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(585): error: identifier “__hfma2” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(584): error: identifier “__hadd2” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(591): error: identifier “__hmul2” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(591): error: identifier “__h2div” is undefined
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(430): error: identifier “hcos” is undefined
detected during instantiation of “void rotate_int8(int8_4 *, float, const int8_4 *, float, const T *, const T *, int *, RotateInterpolation, cudaStream_t) [with T=float]”
(758): here
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(430): error: identifier “hsin” is undefined
(758): here
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(430): error: more than one conversion function from “const __half” to a built-in type applies:
(758): here
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(439): error: identifier “__hfma2” is undefined
(758): here
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(438): error: identifier “__hadd2” is undefined
(758): here
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(445): error: identifier “__hmul2” is undefined
(758): here
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(445): error: identifier “__h2div” is undefined
(758): here
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(475): error: identifier “__hsub” is undefined
(758): here
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(475): error: identifier “__hmul” is undefined
(758): here
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(425): error: identifier “__hmul” is undefined
detected during:
instantiation of “void rotateKernel_int8(int, int8_4 *, float, const int8_4 *, float, const T *, const T *, int, int, int, RotateInterpolation) [with T=float]”
(747): here
(758): here
modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu(426): error: identifier “__hsub” is undefined
detected during:
(747): here
(758): here
41 errors detected in the compilation of “modules/perception/common/inference/tensorrt/plugins/rotateKernel.cu”.
