Error in flashing R35.4.1 to Jetson Xavier NX 16GB NVME
Hello.
I’m trying to flashing R35.4.1 to my board.
  • board : custom board. (detected to jetson-xavier-nx-devkit-emmc using “sudo ./nvautoflash.sh --print_boardid”)
    I succeded to flash R32.6.1 & R32.7.1 to this board.
  • jetson : Jetson Xavier NX 16GB
  • memory : NVME 256GB(no sd, no emmc)
  • Host PC : Ubuntu 20.04
I followed the process in https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/IN/QuickStart.html#jetson-modules-and-configurations
I used command
sudo ./tools/kernel_flash/l4t_initrd_flash.sh -c ./tools/kernel_flash/flash_l4t_nvme.xml -S 220GiB --external-device nvme0n1p1 --showlogs jetson-xavier-nx-devkit-emmc nvme0n1p1
(this command worked well in R32.6.1 & R32.7.1 with my board)
But, I got an error
  • Step 3: Start the flashing process *
xargs: unmatched double quote; by default quotes are special to xargs unless you use the -0 option
Cleaning up…
I attached the log
flash_1-2_0_20240412-213835.log (8.4 KB)
How can I flash this to my board?
Put the full log including where you ran the command here.
Clearly you messed it up with the usage.
I added 2 log file.
One is Host PC log and the other is Jetson UART log.
host_pc_log.txt (4.3 KB)
flash_uart_log.txt (75.3 KB)
Pls, check and give me an advice.
Is adding --network usb0 making any difference?
Oh. it works well. Thanks
