A5000 laptop GPU, on Ubuntu 20.04
• DeepStream Version
6.3
• TensorRT Version
nv-tensorrt-local-repo-ubuntu2004-8.6.1-cuda-12.0/now 1.0-1 amd64 [installed,local]
tensorrt-dev/unknown,unknown,now 8.6.1.6-1+cuda12.0 amd64 [installed,upgradable to: 10.9.0.34-1+cuda12.8]
tensorrt-libs/unknown,unknown,now 8.6.1.6-1+cuda12.0 amd64 [installed,upgradable to: 10.9.0.34-1+cuda12.8]
tensorrt/unknown,unknown,now 8.6.1.6-1+cuda12.0 amd64 [installed,upgradable to: 10.9.0.34-1+cuda12.8]
| NVIDIA-SMI 570.124.06 Driver Version: 570.124.06 CUDA Version: 12.8 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA RTX A5000 Laptop GPU On | 00000000:01:00.0 On | N/A |
| N/A 60C P8 16W / 90W | 314MiB / 16384MiB | 13% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
although I originally had the 470.xx driver when I started getting this error and uninstalled/reinstalled/upgraded the driver in process of troubleshooting this issue
This seems very similar to this issue: ERROR from nvv4l2h264enc. Could not get/set settings from/on resource. Device is in streaming mode
I have started getting a lot of these errors when starting pipelines:
Error while setting IOCTL
Invalid control
S_EXT_CTRLS for CUDA_GPU_ID failed
Invalid control
Invalid control
Invalid control
For instance here’s the output of one of the deepstream apps:
deepstream-app -c /opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
libEGL warning: MESA-LOADER: failed to retrieve device information
libEGL warning: DRI2: failed to authenticate
0:00:04.390909617 10049 0x563c60111690 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 6]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/../../models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input_1 3x224x224
1 OUTPUT kFLOAT predictions/Softmax 20x1x1
0:00:04.568478987 10049 0x563c60111690 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2091> [UID = 6]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/../../models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:04.573337678 10049 0x563c60111690 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<secondary_gie_2> [UID 6]: Load new model:/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/config_infer_secondary_carmake.txt sucessfully
0:00:08.246213303 10049 0x563c60111690 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 5]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/../../models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
1 OUTPUT kFLOAT predictions/Softmax 12x1x1
0:00:08.428340892 10049 0x563c60111690 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2091> [UID = 5]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/../../models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:08.430388255 10049 0x563c60111690 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<secondary_gie_1> [UID 5]: Load new model:/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/config_infer_secondary_carcolor.txt sucessfully
0:00:12.101397882 10049 0x563c60111690 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 4]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/../../models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
1 OUTPUT kFLOAT predictions/Softmax 6x1x1
0:00:12.285438853 10049 0x563c60111690 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2091> [UID = 4]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/../../models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:12.286287925 10049 0x563c60111690 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<secondary_gie_0> [UID 4]: Load new model:/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/config_infer_secondary_vehicletypes.txt sucessfully
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
[NvMultiObjectTracker] Loading TRT Engine for tracker ReID...
[NvMultiObjectTracker] Loading Complete!
ERROR: [TRT]: 3: [runtime.cpp::~Runtime::346] Error Code 3: API Usage Error (Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
[NvMultiObjectTracker] Initialized
0:00:16.070228557 10049 0x563c60111690 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:16.251219966 10049 0x563c60111690 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2091> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine
0:00:16.253038472 10049 0x563c60111690 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg)
**PERF: 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00)
** INFO: <bus_callback:239>: Pipeline ready
Invalid control
Invalid control
Invalid control
Invalid control
ENC_CTX(0x7fab8400d210) Error in initializing nvenc context
ERROR from sink_sub_bin_encoder2: Could not get/set settings from/on resource.
Debug info: gstv4l2object.c(3536): gst_v4l2_object_set_format_full (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstBin:sink_sub_bin2/nvv4l2h264enc:sink_sub_bin_encoder2:
Quitting
nvstreammux: Successfully handled EOS for source_id=0
nvstreammux: Successfully handled EOS for source_id=1
nvstreammux: Successfully handled EOS for source_id=2
nvstreammux: Successfully handled EOS for source_id=3
[NvMultiObjectTracker] De-initialized
App run failed
could you share the output of “gst-inspect-1.0 |grep nvv4l2h264enc” and “ldd /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideo4linux2.so” ?
$ gst-inspect-1.0 |grep nvv4l2h264enc
nvvideo4linux2: nvv4l2h264enc: V4L2 H.264 Encoder
$ ldd /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideo4linux2.so
linux-vdso.so.1 (0x00007ffe1610e000)
libnvbufsurface.so => ///opt/nvidia/deepstream/deepstream-6.3/lib/libnvbufsurface.so (0x00007facaeb97000)
libnvbufsurftransform.so => ///opt/nvidia/deepstream/deepstream-6.3/lib/libnvbufsurftransform.so (0x00007facaced7000)
libgstnvcustomhelper.so => ///opt/nvidia/deepstream/deepstream-6.3/lib/libgstnvcustomhelper.so (0x00007facaced2000)
libgstallocators-1.0.so.0 => /usr/lib/x86_64-linux-gnu/libgstallocators-1.0.so.0 (0x00007facace94000)
libgstnvdsseimeta.so => ///opt/nvidia/deepstream/deepstream-6.3/lib/libgstnvdsseimeta.so (0x00007facace8d000)
libgstreamer-1.0.so.0 => /usr/lib/x86_64-linux-gnu/libgstreamer-1.0.so.0 (0x00007facacd46000)
libgstbase-1.0.so.0 => /usr/lib/x86_64-linux-gnu/libgstbase-1.0.so.0 (0x00007facaccc8000)
libgstvideo-1.0.so.0 => /usr/lib/x86_64-linux-gnu/libgstvideo-1.0.so.0 (0x00007facacc17000)
libglib-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007facacaed000)
libgobject-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0 (0x00007facaca8d000)
libv4l2.so.0 => /usr/lib/x86_64-linux-gnu/libv4l2.so.0 (0x00007facac986000)
libc.so.6 => /usr/lib/x86_64-linux-gnu/libc.so.6 (0x00007facac794000)
libnvbuf_fdmap.so => ///opt/nvidia/deepstream/deepstream-6.3/lib/libnvbuf_fdmap.so (0x00007facac78e000)
libcudart.so.12 => /usr/local/cuda-12.1/lib64/libcudart.so.12 (0x00007facac4e7000)
libcuda.so.1 => /usr/lib/x86_64-linux-gnu/libcuda.so.1 (0x00007faca8022000)
libpthread.so.0 => /usr/lib/x86_64-linux-gnu/libpthread.so.0 (0x00007faca7fff000)
libnppc.so.12 => /usr/local/cuda-12.1/lib64/libnppc.so.12 (0x00007faca7c6e000)
libnppig.so.12 => /usr/local/cuda-12.1/lib64/libnppig.so.12 (0x00007faca5472000)
libnppidei.so.12 => /usr/local/cuda-12.1/lib64/libnppidei.so.12 (0x00007faca4834000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007faca4652000)
libgcc_s.so.1 => /usr/lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007faca4637000)
libgmodule-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libgmodule-2.0.so.0 (0x00007faca4631000)
libm.so.6 => /usr/lib/x86_64-linux-gnu/libm.so.6 (0x00007faca44e0000)
libdl.so.2 => /usr/lib/x86_64-linux-gnu/libdl.so.2 (0x00007faca44da000)
liborc-0.4.so.0 => /usr/lib/x86_64-linux-gnu/liborc-0.4.so.0 (0x00007faca4457000)
libpcre.so.3 => /usr/lib/x86_64-linux-gnu/libpcre.so.3 (0x00007faca43e4000)
libffi.so.7 => /usr/lib/x86_64-linux-gnu/libffi.so.7 (0x00007faca43d8000)
libv4lconvert.so.0 => /usr/lib/x86_64-linux-gnu/libv4lconvert.so.0 (0x00007faca434f000)
/lib64/ld-linux-x86-64.so.2 (0x00007facaebf6000)
librt.so.1 => /usr/lib/x86_64-linux-gnu/librt.so.1 (0x00007faca4345000)
I am running deepstream inside of a docker container with a non-sudo user, not in host networking mode.
- for simplicity, could you try these two commands?
gst-launch-1.0 filesrc location=/opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! fakesink
gst-launch-1.0 filesrc location=/opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! nvvideoconvert ! video/x-raw(memory:NVMM),format=I420 ! nvv4l2h264enc bitrate=1000000 ! filesink location=test.264
$ sudo gst-launch-1.0 filesrc location=/opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! fakesink
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Invalid control
Invalid control
(sudo doesn’t change things)
$ gst-launch-1.0 filesrc location=/opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! nvvideoconvert ! video/x-raw\(memory:NVMM\),format=I420 ! nvv4l2h264enc bitrate=1000000 ! filesink location=test.264
Invalid control
Invalid control
I tried installing the drivers via .run
script downloaded directly from nvidia, and in that case, the drivers never loaded at all, Ubuntu just kept falling back to the open source drivers so the card wasn’t being recognized at all. I also tried the headless drivers without success.
I saw one other post about the NVIDIA_DRIVER_CAPABILITIES
$ echo $NVIDIA_DRIVER_CAPABILITIES
compute,utility
me@indominus_rex2:/workspaces/nvidia ()
$ export NVIDIA_DRIVER_CAPABILITIES=all
Invalid control
Invalid control
Any other ideas would be appreciated.
