Error in Linking
I have written a code that needs to compare CPU and GPU performance. For that purpose I was using GPU timers (Can I use Events and other functions from cutil_inline.h in .cpp files? They worked all right in the Debug mode). However, when I try to compile in the Release mode, I get the following error
error LNK2001: unresolved external symbol _cudaEventCreate@4
Do I have to time using the CPU timers? Is there no other way I could overcome this problem?
I think you have a different configuration in Release and Debug mode.
You have to go properties > linking options > input
and make sure you have all libraries in this input (like in your debug mode options)
Hope that will help you
Hi mainak,
Does your code work, i want to test GPU performance also, but i am new to cuda and i am not a developper, could you post it please?
thx!
