Error in nvOCDR DeepStream
Hardware Platform (Jetson / GPU) : Jetson Orin Nano Dev kit
• DeepStream Version : 7.1
• JetPack Version (valid for Jetson only) : 6.1(rev1)
• TensorRT Version :10.3
I am working on nvOCD solution on Jetson Orin Nano Dev kit but I am getting below error.
gst-launch-1.0 filesrc location=/home/rptech/projects/ocdr/onnx_models/NVIDIA-Optical-Character-Detection-and-Recognition-Solution/c++_samples/test_img/scene_text.jpg ! jpegparse ! nvv4l2decoder ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=1080 ! nvdsvideotemplate customlib-name=/home/rptech/projects/ocdr/onnx_models/NVIDIA-Optical-Character-Detection-and-Recognition-Solution/libnvocdr.so customlib-props=“ocdnet-engine-path:/home/rptech/projects/ocdr/onnx_models/ocdnet.fp16.engine” customlib-props=“ocdnet-input-shape:3,736,1280” customlib-props=“ocdnet-binarize-threshold:0.1” customlib-props=“ocdnet-polygon-threshold:0.3” customlib-props=“ocdnet-max-candidate:200” customlib-props=“ocrnet-engine-path:/home/rptech/projects/ocdr/onnx_models/ocrnet.fp16.engine” customlib-props=“ocrnet-dict-path:/home/rptech/projects/ocdr/onnx_models/character_list.txt” customlib-props=“ocrnet-input-shape:1,32,100” ! nvmultistreamtiler rows=1 columns=1 width=1280 height=720 ! nvvideoconvert ! nvdsosd ! nvvideoconvert ! ‘video/x-raw,format=I420’ ! jpegenc ! jpegparse ! filesink location=/home/rptech/projects/ocdr/onnx_models/NVIDIA-Optical-Character-Detection-and-Recognition-Solution/c++_samples/test_img/output.jpg
Setting pipeline to PAUSED …
Opening in BLOCKING MODE
ERROR: from element /GstPipeline:pipeline0/GstNvDsVideoTemplate:nvdsvideotemplate0: Runtime error: createCustomAlgoCtx function not found in library
Additional debug info:
Exception occurred
ERROR: pipeline doesn’t want to preroll.
Failed to set pipeline to PAUSED.
Setting pipeline to NULL …
Freeing pipeline …
Please suggest on this.
For DeepStream sample, please refer to deepstream_tao_apps/apps/tao_others/deepstream-nvocdr-app at master · NVIDIA-AI-IOT/deepstream_tao_apps
I am referring to same link for this project. But the thing is i am doing it on-prem not in container.
You don’t need to do it in container. What you have to do is to install the DeepStream SDK according to Installation — DeepStream documentation
already installed via sdk manager on the jetson.
The “customlib-name=/home/rptech/projects/ocdr/onnx_models/NVIDIA-Optical-Character-Detection-and-Recognition-Solution/libnvocdr.so” is wrong, it should be the “deepstream/libnvocdr_impl.so”.
It is mentioned to compile in our directory in the same repo itself. Please find the attachment FYR.
And even I searched in /opt/nvidia/deepstream/deepstream-7.1/sources/gst-plugins for libnvocdr_impl.so but I could not find it there.
Looking forward for your suggestions.
You are running with DeepStream but not the sample in NVIDIA-AI-IOT/NVIDIA-Optical-Character-Detection-and-Recognition-Solution: This repository provides optical character detection and recognition solution optimized on Nvidia devices.. Why don’t you follow the DeepStream instruction? deepstream_tao_apps/apps/tao_others/deepstream-nvocdr-app at master · NVIDIA-AI-IOT/deepstream_tao_apps
Thanks for your suggestions.I am following the same. now there is a new challenge. No errors are generating but it is stuck in between. attaching the log fyr.
gst-launch-1.0 filesrc location=/home/rptech/projects/ocdr/onnx_models/repo/c++_samples/test_img/scene_text.jpg ! jpegparse ! nvv4l2decoder ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=1080 ! nvdsvideotemplate customlib-name=/home/rptech/projects/ocdr/onnx_models/repo/deepstream/libnvocdr_impl.so customlib-props=“ocdnet-engine-path:/home/rptech/projects/ocdr/onnx_models/ocdnet.fp16.engine” customlib-props=“ocdnet-input-shape:3,736,1280” customlib-props=“ocdnet-binarize-threshold:0.1” customlib-props=“ocdnet-polygon-threshold:0.3” customlib-props=“ocdnet-max-candidate:200” customlib-props=“ocrnet-engine-path:/home/rptech/projects/ocdr/onnx_models/ocrnet.fp16.engine” customlib-props=“ocrnet-dict-path:home/rptech/projects/ocdr/onnx_models/character_list.txt” customlib-props=“ocrnet-input-shape:1,32,100” ! nvmultistreamtiler rows=1 columns=1 width=1280 height=720 ! nvvideoconvert ! nvdsosd ! nvvideoconvert ! ‘video/x-raw,format=I420’ ! jpegenc ! jpegparse ! filesink location=/home/rptech/projects/ocdr/onnx_models/repo/c++_samples/test_img/output.jpg
Inside Custom Lib : Setting Prop Key=ocdnet-engine-path Value=/home/rptech/projects/ocdr/onnx_models/ocdnet.fp16.engine
Inside Custom Lib : Setting Prop Key=ocdnet-input-shape Value=3,736,1280
Inside Custom Lib : Setting Prop Key=ocdnet-binarize-threshold Value=0.1
Inside Custom Lib : Setting Prop Key=ocdnet-polygon-threshold Value=0.3
Inside Custom Lib : Setting Prop Key=ocdnet-max-candidate Value=200
Inside Custom Lib : Setting Prop Key=ocrnet-engine-path Value=/home/rptech/projects/ocdr/onnx_models/ocrnet.fp16.engine
Inside Custom Lib : Setting Prop Key=ocrnet-dict-path Value=home/rptech/projects/ocdr/onnx_models/character_list.txt
Inside Custom Lib : Setting Prop Key=ocrnet-input-shape Value=1,32,100
Pipeline is PREROLLING …
NvMMLiteOpen : Block : BlockType = 277
NvMMLiteBlockCreate : Block : BlockType = 277
(gst-launch-1.0:6384): GStreamer-CRITICAL **: 10:39:17.705: gst_caps_set_simple: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:6384): GStreamer-Base-CRITICAL **: 10:39:17.706: basetransform: second attempt to fixate caps returned invalid (NULL) caps on pad nvdsvideotemplate0:sink
(gst-launch-1.0:6384): GStreamer-CRITICAL **: 10:39:17.707: gst_caps_set_simple: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:6384): GStreamer-Base-CRITICAL **: 10:39:17.707: basetransform: second attempt to fixate caps returned invalid (NULL) caps on pad nvdsvideotemplate0:sink
(gst-launch-1.0:6384): GStreamer-CRITICAL **: 10:39:17.734: gst_caps_set_simple: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:6384): GStreamer-Base-CRITICAL **: 10:39:17.734: basetransform: second attempt to fixate caps returned invalid (NULL) caps on pad nvdsvideotemplate0:sink
(gst-launch-1.0:6384): GStreamer-CRITICAL **: 10:39:17.757: gst_caps_set_simple: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:6384): GStreamer-Base-CRITICAL **: 10:39:17.757: basetransform: second attempt to fixate caps returned invalid (NULL) caps on pad nvdsvideotemplate0:sink
(gst-launch-1.0:6384): GStreamer-CRITICAL **: 10:39:17.758: gst_caps_set_simple: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:6384): GStreamer-Base-CRITICAL **: 10:39:17.758: basetransform: second attempt to fixate caps returned invalid (NULL) caps on pad nvdsvideotemplate0:sink
nvstreammux: Successfully handled EOS for source_id=0
(gst-launch-1.0:6384): GStreamer-CRITICAL **: 10:39:17.759: gst_caps_set_simple: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:6384): GStreamer-Base-CRITICAL **: 10:39:17.759: basetransform: second attempt to fixate caps returned invalid (NULL) caps on pad nvdsvideotemplate0:sink
(gst-launch-1.0:6384): GStreamer-CRITICAL **: 10:39:17.760: gst_caps_set_simple: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:6384): GStreamer-Base-CRITICAL **: 10:39:17.760: basetransform: second attempt to fixate caps returned invalid (NULL) caps on pad nvdsvideotemplate0:sink
Please refer to the following pipeline, I’m using the latest models with DeepStream 7.1, you can just refer to the pipeline itself.
gst-launch-1.0 filesrc location=/home/xxxx/in.jpg ! jpegparse ! nvv4l2decoder ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=NV12' ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=1080 ! nvdsvideotemplate customlib-name=/home/xxxx/libnvocdr_impl.so customlib-props="ocdnet-engine-path:/home/xxxx/ocdnet.fp16.engine" customlib-props="ocdnet-input-shape:3,736,1280" customlib-props="ocdnet-binarize-threshold:0.1" customlib-props="ocdnet-polygon-threshold:0.3" customlib-props="ocdnet-max-candidate:200" customlib-props="ocrnet-engine-path:/home/xxxx/ocrnet.fp16.engine" customlib-props="ocrnet-dict-path:/home/xxxx/character_list" customlib-props="ocrnet-input-shape:1,64,200" customlib-props="ocrnet-decode:Attention" ! nvmultistreamtiler rows=1 columns=1 width=1280 height=720 ! nvdsosd ! nvvideoconvert ! 'video/x-raw,format=I420' ! jpegenc ! jpegparse ! filesink location=/home/xxxx/output.jpg
followed your suggestions. but no luck. getting error in reading the OCRnet dict file. command and log is attached below.
gst-launch-1.0 filesrc location=/home/rptech/projects/ocdr/onnx_models/repo/c++_samples/test_img/scene_text.jpg ! jpegparse ! nvv4l2decoder ! nvvideoconvert ! ‘video/x-raw(memory:NVMM),format=NV12’ ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=1080 ! nvdsvideotemplate customlib-name=/home/rptech/projects/ocdr/onnx_models/repo/deepstream/libnvocdr_impl.so customlib-props=“ocdnet-engine-path:/home/rptech/projects/ocdr/onnx_models/ocdnet.fp16.engine” customlib-props=“ocdnet-input-shape:3,736,1280” customlib-props=“ocdnet-binarize-threshold:0.1” customlib-props=“ocdnet-polygon-threshold:0.3” customlib-props=“ocdnet-max-candidate:200” customlib-props=“ocrnet-engine-path:/home/rptech/projects/ocdr/onnx_models/ocrnet.fp16.engine” customlib-props=“ocrnet-dict-path:home/rptech/projects/ocdr/onnx_models/character_list.txt” customlib-props=“ocrnet-input-shape:1,64,200” customlib-props=“ocrnet-decode:Attention” ! nvmultistreamtiler rows=1 columns=1 width=1280 height=720 ! nvdsosd ! nvvideoconvert ! ‘video/x-raw,format=I420’ ! jpegenc ! jpegparse ! filesink location=/home/rptech/projects/ocdr/onnx_models/repo/c++_samples/test_img/output.jpg
Inside Custom Lib : Setting Prop Key=ocrnet-input-shape Value=1,64,200
Inside Custom Lib : Setting Prop Key=ocrnet-decode Value=Attention
Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
[ERROR] Error reading OCRNet dict file home/rptech/projects/ocdr/onnx_models/character_list.txt
I’m using different models. Please replace this part with your original configurations.
what does original configurations mean? I am downloading models from NGC only which is mentioned in TAO documentation(Deploying nvOCDR to DeepStream - NVIDIA Docs).
Use your configuration.
Sorry!
I am not understanding what you actually mean by “your configuration” because i am using my files/directories in the above command provided by you.
My nvdsvideotemplate configuration is different to your nvdsvideotemplate configuration
This is yours:
This is mine:
This is because I used different OCD/OCR models. Please use your configuration with your models.
I dont have any custom model right now. I am using the same pre-trained model model(downloaded from the link mentioned in the repo) and compiling(for trt model) them with the same name that are mentioned in the repo.
Intially, i want to benchmark on my jetson and then i will customise as per my requirements.
Please suggest!
What is your issue? Your pipeline can work after adding nvvideoconvert and capsfilter after the nvv4l2decoder.
I tried but this time there is some different error. Logs are as follows
gst-launch-1.0 filesrc location=/home/rptech/projects/ocdr/onnx_models/repo/c++_samples/test_img/scene_text.jpg ! jpegparse ! nvv4l2decoder ! nvvideoconvert ! capsfilter ! ‘video/x-raw(memory:NVMM),format=NV12’ ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=1080 ! nvdsvideotemplate customlib-name=/home/rptech/projects/ocdr/onnx_models/repo/deepstream/libnvocdr_impl.so customlib-props=“ocdnet-engine-path:/home/rptech/projects/ocdr/onnx_models/ocdnet.fp16.engine” customlib-props=“ocdnet-input-shape:3,736,1280” customlib-props=“ocdnet-binarize-threshold:0.1” customlib-props=“ocdnet-polygon-threshold:0.3” customlib-props=“ocdnet-max-candidate:200” customlib-props=“ocrnet-engine-path:/home/rptech/projects/ocdr/onnx_models/ocrnet.fp16.engine” customlib-props=“ocrnet-dict-path:/home/rptech/projects/ocdr/onnx_models/character_list” customlib-props=“ocrnet-input-shape:1,64,200” customlib-props=“ocrnet-decode:Attention” ! nvmultistreamtiler rows=1 columns=1 width=1280 height=720 ! nvdsosd ! nvvideoconvert ! ‘video/x-raw,format=I420’ ! jpegenc ! jpegparse ! filesink location=/home/rptech/projects/ocdr/onnx_models/repo/c++_samples/test_img/output.jpg
Inside Custom Lib : Setting Prop Key=ocrnet-dict-path Value=/home/rptech/projects/ocdr/onnx_models/character_list
Line 93: ‘’ failed: an illegal memory access was encountered
Aborted (core dumped)
Please suggest!
I think your model shape is customlib-props=“ocrnet-input-shape:1,32,100” as what you post in the Error in nvOCDR DeepStream
