Error in radixSort.cu I found an error in radixSort.cu
Even the device emulation mode being deprecated in the release 3.0 of Cuda SDK, I need to use this mode when I’m at home. When I compiled the SDK example projects using “make emu=1” I found in the file radixSort.cu, line 191 that “t” is already defined. I removed the T and the problem was solved.
But this error just is shown in the device emulation mode becouse it was written inside a #ifdef DEVICE_EMULATION directive.
Hope this can help someone.
