error in results - bitwise operations on gpu
HI I have the following kernel that computes two variables TW and Tag
based on input buffer
I have also included the c func that does the same job
I see that the results from the GPU are completely erratic
Is there something that I’m completely unaware when
implementing bit operations on gpu
Can someone please let me know
Or is there any other fast method to do the same with correct results
Thanx in advance
Get_Tag_TW<<< dimGrid, dimBlock >>>(d_buffer,d_TW,d_Tag);
/// kernel for GPU
__global__
void Get_Tag_TW(unsigned char *Buffer, int *TW,unsigned char *Tag)
	__shared__ unsigned char	shrd_buffer[BLOCK_SIZE];
	__shared__  int		shrd_TW[BLOCK_SIZE];
	__shared__ unsigned char		shrd_Tag[BLOCK_SIZE];
	unsigned int index_in = blockIdx.x * blockDim.x + threadIdx.x;
	if(index_in < NBYTES)
		shrd_Tag[threadIdx.x]= 0x00;
	shrd_Tag[threadIdx.x] = shrd_Tag[threadIdx.x] | (( Buffer[8*threadIdx.x+3] >> 3)& 0x08);
	shrd_Tag[threadIdx.x] = shrd_Tag[threadIdx.x] | ((Buffer[8*threadIdx.x+7] >>4)& 0x04);
	shrd_Tag[threadIdx.x] = shrd_Tag[threadIdx.x] | ((Buffer[8*threadIdx.x+5])& 0x03);
		shrd_TW[threadIdx.x] = Buffer[8*threadIdx.x+5];
		shrd_TW[threadIdx.x] = (shrd_TW[threadIdx.x]<< 8 )|Buffer[8*threadIdx.x+4];
	shrd_TW[threadIdx.x] = (shrd_TW[threadIdx.x]<< 8 )|Buffer[8*threadIdx.x+1];
	shrd_TW[threadIdx.x] = (shrd_TW[threadIdx.x]<< 8 )|Buffer[8*threadIdx.x];
__syncthreads();
	TW[index_in] = shrd_TW[threadIdx.x];
	Tag[index_in]= shrd_Tag[threadIdx.x];
/// C func for same operation on CPU
void  readBuffer(unsigned char* Tag,int* TW,unsigned char* addressBuffer )
int i=0;
for (i=0;i<NBYTES;i++)
	Tag[i]= 0x00;
	Tag[i] = Tag[i] | (( addressBuffer[8*i+3] >> 3)& 0x08);
	Tag[i] = Tag[i] | ((addressBuffer[8*i+7] >>4)& 0x04);
	Tag[i] = Tag[i] | ((addressBuffer[8*i+5])& 0x03);
	TW[i] = addressBuffer[8*i+5];
	TW[i] = (TW[i]<< 8 )|addressBuffer[8*i+4];
	TW[i] = (TW[i]<< 8 )|addressBuffer[8*i+1];
	TW[i] = (TW[i]<< 8 )|addressBuffer[8*i+0];
You have a _syncthreads() inside a divergent conditional… always bad news.
I don’t think it’s needed at all, since the threads don’t intercommunicate.
A side note, this kernel will be very slow since you’re reading device memory every line. If its speed is a problem you can load a couple lines of your Buffer data into shared memory and access it a lot faster from there.
Thank you
