Error in trtexec conversion model in deepstream container: Cuda failure: forward compatibility was attempted on non supported HW Aborted (core dumped)
RTX 2060
• DeepStream Version
Deepstream Container 6.2
• TensorRT Version
8.2
In container:
nvidia-smi
Wed Jun 28 09:56:50 2023
| NVIDIA-SMI 470.182.03   Driver Version: 470.182.03   CUDA Version: 11.8     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  Off  | 00000000:05:00.0  On |                  N/A |
|  0%   53C    P5    20W / 160W |   1607MiB /  5932MiB |     19%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
questions
trtexec --onnx=bird_1810_sf.onnx  --saveEngine=bird_1810_sf.trt --workspace=1024 --best
&&&& RUNNING TensorRT.trtexec [TensorRT v8502] # trtexec --onnx=bird_1810_sf.onnx --saveEngine=bird_1810_sf.trt --workspace=1024 --best
[06/28/2023-09:55:40] [W] --workspace flag has been deprecated by --memPoolSize flag.
[06/28/2023-09:55:40] [I] === Model Options ===
[06/28/2023-09:55:40] [I] Format: ONNX
[06/28/2023-09:55:40] [I] Model: bird_1810_sf.onnx
[06/28/2023-09:55:40] [I] Output:
[06/28/2023-09:55:40] [I] === Build Options ===
[06/28/2023-09:55:40] [I] Max batch: explicit batch
[06/28/2023-09:55:40] [I] Memory Pools: workspace: 1024 MiB, dlaSRAM: default, dlaLocalDRAM: default, dlaGlobalDRAM: default
[06/28/2023-09:55:40] [I] minTiming: 1
[06/28/2023-09:55:40] [I] avgTiming: 8
[06/28/2023-09:55:40] [I] Precision: FP32+FP16+INT8
[06/28/2023-09:55:40] [I] LayerPrecisions:
[06/28/2023-09:55:40] [I] Calibration: Dynamic
[06/28/2023-09:55:40] [I] Refit: Disabled
[06/28/2023-09:55:40] [I] Sparsity: Disabled
[06/28/2023-09:55:40] [I] Safe mode: Disabled
[06/28/2023-09:55:40] [I] DirectIO mode: Disabled
[06/28/2023-09:55:40] [I] Restricted mode: Disabled
[06/28/2023-09:55:40] [I] Build only: Disabled
[06/28/2023-09:55:40] [I] Save engine: bird_1810_sf.trt
[06/28/2023-09:55:40] [I] Load engine:
[06/28/2023-09:55:40] [I] Profiling verbosity: 0
[06/28/2023-09:55:40] [I] Tactic sources: Using default tactic sources
[06/28/2023-09:55:40] [I] timingCacheMode: local
[06/28/2023-09:55:40] [I] timingCacheFile:
[06/28/2023-09:55:40] [I] Heuristic: Disabled
[06/28/2023-09:55:40] [I] Preview Features: Use default preview flags.
[06/28/2023-09:55:40] [I] Input(s)s format: fp32:CHW
[06/28/2023-09:55:40] [I] Output(s)s format: fp32:CHW
[06/28/2023-09:55:40] [I] Input build shapes: model
[06/28/2023-09:55:40] [I] Input calibration shapes: model
[06/28/2023-09:55:40] [I] === System Options ===
[06/28/2023-09:55:40] [I] Device: 0
[06/28/2023-09:55:40] [I] DLACore:
[06/28/2023-09:55:40] [I] Plugins:
[06/28/2023-09:55:40] [I] === Inference Options ===
[06/28/2023-09:55:40] [I] Batch: Explicit
[06/28/2023-09:55:40] [I] Input inference shapes: model
[06/28/2023-09:55:40] [I] Iterations: 10
[06/28/2023-09:55:40] [I] Duration: 3s (+ 200ms warm up)
[06/28/2023-09:55:40] [I] Sleep time: 0ms
[06/28/2023-09:55:40] [I] Idle time: 0ms
[06/28/2023-09:55:40] [I] Streams: 1
[06/28/2023-09:55:40] [I] ExposeDMA: Disabled
[06/28/2023-09:55:40] [I] Data transfers: Enabled
[06/28/2023-09:55:40] [I] Spin-wait: Disabled
[06/28/2023-09:55:40] [I] Multithreading: Disabled
[06/28/2023-09:55:40] [I] CUDA Graph: Disabled
[06/28/2023-09:55:40] [I] Separate profiling: Disabled
[06/28/2023-09:55:40] [I] Time Deserialize: Disabled
[06/28/2023-09:55:40] [I] Time Refit: Disabled
[06/28/2023-09:55:40] [I] NVTX verbosity: 0
[06/28/2023-09:55:40] [I] Persistent Cache Ratio: 0
[06/28/2023-09:55:40] [I] Inputs:
[06/28/2023-09:55:40] [I] === Reporting Options ===
[06/28/2023-09:55:40] [I] Verbose: Disabled
[06/28/2023-09:55:40] [I] Averages: 10 inferences
[06/28/2023-09:55:40] [I] Percentiles: 90,95,99
[06/28/2023-09:55:40] [I] Dump refittable layers:Disabled
[06/28/2023-09:55:40] [I] Dump output: Disabled
[06/28/2023-09:55:40] [I] Profile: Disabled
[06/28/2023-09:55:40] [I] Export timing to JSON file:
[06/28/2023-09:55:40] [I] Export output to JSON file:
[06/28/2023-09:55:40] [I] Export profile to JSON file:
the TensorRT version should be TRT 8.5.2.2 in DS6.2, please refer to this table. did you change any software version?
sorry,my error for trt version.but this is not reason.when I update the gpu driver version for host ,I got the right result.so thanks!
