Error installing CloudXR
I have an error when installing the CloudXR Setup. See the attached capture.
Thanks.!
cloudxr_error|493x383
This means that you already have the Nvidia Audio Capture driver installed on your system, and it is in use. This can sometimes get installed with GeForce Experience. It should be fine to ignore and continue the installation as the version packaged with GeForce Experience and our version are compatible.
Thanks,
Will
