Error installing Deepstream plugin
I’m able to generate the .so file of the plugin, but I think the element is not installed properly , since gst-inspect-1.0 gives
"No such element or ‘plugin’ ".
try sudo make install too.
I have done sudo make install…
I once tried to create a custom gstreamer element.
Purpose was to do preprocessing in gpu memory itself.
I am unsure how this helps you but for me to be able to use custom plugin in deepstream, all I had to do was make and sudo make install.
Which plugin are you trying to use?
I’m trying to make custom plugin, with nvvidconv element as the base. .
so what is your problem ?
• DeepStream Version
• TensorRT Version
• The pipeline being used
