安装 Isaac Sim 时出错:Command failed: “/home/arx/.local/share/ov/pkg/isaac_sim-2022.1.1/omni.isaac.sim.post.install.sh”
UsdE57FileFormat
OmniAssetFileFormat
/home/arx/.local/share/ov/pkg/isaac_sim-2022.1.1/omni.isaac.sim.post.install.sh:行 17: 11247 已杀死 ${SCRIPT_DIR}/omni.isaac.sim.warmup.sh
Hi. Does Create or Code run with no issues?
Please share your Isaac Sim log at
~/.nvidia-omniverse/logs/Kit/Isaac-Sim/2022.1
Hi. I got a similar error.
Error occurred during installation of Isaac Sim: Command failed: “/home/user/.local/share/ov/pkg/isaac_sim-2022.1.1/omni.isaac.sim.post.install.sh”
UsdE57FileFormat
OmniAssetFileFormat
2022-10-26 11:56:18 [6,517ms] [Error] [carb.crashreporter-breakpad.plugin] crash detected
2022-10-26 11:56:29 [17,023ms] [Error] [carb.crashreporter-breakpad.plugin] Wrote dump file ‘/home/user/.local/share/ov/data/Kit/Isaac-Sim/2022.1/37a5d0ed-f7ab-4831-a46ba581-de59a7e4.dmp’
2022-10-26 11:56:29 [17,023ms] [Error] [carb.crashreporter-breakpad.plugin] dump file size is -1 bytes, file is not readable.
2022-10-26 11:56:29 [17,024ms] [Fatal] [carb.crashreporter-breakpad.plugin] Crash detected in pid 33418 thread 33418
2022-10-26 11:56:29 [17,024ms] [Fatal] [carb.crashreporter-breakpad.plugin] Thread 33418 backtrace follows:
2022-10-26 11:56:29 [17,102ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libcarb.events.plugin.so!std::basic_string<char, std::char_traits, std::allocator >::~basic_string()+0xde4 (??:?)
2022-10-26 11:56:29 [17,176ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libcarb.assets.plugin.so!std::basic_string<char, std::char_traits, std::allocator >::basic_string(std::string const&, unsigned long, unsigned long)+0x8e54 (??:?)
2022-10-26 11:56:29 [17,232ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libcarb.datasource-file.plugin.so!std::basic_string<char, std::char_traits, std::allocator >::~basic_string()+0x424 (??:?)
2022-10-26 11:56:29 [17,316ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: libgpu.foundation.plugin.so!std::fill(std::_Bit_iterator, std::_Bit_iterator, bool const&)+0x374 (??:?)
2022-10-26 11:56:29 [17,388ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: libcarb.datasource-omniclient.plugin.so!std::_V2::condition_variable_any::~condition_variable_any()+0x1044 (??:?)
2022-10-26 11:56:29 [17,458ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: libomni.kit.renderer.plugin.so!std::__future_base::_Resultcarb::datasource::Connection*::_M_destroy()+0x3674 (??:?)
2022-10-26 11:56:29 [17,526ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: librtx.materialdb.plugin.so!std::mutex::lock()+0x224 (??:?)
2022-10-26 11:56:29 [17,592ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: libpthread.so.0!funlockfile+0x60 (sigaction.c:?)
/home/user/.local/share/ov/pkg/isaac_sim-2022.1.1/omni.isaac.sim.post.install.sh: line 17: 33418 Segmentation fault (core dumped) ${SCRIPT_DIR}/omni.isaac.sim.warmup.sh
kit_20221026_145612.log (513.5 KB)
crash_2022-10-26_14-56-29_33418.txt (3.1 KB)
Hi. Please reinstall your drivers. The 470 and 510 drivers are recommended.
See also: Linux Troubleshooting — Omniverse Robotics documentation
