I installed jetpack4.2 using sdk-manager.
An error was detected in the terminal during the os flash process during installation.
First error occurred:Flash Jetson Nano : lost connection (os flashing 10.8%)
(I’ve already installed Python.)
Second error occurred: Flash Jetson Nano : Board ID (3448) version (200)
Third error:ERROR: Flash Jetson Nano 10: RAW: 177209344( 169 blks) ==> 84934804:177209356
Terminal is as follows.
Flash JETSON NANO os10.8%
• 22:22:29 ERROR :
• 22:24:40 INFO : Flash Jetson Nano : exit status 255
• 22:24:40 WARNING : Flash Jetson Nano : command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh nvidia@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no nvidia@192.168.55.1 “~/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh && rm -f ~/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh” finished with error, but ignored
• 22:24:40 INFO : Flash Jetson Nano : exec_command: sleep 20
• 22:25:00 INFO : Flash Jetson Nano : exec_command: sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1
• 22:25:00 INFO : Flash Jetson Nano : ###############################################################################
• 22:25:00 INFO : Flash Jetson Nano : # L4T BSP Information:
• 22:25:00 INFO : Flash Jetson Nano : # R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t210ref, EABI: aarch64,
• 22:25:00 INFO : Flash Jetson Nano : # DATE: Wed Mar 13 07:46:13 UTC 2019
• 22:25:00 INFO : Flash Jetson Nano : # Target Board Information:
• 22:25:00 INFO : Flash Jetson Nano : # Name: jetson-nano-qspi-sd, Board Family: t210ref, SoC: Tegra 210,
• 22:25:00 INFO : Flash Jetson Nano : # OpMode: production, Boot Authentication: ,
• 22:25:00 INFO : Flash Jetson Nano : ./tegraflash.py --chip 0x21 --applet “/home/lim/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/nvtboot_recovery.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin”
• 22:25:00 INFO : Flash Jetson Nano : Welcome to Tegra Flash
• 22:25:00 INFO : Flash Jetson Nano : version 1.0.0
• 22:25:00 INFO : Flash Jetson Nano : Type ? or help for help and q or quit to exit
• 22:25:00 INFO : Flash Jetson Nano : Use ! to execute system commands
• 22:25:00 INFO : Flash Jetson Nano : [ 0.0017 ] Generating RCM messages
• 22:25:00 INFO : Flash Jetson Nano : [ 0.0024 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/lim/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
• 22:25:00 INFO : Flash Jetson Nano : [ 0.0030 ] RCM 0 is saved as rcm_0.rcm
• 22:25:00 INFO : Flash Jetson Nano : [ 0.0412 ] RCM 1 is saved as rcm_1.rcm
• 22:25:00 INFO : Flash Jetson Nano : [ 0.0412 ] List of rcm files are saved in rcm_list.xml
• 22:25:00 INFO : Flash Jetson Nano : [ 0.0413 ] Signing RCM messages
• 22:25:00 INFO : Flash Jetson Nano : [ 0.0473 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
• 22:25:00 INFO : Flash Jetson Nano : [ 0.0500 ] Assuming zero filled SBK key
• 22:25:00 INFO : Flash Jetson Nano : [ 0.0759 ]
• 22:25:00 INFO : Flash Jetson Nano : [ 0.0759 ] Copying signature to RCM mesages
• 22:25:00 INFO : Flash Jetson Nano : [ 0.0770 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
• 22:25:00 INFO : Flash Jetson Nano : [ 0.0782 ]
• 22:25:00 INFO : Flash Jetson Nano : [ 0.0782 ] Boot Rom communication
• 22:25:00 INFO : Flash Jetson Nano : [ 0.0790 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
• 22:25:00 INFO : Flash Jetson Nano : [ 0.0797 ] RCM version 0X210001
• 22:25:01 INFO : Flash Jetson Nano : [ 0.1215 ] Boot Rom communication completed
• 22:25:01 INFO : Flash Jetson Nano : [ 1.1285 ]
• 22:25:01 INFO : Flash Jetson Nano : [ 1.1287 ] dump EEPROM info
• 22:25:01 INFO : Flash Jetson Nano : [ 1.1317 ] tegrarcm --oem platformdetails eeprom /home/lim/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/cvm.bin
• 22:25:02 INFO : Flash Jetson Nano : [ 1.1345 ] Applet version 00.01.0000
• 22:25:02 INFO : Flash Jetson Nano : [ 1.1517 ] Saved platform info in /home/lim/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra/bootloader/cvm.bin
• 22:25:02 INFO : Flash Jetson Nano : [ 1.2279 ]
• 22:25:02 ERROR : Flash Jetson Nano : Board ID(3448) version(200)
23%
22:27:18 ERROR : Flash Jetson Nano : 10: RAW: 177209344( 169 blks) ==> 84934804:177209356
• 22:27:18 ERROR : Flash Jetson Nano : 11: SKP: 3145728( 3 blks) ==> 262144160:12
• 22:27:19 ERROR : Flash Jetson Nano : 12: RAW: 137363456( 131 blks) ==> 262144172:137363468
• 22:27:19 ERROR : Flash Jetson Nano : 13: SKP: 1048576( 1 blks) ==> 399507640:12
• 22:27:19 ERROR : Flash Jetson Nano : 14: RAW: 12582912( 12 blks) ==> 399507652:12582924
• 22:27:19 ERROR : Flash Jetson Nano : 15: SKP: 1048576( 1 blks) ==> 412090576:12
• 22:27:19 ERROR : Flash Jetson Nano : 16: RAW: 113246208( 108 blks) ==> 412090588:113246220
• 22:27:19 ERROR : Flash Jetson Nano : 17: SKP: 3145728( 3 blks) ==> 525336808:12
• 22:27:19 ERROR : Flash Jetson Nano : 18: RAW: 2097152( 2 blks) ==> 525336820:2097164
• 22:27:19 ERROR : Flash Jetson Nano : 19: SKP: 2097152( 2 blks) ==> 527433984:12
• 22:27:19 ERROR : Flash Jetson Nano : 20: RAW: 55574528( 53 blks) ==> 527433996:55574540
• 22:27:19 ERROR : Flash Jetson Nano : 21: SKP: 3145728( 3 blks) ==> 583008536:12
• 22:27:19 ERROR : Flash Jetson Nano : 22: RAW: 38797312( 37 blks) ==> 583008548:38797324
• 22:27:19 ERROR : Flash Jetson Nano : 23: SKP: 3145728( 3 blks) ==> 621805872:12
• 22:27:19 ERROR : Flash Jetson Nano : 24: RAW: 30408704( 29 blks) ==> 621805884:30408716
• 22:27:19 ERROR : Flash Jetson Nano : 25: SKP: 3145728( 3 blks) ==> 652214600:12
• 22:27:19 ERROR : Flash Jetson Nano : 26: RAW: 30408704( 29 blks) ==> 652214612:30408716
• 22:27:19 ERROR : Flash Jetson Nano : 27: SKP: 3145728( 3 blks) ==> 682623328:12
• 22:27:19 ERROR : Flash Jetson Nano : 28: RAW: 38797312( 37 blks) ==> 682623340:38797324
• 22:27:19 ERROR : Flash Jetson Nano : 29: SKP: 3145728( 3 blks) ==> 721420664:12
• 22:27:19 ERROR : Flash Jetson Nano : 30: RAW: 14680064( 14 blks) ==> 721420676:14680076
• 22:27:19 ERROR : Flash Jetson Nano : 31: SKP: 2097152( 2 blks) ==> 736100752:12
• 22:27:19 ERROR : Flash Jetson Nano : 32: RAW: 34603008( 33 blks) ==> 736100764:34603020
• 22:27:19 ERROR : Flash Jetson Nano : 33: SKP: 3145728( 3 blks) ==> 770703784:12
• 22:27:19 ERROR : Flash Jetson Nano : 34: RAW: 19922944( 19 blks) ==> 770703796:19922956
• 22:27:19 ERROR : Flash Jetson Nano : 35: SKP: 1048576( 1 blks) ==> 790626752:12
• 22:27:19 ERROR : Flash Jetson Nano : 36: RAW: 114294784( 109 blks) ==> 790626764:114294796
• 22:27:19 ERROR : Flash Jetson Nano : 37: SKP: 3145728( 3 blks) ==> 904921560:12
• 22:27:19 ERROR : Flash Jetson Nano : 38: RAW: 62914560( 60 blks) ==> 904921572:62914572
• 22:27:19 ERROR : Flash Jetson Nano : 39: SKP: 4194304( 4 blks) ==> 967836144:12
• 22:27:19 ERROR : Flash Jetson Nano : 40: RAW: 30408704( 29 blks) ==> 967836156:30408716
• 22:27:19 ERROR : Flash Jetson Nano : 41: SKP: 3145728( 3 blks) ==> 998244872:12
• 22:27:19 ERROR : Flash Jetson Nano : 42: RAW: 26214400( 25 blks) ==> 998244884:26214412
• 22:27:19 ERROR : Flash Jetson Nano : 43: SKP: 3145728( 3 blks) ==> 1024459296:12
• 22:27:19 ERROR : Flash Jetson Nano : 44: RAW: 3145728( 3 blks) ==> 1024459308:3145740
• 22:27:19 ERROR : Flash Jetson Nano : 45: SKP: 1048576( 1 blks) ==> 1027605048:12
• 22:27:19 ERROR : Flash Jetson Nano : 46: RAW: 7340032( 7 blks) ==> 1027605060:7340044
• 22:27:19 ERROR : Flash Jetson Nano : 47: SKP: 2097152( 2 blks) ==> 1034945104:12
• 22:27:19 ERROR : Flash Jetson Nano : 48: RAW: 130023424( 124 blks) ==> 1034945116:130023436
• 22:27:19 ERROR : Flash Jetson Nano : 49: SKP: 3145728( 3 blks) ==> 1164968552:12
• 22:27:19 ERROR : Flash Jetson Nano : 50: RAW: 80740352( 77 blks) ==> 1164968564:80740364
• 22:27:19 ERROR : Flash Jetson Nano : 51: SKP: 3145728( 3 blks) ==> 1245708928:12
• 22:27:19 ERROR : Flash Jetson Nano : 52: RAW: 15728640( 15 blks) ==> 1245708940:15728652
• 22:27:19 ERROR : Flash Jetson Nano : 53: SKP: 1048576( 1 blks) ==> 1261437592:12
• 22:27:19 ERROR : Flash Jetson Nano : 54: RAW: 8388608( 8 blks) ==> 1261437604:8388620
• 22:27:19 ERROR : Flash Jetson Nano : 55: SKP: 8388608( 8 blks) ==> 1269826224:12
• 22:27:19 ERROR : Flash Jetson Nano : 56: RAW: 7340032( 7 blks) ==> 1269826236:7340044
• 22:27:19 ERROR : Flash Jetson Nano : 57: SKP: 663748608( 633 blks) ==> 1277166280:12
• 22:27:19 ERROR : Flash Jetson Nano : 58: RAW: 7340032( 7 blks) ==> 1277166292:7340044
• 22:27:19 ERROR : Flash Jetson Nano : 59: SKP: 26214400( 25 blks) ==> 1284506336:12
• 22:27:19 ERROR : Flash Jetson Nano : 60: RAW: 12582912( 12 blks) ==> 1284506348:12582924
• 22:27:19 ERROR : Flash Jetson Nano : 61: SKP: 88080384( 84 blks) ==> 1297089272:12
• 22:27:20 ERROR : Flash Jetson Nano : 62: RAW: 455081984( 434 blks) ==> 1297089284:455081996
• 22:27:20 ERROR : Flash Jetson Nano : 63: SKP: 618659840( 590 blks) ==> 1752171280:12
• 22:27:20 ERROR : Flash Jetson Nano : 64: RAW: 1048576( 1 blks) ==> 1752171292:1048588
• 22:27:20 ERROR : Flash Jetson Nano : 65: SKP: 267386880( 255 blks) ==> 1753219880:12
• 22:27:20 ERROR : Flash Jetson Nano : 66: RAW: 1048576( 1 blks) ==> 1753219892:1048588
• 22:27:21 ERROR : Flash Jetson Nano : 67: SKP: 670040064( 639 blks) ==> 1754268480:12
• 22:27:21 ERROR : Flash Jetson Nano : 68: RAW: 9437184( 9 blks) ==> 1754268492:9437196
• 22:27:22 ERROR : Flash Jetson Nano : 69: SKP: 24117248( 23 blks) ==> 1763705688:12
• 22:27:22 ERROR : Flash Jetson Nano : 70: RAW: 12582912( 12 blks) ==> 1763705700:12582924
• 22:27:22 ERROR : Flash Jetson Nano : 71: SKP: 88080384( 84 blks) ==> 1776288624:12
• 22:27:22 ERROR : Flash Jetson Nano : 72: RAW: 34603008( 33 blks) ==> 1776288636:34603020
• 22:27:22 ERROR : Flash Jetson Nano : 73: SKP: 1048576( 1 blks) ==> 1810891656:12
• 22:27:30 ERROR : Flash Jetson Nano : 74: RAW: 1013972992( 967 blks) ==> 1810891668:1013973004
• 22:27:30 ERROR : Flash Jetson Nano : 75: SKP: 963641344( 919 blks) ==> 2824864672:12
• 22:27:31 ERROR : Flash Jetson Nano : 76: RAW: 7340032( 7 blks) ==> 2824864684:7340044
• 22:27:31 ERROR : Flash Jetson Nano : 77: SKP: 26214400( 25 blks) ==> 2832204728:12
• 22:27:31 ERROR : Flash Jetson Nano : 78: RAW: 12582912( 12 blks) ==> 2832204740:12582924
• 22:27:31 ERROR : Flash Jetson Nano : 79: SKP: 88080384( 84 blks) ==> 2844787664:12
• 22:27:31 ERROR : Flash Jetson Nano : 80: RAW: 1048576( 1 blks) ==> 2844787676:1048588
• 22:27:31 ERROR : Flash Jetson Nano : 81: SKP: 3145728( 3 blks) ==> 2845836264:12
• 22:27:37 ERROR : Flash Jetson Nano : 82: RAW: 715128832( 682 blks) ==> 2845836276:715128844
• 22:27:37 ERROR : Flash Jetson Nano : 83: SKP: 18874368( 18 blks) ==> 3560965120:12
• 22:27:37 ERROR : Flash Jetson Nano : 84: RAW: 33554432( 32 blks) ==> 3560965132:33554444
• 22:27:37 ERROR : Flash Jetson Nano : 85: SKP: 1241513984( 1184 blks) ==> 3594519576:12
• 22:27:38 ERROR : Flash Jetson Nano : 86: RAW: 6291456( 6 blks) ==> 3594519588:6291468
• 22:27:38 ERROR : Flash Jetson Nano : 87: SKP: 27262976( 26 blks) ==> 3600811056:12
• 22:27:38 ERROR : Flash Jetson Nano : 88: RAW: 16777216( 16 blks) ==> 3600811068:16777228
• 22:27:39 ERROR : Flash Jetson Nano : 89: SKP: 83886080( 80 blks) ==> 3617588296:12
• 22:27:40 ERROR : Flash Jetson Nano : 90: RAW: 167772160( 160 blks) ==> 3617588308:167772172
• 22:27:41 ERROR : Flash Jetson Nano : 91: SKP: 1845493760( 1760 blks) ==> 3785360480:12
• 22:27:41 ERROR : Flash Jetson Nano : 92: RAW: 6291456( 6 blks) ==> 3785360492:6291468
• 22:27:41 ERROR : Flash Jetson Nano : 93: SKP: 27262976( 26 blks) ==> 3791651960:12
• 22:27:41 ERROR : Flash Jetson Nano : 94: RAW: 18874368( 18 blks) ==> 3791651972:18874380
• 22:27:41 ERROR : Flash Jetson Nano : 95: SKP: 81788928( 78 blks) ==> 3810526352:12
• 22:27:41 ERROR : Flash Jetson Nano : 96: RAW: 1048576( 1 blks) ==> 3810526364:1048588
• 22:27:41 ERROR : Flash Jetson Nano : 97: SKP: 3145728( 3 blks) ==> 3811574952:12
• 22:27:42 ERROR : Flash Jetson Nano : 98: RAW: 111149056( 106 blks) ==> 3811574964:111149068
• 22:27:43 ERROR : Flash Jetson Nano : 99: SKP: 1897922560( 1810 blks) ==> 3922724032:12
• 22:27:43 ERROR : Flash Jetson Nano : 100: RAW: 5242880( 5 blks) ==> 3922724044:5242892
• 22:27:43 ERROR : Flash Jetson Nano : 101: SKP: 28311552( 27 blks) ==> 3927966936:12
• 22:27:43 ERROR : Flash Jetson Nano : 102: RAW: 13631488( 13 blks) ==> 3927966948:13631500
• 22:27:43 ERROR : Flash Jetson Nano : 103: SKP: 87031808( 83 blks) ==> 3941598448:12
• 22:27:45 ERROR : Flash Jetson Nano : 104: RAW: 296747008( 283 blks) ==> 3941598460:296747020
• 22:27:46 ERROR : Flash Jetson Nano : 105: SKP: 1716518912( 1637 blks) ==> 4238345480:12
• 22:27:46 INFO : Flash Jetson Nano : done.
• 22:27:46 INFO : Flash Jetson Nano : system.img built successfully.
• 22:27:46 ERROR : Flash Jetson Nano : – Total: ---------------------------------------------------
