Error Installing ROS on TX2
I’am new to Nvidia Tx2 Development.
I am now trying to install on a new TX2 ROS, but during installation phase (using the script ./installROS.sh, http://www.jetsonhacks.com/2017/03/27/robot-operating-system-ros-nvidia-jetson-tx2/) I had the following problem:
The following packages have unmet dependencies:
 python-rosinstall : Depends: python-vcstools (>= 0.1.38) but it is not going to be installed
                     Depends: python-wstool (>= 0.1.12) but it is not going to be installed
                     Depends: mercurial but it is not installable
E: Unable to correct problems, you have held broken packages.
Do you have any idea how to solve it? Seems that the problem is related to mercurial.
I am using the version:
# R27 (release), REVISION: 0.1
Description:	Ubuntu 16.04 LTS
Release:	16.04
Codename:	xenial
I’ve never dealt with this particular software, but you’re running L4T R27.0.1 which was the very first software running on a TX2. R28.1 is a far more reliable release…I’d suggest flashing to R28.1 (can be done with JetPack3.1) and checking again.
Mercurial should be in the Universe repository. Make sure Universe is enabled:
sudo add-apt-repository universe sudo apt-get update
You should be able to manually load mercurial if desired:
$ sudo apt-get install mercurial
However, L4T 27.1 is not a production release, and is not recommended for production use.
If you’re using the install script from https://github.com/jetsonhacks/installROSTX2 just use the updateRepositories.sh script from the same repo.
Yes, the @jeffrey.cousineau solution is much more clever. One thing that appears to happen is that different regions have different repositories enabled after flashing the Jetson. Most of the scripts that I have written assume that all of the repositories have been enabled similar to the fresh install of L4T that I have (I’m in the US).
Thanks Jeffrey!
updateRepositories.sh actually solved the problem.
Kangalow and linuxdev, anyway I will take your suggestion and update my TX2
