there are errors installing SDK Manager on AGX Drive:
18:46:52 ERROR: OSS and NV packages: /tmp/resolvconf.config.8HvZSF: 13: /tmp/resolvconf.config.8HvZSF: ifquery: not found
18:46:53 ERROR: OSS and NV packages: /tmp/resolvconf.config.8HvZSF: 13: /tmp/resolvconf.config.8HvZSF: ifquery: not found
18:52:18 INFO: Drive Platform Targetfs: docker: Error response from daemon: Get https://registry-1.docker.io/v2/: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers).
19:08:32 INFO: Drive Platform Targetfs: ERROR: could not build docker image
19:08:32 INFO: Drive Platform Targetfs: INFO: Removing the docker image(s) that was just created
19:08:32 INFO: Drive Platform Targetfs: Total reclaimed space: 0B
19:08:32 INFO: Drive Platform Targetfs: ERROR: The docker failed to properly install the components
19:08:32 INFO: Drive Platform Targetfs: Time to failure: 0 minutes and 45 seconds
19:08:32 INFO: Drive Platform Targetfs: [ Package Install Finished with Error ]
19:08:32 ERROR: Drive Platform Targetfs: [error]: : [exec_command]: /bin/bash -c /tmp/XXXXX/tmp_NV_DRIVE_PLATFORM_RFS_TARGET_COMP.sh; [error]:
19:08:32 ERROR: Drive Platform Targetfs: command terminated with error
19:08:32 SUMMARY: Drive Platform Targetfs: Failed to execute commands with GenericInstaller
19:08:32 SUMMARY: Flash Xavier A+B in parallel: Depends on failed component
19:08:32 SUMMARY: Drive Platform Targetfs Patch: Depends on failed component
Is this issue caused by the AGX Drive or by the host machine?
Is it recommended to perform the SDK manager installations again using another host machine?
Dear @andreas.schwager,
Yes. Trying from an another fresh installed host would resolve issues related to current host state and confirms if it is actually an issue with DRIVE platform.
E: Package ‘apt-utils’ has no installation candidate
The command ‘/bin/sh -c apt-get update && apt-get install --yes apt-utils && apt-get install --yes python3 python3-dev qemu-user-static && apt-get autoremove --yes && apt-get clean’ returned a non
-zero code: 100
Time to failure: 0 minutes and 56 seconds
