As i have CAN radar i’m willing to record the data sent by CANbus but with every recorder app I have the same issue: CANSocket: ioctl (SIOCSHTSTAMP, can0) failded -> bad adress. Cannot enable HW timestamps, try with root user.
When i try without sudo command i have : CANSocket: ioctl (SIOCSHTSTAMP, can0) failded -> Operation not permitted. Cannot enable HW timestamps, try with root user.
Could you also explain how the CAN network should be recorded?
Can I know how to record CAN data?
Are you using recorder-qt tool in DriveWorks tool?
If not, please refer to “Recording SocketCAN Data” part in DriveWorks development guide? Thanks.
Even when i use recorder-qt i have this error displayed. In fact every program that allows to record CAN data is having this issue…
To generate CAN data i have a vector CAN generator, all the samples are able to receive/decode the CANbus.
My final goal is to be able to take the car, do a ride and come back to the office and analyze all the recorded CAN data. To do that i customized the app sample_record but as i have this error the can.bin files are impossible to replay.
With the new PDK and DW i don’t have this issue anymore! But i can’t find any replayer for CANbus, do i miss something? As i remember in tools there was “replayer” in the previous version.
