Error is occured on pyds.gst_element_send_nvevent_new_stream_reset
I am converting the contents of “deepstream_source_bin.c” code to python language for rtspsrc reconnection.
I use the pyds.gst_element_send_nvevent_new_stream_reset() function to reset the source according to document.
That function receives “gst_element” and “source_id” as parameters. However, both arguments are supposed to receive int. And the following error occurs when i use the current function.
    # parser : gst element - h264parser
    if not pyds.gst_element_send_nvevent_new_stream_reset(parser, 0):
TypeError: gst_element_send_nvevent_new_stream_reset(): incompatible function arguments. The following argument types are supported:
    1. (arg0: int, arg1: int) -> int
Maybe i think wrong argument type(int) of gst_element is problem. How to solve this problem?
• Hardware Platform (Jetson / GPU) : Jetson & GPU
• DeepStream Version : 6.1(Jetson - pyds 1.1.4) & 6.1.1(GPU - pyds 1.1.4)
• JetPack Version (valid for Jetson only) : 5.0.1
• TensorRT Version :
• NVIDIA GPU Driver Version (valid for GPU only) : 525.60.11
• Issue Type( questions, new requirements, bugs) bugs
1. install pyds
2. run code on python3
import pyds
from gi.repository import Gst
Gst.init()
queue = Gst.ElementFactory.make("queue", "temp")
pyds.gst_element_send_nvevent_new_stream_reset(queue, 0)
Could you try to convert the queue and parser to int with python?
